-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   More 930 Headers - and now for something completely different ... (http://forums.pelicanparts.com/showthread.php?t=725928)
Midlife930 04-09-2013 06:38 AM
Thank you Brian!
My plan is exactly that, almost added the turn down tips then decided to wait until after break in to see if I could leave them straight. I like the straight out look .....
Dave
Midlife930 05-13-2013 10:03 AM
Now have about 400 kms on the car. 200 highway followed by 200 at Mosport this past weekend running at 0.7 bar and short shifting at 5000 (most of the time)
The car feels like the differential ratio has been lowered .... it is simply faster than before even at the lower boost!
Then it snowed on Sunday afternoon ending the event early.
Davehttp://forums.pelicanparts.com/uploa...1368464547.jpg
Midlife930 07-23-2013 05:25 AM
http://forums.pelicanparts.com/uploa...1374581477.jpg
http://forums.pelicanparts.com/uploa...1374581550.jpg
I'm happy to report that 2 more days at Mosport, 1 at Atlanta Motorsports Park, 2 at VIR and 3 at Calabogie and the car is running without issue!
Started at 0.7 bar boost thinking that was to be for break-in with the plan to go to 1 bar. Well as I am able to run to my chosen rev limit of 6500 in 4th on the back at Mosport and able to pull (just a tiny bit) a buddy in his 930 with a 3.6, Carrera manifold quoted as 600hp build with my little 3.4. I think he is well below 600 and my car is likely putting a reliable 400+ to the ground.
All is good and Brian I am very easily passing noise regulations of 92 at Calabogie.
People do ask why I have 3 mufflers and 12 coils ......
The new full up Elephant suspension set up is great too!
When these cars are set up they are a blast,
Dave
nocarrier 07-23-2013 07:47 AM
Nice car! Do you have any more pictures?
sundevil64 07-23-2013 08:34 AM
What muffler did you use? I also have a twin wg system from Mark and Brian. I have been limited so far to one of Brian's mufflers which I am fine with, just curious. It looks like you used a magnaflow or something along those lines.
Brian-What are you getting the wg mufflers now in days.
Midlife930 07-23-2013 12:15 PM
http://forums.pelicanparts.com/uploa...1374605947.jpg
http://forums.pelicanparts.com/uploa...1374606002.jpg
http://forums.pelicanparts.com/uploa...1374606716.jpg
Thanks for the compliment on the car.
Yes plain old Magnaflow with muffler shop welds.
The car shot is last year at Tremblant with NERPCA before the RS 3.8 wing and with the old exhaust set up.
Dave
Midlife930 07-26-2013 09:57 AM
http://forums.pelicanparts.com/uploa...1374857675.jpg
This is the reason I went to bigger intercooler, better flowing exhaust and turbo with the dual wastegates. Detonation during overboost which has now been completely eliminated.
Blow by was 70% so I knew ............
Dave
gsxrken 07-26-2013 11:52 AM
Originally Posted by Midlife930 (Post 7564306)
Well as I am able to run to my chosen rev limit of 6500 in 4th on the back at Mosport...
Holy crow, how fast is that? Do you have a 930 box or a 915?
Midlife930 07-29-2013 04:01 AM
I have closed up the third and fourth ratios in a 930 box.
27 driving 26 for third
30 driving 22 for fourth which gives you low 150's at 6500
Stock ratios are 28:25 & 32:20
I would like to raise the ratio for second to give me 3 relatively close gears. There are a few spots at the Glen where third is just a tad high and dropping to second is too much thrashing around.
Dave
Midlife930 11-19-2013 04:38 AM
Good morning,
My season ended at VIR with Chin at the end of October. Last night I was looking at some of my in car video and see that this year my lap times are in the order or 2 seconds quicker than last season. I am becoming more comfortable with the track but the interesting bit is the fact that I am running 0.7 bar this season against a full bar plus a bit last.
So I had a look at Oak tree to the braking zone on the back straight. Lowest speed at Oak tree varied between 69 to 67 kph, both this season and last and top speed both years was high 230's. If I was willing to brake later I expect 240 would be my top speed on that straight. The car weight is essentially unchanged & I added the 3.8 RSR wing this year which I would guess increased drag a little.
Same engine set up in terms of intake manifold and cams and compression.
Kokelin replaced with a custom Bell
Headers & turbo replaced as earlier in this string
0.7 bar for 2013
1.1 bar for 2012
Max oil temp that I notices for 2013 was 180 and last year 220F
And I am using less fuel.
Making the same useable power.
And no oil leaks - a successful investment!
I plan to add some lightness over the winter as the car is just under 3000 pounds today.
Dave
thomas682 11-19-2013 07:41 AM
over boost cylinder damage
Dave,
Were you able to salvage the cylinder that suffered over boost as shown in the photo above from 26 July? Did you buy a new set of P&C? Replate? Were they Mahle 98MM cylinders? I have a similar situation and am seeking all options from those who have already been down this path....
Midlife930 11-19-2013 09:41 AM
They are 98mm Nickies from LN Engineering. When I saw the damage I ordered a fresh set of pistons and cylinders from LN and later sent the damaged cylinder to them for repair. LN repaired the cylinder and set me up a full set of rings so I have an engine set of P&C's as spare for the next rebuild.
I would ask Charles if he can look after you,
Dave
930 ZZZ 11-19-2013 10:22 AM
Hi Dave,
Just wondering what type of wheels and tires you are running? dia, widths, profile, brand etc. Any issues when driving on the street/highway with the car tracking or darting around with different road surfaces?
Jim
Midlife930 11-19-2013 01:40 PM
Hi Jim,
CCW 17x9 6.25 BS and 17x11.5 7.25 BS with 255/40 and 315/35 BFG R1 ........ not very street legal.
The car feels great on the street apart from the stiffness of the set up with 24mm bars front and 33mm rear. The car is sitting on an Elephant package of bars shocks and bushings with a very careful alignment and corner balance. If I was going to run on the street more often I would go to NT-01's or maybe R1R's.
On the other hand my 89 Euro M5 darts around with 255's all around, but the suspension has not been setup, I don't even think the toe is correct. As I see it, with a proper set up the car will be solid.
Dave
930 ZZZ 11-19-2013 02:09 PM
PM Sent,
Jim
Pimpim 11-19-2013 02:38 PM
How big intercooler did you had when this happend to you engine??:/
philip j 11-19-2013 02:59 PM
Dave, we should get together next year when you head down this way. (Ottawa) I have your twin. Philiphttp://forums.pelicanparts.com/uploa...1384901974.jpg
Midlife930 11-19-2013 05:12 PM
It was a Kokelin, unshrouded as when I shrouded it my head temps went up too much. So I traded off head temps for slightly higher intake air temps. The big Kokelin seemed really good for short blasts but not for long straights when it soaked up. The larger and thinner Bell keeps the charge cool all the time and allows good flow to keep the heads cooler too!
And Philp I get to Calabogie a few times each season with Porsche and BMW clubs. The image above of me trying to put my helmet on is at Calabogie. Your car sounds more full blown than mine & would really like a taller second, but not quite enough to take it all apart.
Cheers,
Dave
Dave
guru944 11-19-2013 08:10 PM
Brian:
Nice. Great design and definitely different. Keep us posted how they perform ok.
Later...
DohertyCM 11-22-2013 07:16 PM
Post a picture of the intercooler....where did you get it and how much was it....was it a direct replacement?
Midlife930 11-25-2013 04:47 AM
Hi,
Not sure why I can't find a shot of the intercooler installed but here's a cell image in the kitchen. I sent my Kokelin to Bell with a sketch or two and they built a bolt in. All arranged by Todd at Turbocharging Dynamics who I have worked with on BMW turbo systems for years. He spec's and supplied the turbo that is on Brian's header system.
Dave
http://forums.pelicanparts.com/uploa...1385383335.jpg
Midlife930 06-11-2014 04:44 AM
Pulling this old thread back up as I have finally had the opportunity to get the car on a dyno with Sasha Anis of On Point Dyno
OnPoint Dyno
Sasha is a great guy who knows tuning and is easy to work with.
I like the idea of a hub dyno much more than strapping the car to a roller. Easier on the equipment more accurate and less dangerous.
I have moved to a 0.9 bar spring set up which put me around 13 psi on Sasha's machine.
Dyno hubs on the car
http://forums.pelicanparts.com/uploa...1402486044.jpg
On the Dyno
http://forums.pelicanparts.com/uploa...1402486177.jpg
Sasha installed his Knock Ears to ensure no knock then took my tune of around 440 hp and 355 torque to 460 and 373. Apart from peak numbers he flattened and raised the torque curve through the entire power band and brought boost in sooner. For a track car that sees extended periods of full boost I am very happy with these power levels.
http://forums.pelicanparts.com/uploa...1402486688.jpg
http://forums.pelicanparts.com/uploa...1402486758.jpg
Then cooling her down
http://forums.pelicanparts.com/uploa...1402486825.jpg
Looking forward to Watkins Glen this weekend,
Dave
Tippy 06-11-2014 06:52 AM
That is some strong numbers for sub-1 bar of boost. Congrats!
3 questions:
1. What are the turbo specs
2. What RPM are you seeing full boost
3. Tuner trick to bring in boost sooner?
I've read debates between running lean or rich right at zero vacuum, but everyone seems to agree on a slight timing retard at the first onset of boost to lug the engine harder than normal to get it spooling.
Curious if the tuner made mention of his technique.
mnez 06-11-2014 07:16 AM
Nice write up Dave.
Midlife930 06-11-2014 07:40 AM
Thanks and thanks.
1. GT35R on a T3 with the largest A/R compressor housing available from Tial
2. The yellow line on the chart is boost, you can see the ramp and in by 4,000
3. Sasha lowered fuel as I was a bit rich and added a few degrees timing.
in his words, boost just came in quicker as the engine was happier.
He spent a lot of time at mid throttle mid power in the middle 300's getting the mixture right, then moved to full power pulls & then timing. You can see from the lap numbers he only did 6 full power pulls after all of the mid power work. The goal was on track power delivery for predictability not hero numbers. Hence,, the time spent below full power which of course you don't see in the chart.
Dave
Tippy 06-11-2014 08:26 AM
Oh yeah, WOT is very little tuning, most of the tuning is below WOT.
That is a big turbine, didn't realize Garrett's ran that big.
