Advice/Comments - AFR above 12 by 5300rpm
Not sure what to check next?
I have my BLWUR enrichment adjusted to the point that it will not drop the CP any more. I got 1.6 bar @ 26*C.
I have checked the flow rates and got;
Entering Fuel dist. = 2200cc
Entering WUR = 473cc
System pressure = in spec (checked at mechanic)
Here is the data from this morning
Second gear
Third gear
Old 08-15-2013, 10:44 AM
Straight shooter
Lapkritis's Avatar
Fuel pump tired or low voltage at the pump...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 08-15-2013, 10:58 AM
9Thirty's Avatar
Are you sure you don't mean 4300 rpm?
Old 08-15-2013, 11:57 AM
Red dotted line on the graph is AFR=12. Maybe I am missing something, what are you seeing?
Thanks,
Old 08-15-2013, 01:09 PM
9Thirty's Avatar
Thanks,
I was looking at the numbers at the bottom of the graph that appear to be a guide for the rpms. They are listed in 200 rpm intervals. The gold line appeared to be the AFRs. So it appears to me that it hit 12 AFR at 4000 rpm in second gear and 12 AFR at 3000 rpm in third gear. It is hard to read the numbers on the left side of the page vertically. Is that where the rpm numbers are listed for reference?
Old 08-15-2013, 05:54 PM
Turbofrog
smurfbus's Avatar
X-axis is time! Read the little boxes.
Fuel pump checks (possibly swap to bigger pumps), 7 bar system pressure and if not enough a split second controller for the WUR like Thierry did. First I would check the flow at the injectors and make sure its close to even when metering plate is fully pressed.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-15-2013, 08:55 PM
Thanks for the tips. I will confirm fuel pump voltages and system pressure. I still need to check the injector flow, this has been on my list for too long.
Old 08-16-2013, 05:47 AM
Straight shooter
Lapkritis's Avatar
The pressure only needs to drop a little when under loads. This can be due to a pump showing wear; it will hold pressure fine at idle but not as flow increases with engine loads. A fuel pump controller that ramps voltage up (Mallory or msd makes one) with a boost signal input is a nice tool to get the most from your existing system and future upgrades.
Old 08-16-2013, 06:07 AM
Straight shooter
Lapkritis's Avatar
Here it is:
http://www.msdignition.com/Products/Accessories/Fuel_Acc_/2351_-_Programmable_Fuel_Pump_Voltage_Booster.aspx
This is one of the secrets to matching fueling with increased boost. Worth every penny if you want to go faster just make sure you have a good healthy pump first.
Old 08-16-2013, 06:14 AM
I didnt think that boosting the fuel voltage in relation to boost work with CIS system.
Old 08-19-2013, 08:16 AM
I checked the system pressure and found it to be in spec for my fuel head, 6.2bar. I increased it to 6.6 bar and reset the WUR and still have the same results of going lean at 5300 rpm.
Fuel pumps are working correctly. I verified the voltage at the front pump and is only dropping 0.25v vs the battery.
Now what??
thx.
Old 09-06-2013, 12:12 PM
Straight shooter
Lapkritis's Avatar
A tired pump is my bet. It simply won't flow enough at the top end even with adequate voltage.
Old 09-06-2013, 12:34 PM
Crotchety Old Bastard
RarlyL8's Avatar
I don't see what your engine mods are. The stock spec head will support about 375WHP.
At ~97psi you should have plenty of pressure to sustain the AFRs. I cannot read your graph well so unable to see if a hint is there.
If a pump is weak idle and cruise will be rich and on-boost lean. Curve tuning will be difficult.
Please list your mods as that is a go-no go gage.
Old 09-06-2013, 06:03 PM
If you click on my user name and then my garage you will find all the specs and mods on my car.
Thanks for the advice so far guys.
Old 09-07-2013, 08:22 AM
RarlyL8's Avatar
At 0.8bar the mods should put you around the 375whp threshold where more fuel is needed.
Can you estimate peak whp from the data you have?
Old 09-07-2013, 11:13 AM
I haven't taken it to redline due to the fueling. Once I hit AFR of 12 I lift.
I calculated whp to be 290 but that is including rolling and wind resistance and a estimated weight.
Old 09-07-2013, 02:20 PM
RarlyL8's Avatar
290whp would be very weak for those mods. At 1bar you should be at 400whp.
The GT35 family supports as much or more than a K27/29.
Redline is past peak HP most likely.
AFR of 12.0 is not lean. I don't like to go above 12.2 however spikes above that are tolerated if not chronic and the engine is not running hot. I suspect there are a lot of 930s out there running 13 and don't even know it. Smart move on your part to verify and protect your new engine.
Old 09-07-2013, 03:45 PM
OK, so I checked the voltage at the rear pump and its low, 1.5v less than the battery or 1.0v less than the front pump.
I dont know if this would cause what I am experiencing with the AFR leaning out to fast since its the return pump. Or is this my problem??
Old 09-09-2013, 05:14 AM
Smart quod bastardus
fredmeister's Avatar
You have to remember that you have alot more wire length to get back to the rear pump so its gonna see more voltage drop from more resistance than the front pumps readings.
I think I saw roughly a 0.5 to 1 volt difference between the front pump and the rear on mine when I measured it as well.
Did you make sure to measure it with the car running and after a minute or 2 so the pumps could be up to running temperature and loads?
The rear pump is not a return pump its actually a second pump in series with the first one to boost pressure and flow. I think its more critical to have a good front pump since it supplies the input to the rear pump so when I changed out one of my fuel pumps to the Bosch 044 unit I installed it on the front and left the rear stock.
Not to be picky but I reread your initial post and am not sure you measured flow rates correctly. Going from memory I think the owners manual says to measure flow on the return line back to the tank with both the pumps running. Then you can also isolate each pump and take pressure readings to see which one is failing. This might help you figure out if a pump is not up to spec....good luck.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-09-2013, 09:56 AM
I did let it run for maybe 5 min. before checking.
Thank you for the tips and clarification on the rear pump.
So, I am down to the fuel head rebuild for more flow or a new front pump.
Thoughts?
Old 09-09-2013, 10:06 AM
