Another Head Studs Question
Hi.
I stripped down 930 engine from my hot rod project. It is a Saudi car and it was rebuild at one time with no expenses spared. Unfortunately due to a monster spring in a waste gate and hybrid turbo all cylinders had broken rings. Otherwise it is in nice shape. It has 3.4, 7.5 CR Yellowbird cylinders and pistons.
I am refreshing it as a spare. It will be run with Carrera manifold and Haltek EFI. I will probably limit the boost to 1 bar.
The engine has 993 fully threaded black head studs. The all look OK. They are suppose to be reusable. However there is a slight evidence of movement on cylinder to heads mating surface.
So my question to the turbo experts is: should I spring for Supertech or APR studs, or can I get away with reusing the 993 ones? It is only my spare engine and I am trying to build it on a budget.
Jerzy
Old 06-23-2013, 10:19 AM
