GHL headers cracking
Well it looks like the heat cycles have finally had their way with my headers. I believe these are GHL's. Can these be repaired on the vehicle or do they need to come off? I think I know the answer, but...
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 03-19-2013, 07:01 PM
If it were me, to be safe, I'd remove. The last thing you need are loose welding "particles" flowing thru the turbo. This way you can run a chain of some sort thru the pipes to knock of potentially loose metal from the welding process....
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 03-20-2013, 12:38 PM
I've gone native
Tt surgeon's Avatar
Agree, time for a new set.
Old 03-20-2013, 01:05 PM
That happened to mine also. I took them off, cleaned them, and then repaired the cracks. It's a good idea to make sure there is no slag sitting in the headers after repair. That being said, it's best to take them off to repair.
Old 03-20-2013, 01:14 PM
exhaust
These are SS correct? Did you do the work or did you have someone do the work? I was wondering how you cleaned the carbon out of them on the inside?
Thanks,
John
Old 03-20-2013, 08:57 PM
John, Yes they are stainless. Cleaning was more prepping the cracks on the exterior by grinding. We did run them through the parts washer which did a decent job. My brother did the welding. After we ran a chain and cable through the headers to check for any debris. We also used an inspection scope to take a look around. This was a couple of years ago. They are working great. No more cracks.
Old 03-20-2013, 10:28 PM
Thanks kupcar.
Old 03-21-2013, 04:57 AM
