Gt35r
Received my new turbo today. Any words of wisdom for install? What's the easiest way to re-clock? Do I need to put any oil in the bearing before running? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 08-17-2012, 06:54 PM
Brando
quattrorunner's Avatar
Oil would get there pretty quickly but it's not hard to drip some in I guess. I'd test mount it and have the bolts kinda loose and clock where it needs an tighten a couple the remove to tighten all ad replace. I'm sure you can figure that out. You got the right oil feed and new drain fittings? Turbokraft has everything. Only problem I had was te drip tank. I just don't use one. Can't fined one.
Old 08-18-2012, 11:25 PM
oil return tank
How did you guys modify the oil catch can to work with the GT35R ? Any one have a good picture? Or do yo eliminate the can altogether? Philip
Old 08-19-2012, 02:35 PM
Ok...
I think I got it. Very tight with the fibreglass rear bumper I have.
Old 08-19-2012, 05:32 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by philip j View Post
... Very tight with the fibreglass rear bumper I have.
You might as well keep the "binoculars"... New bumper on its way
Who Will Live... Will See
Old 08-20-2012, 02:37 AM
Brando
Quote de philip j
I don't get it?
Old 08-21-2012, 12:01 AM
JJ 911SC's Avatar
Originally Posted by quattrorunner View Post
I don't get it?
The Slippery Slope is so long that binoculars are needed to see the end of it
Old 08-21-2012, 02:05 AM
Brando
O well if you put it that way, I doubt binoculars will help.
Old 08-21-2012, 06:56 AM
