derek murray's Avatar
3.0l turbo engine into longhood?
I was wondering what the challenges would be in dropping a 3.0l turbo into my '70S, with 901 trans? Has anyone done this before, as my search did not turn anything up?
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 08-23-2012, 11:56 AM
I would rather be driving
jpnovak's Avatar
Should physically bolt in. What year 930 engine?
You will need a different 225mm flywheel, new oil tank (big problem here since the later tank will not fit the through-71 chassis without cutting. The Type 911 transmission would not be happy with the big torque of a 930 motor. I would suggest a 915 at a minimum. If you drive very "easy" (this does not mean slow) the Type 911 would last for a while.
You would need to adapt the fuel system. This means duel fuel pumps for stock CIS to maintain pressure and flow rates. The stock MFI pump will not match pressure.
there are some electronics differences. Most notably is the later 6pin CDI is required (or MSD) as the distributor uses a magnetic pickup, not points. There are, however, other ways around this.
YOu would probably want to upgrade the suspension. The 930 motor is considerably heavier than the 2.2S. Increased torsion bars at a minimum.
It has been done but is not a straight bolt-in.
What is wrong with the 911S engine? Just looking for more? given the current value of an early S I would be hesitant to make this swap. Certainly would be a very fun car to drive.
Old 08-23-2012, 01:25 PM
Thanks Jamie... the engine is a '77. Nothing is wrong with my "S" engine, but like you suggest, I'm looking for more. Fortunately, (or unfortunately) my car is a non-numbers matching, theft recovered vehicle (missing original VIN - but I luv her, just the same)... so it's pretty much a blank canvas, as far as I'm concerned.
Originally Posted by jpnovak View Post
What year 930 engine.... What is wrong with the 911S engine? Just looking for more? given the current value of an early S I would be hesitant to make this swap. Certainly would be a very fun car to drive.
'70 911S 1002938
Old 08-23-2012, 01:41 PM
Brando
quattrorunner's Avatar
Wow a blank canvas. I like that.
This would be a simple effort if you did things like returning oil from scavenge to the breather cover instead of the tank, used msd, swapped pump for Bosch 044, and used a 915. I love to follow projects like this. Good luck.
Old 08-23-2012, 03:33 PM
Jamie - I've upgraded the suspension with 27mm torsion bars, adjustable spring plates, and Koni adjustable shocks (yellow). Do you think that is enough?
You would probably want to upgrade the suspension. The 930 motor is considerably heavier than the 2.2S. Increased torsion bars at a minimum.
'70 911S 1002938
Old 08-24-2012, 12:16 PM
jpnovak's Avatar
Derek, The stock 930 had 26mm torsion bars. A 27 with the 930 motor would ride close to stock. 28mm would be better if you like the current ride comfort/stiffness ratio.
Sounds like you have a good platform to build this car. It can be done without modifications so that you can return it to original if you ever want to sell.
I have been assembling parts. I am going to try to build a 2.2 turbo motor.
Old 08-24-2012, 02:35 PM
Brando
update?
Turbo powa!
1977 911s. it's cool
Old 10-04-2012, 11:10 AM
Unfortunately, I've had a bit of a setback as I lost out on the engine I was wanting to buy... thanks for the bump, and I'll let you know as soon as some progress is made.
d.
Originally Posted by quattrorunner View Post
update?
'70 911S 1002938
Old 10-04-2012, 02:40 PM
