-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Dyno Sheet Requests (http://forums.pelicanparts.com/showthread.php?t=711131)
930LDR 10-12-2012 05:03 PM
Dyno Sheet Requests
I'm having my motor dyno'd and tuned following a rebuild of my own doing.
Interested to see if anyone has some engine Dyno sheets from a motor of similar shape and size so I can benchmark what I'm seeing from my shop.
3.3L
Stock Ports
Single Plug
SC Cams
GT35R turbo
1.0B
Thanks,
Ronnie's.930 10-12-2012 05:32 PM
Maybe one on this nine page thread is similar to yours?
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/521544-ultimate-930-dyno-thread.html
Hukdunfoniks 10-13-2012 07:44 AM
Here is the dyno from the same build as yours. I was also running an after market filter/intake and an Andial IC.http://forums.pelicanparts.com/uploa...1350139460.gif
930LDR 10-13-2012 12:41 PM
Thanks man... let me ask you a dumb question... what are the two sets of numbers on each side? Also was that on an engine or chassis dyno?
Hukdunfoniks 10-13-2012 12:49 PM
This was a chassis dyno measuring wheel horse power. The two numbers are hp and lbft or torque.
930LDR 10-13-2012 03:38 PM
That's what i was afraid of... I'm only seeing about 350 at the crank on my build. Waiting for the shop to complete a compression check now.
Hukdunfoniks 10-13-2012 07:24 PM
What IC are you using?
930LDR 10-14-2012 07:38 AM
Kokeln
Tt surgeon 10-14-2012 11:33 AM
Headers, exhaust?
930LDR 10-14-2012 08:25 PM
B&b headers. Rarlyl8 exhaust.
Tt surgeon 10-14-2012 08:46 PM
You should be seeing 350 at the wheels.
930LDR 10-15-2012 09:25 AM
That was my thought as well. I'm hoping the explanation may be too low of compression. Not so much because I'm looking forward to the expense to remedy that but because its an identifiable issue. Deck height was probably the one area I most likely could have made a mistake in my measurements. I was very focused on making sure that there was piston clearance but didn't confirm actual height. I'm used new factory 3.3 P&Cs.
fletcher0780 10-15-2012 02:34 PM
Post your dyno so we can take a look at it.
Tt surgeon 10-15-2012 03:20 PM
I would start w a compression test.
