T77911S's Avatar
i need a WUR
anyone have a WUR forsale? a 153 would be nice. a BL one would be even better.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2013, 04:55 AM
thumbdoctor's Avatar
Contact Tony Boyt911SC , he may have what you need.
Porsche, aucune comparaison
Old 09-26-2013, 05:24 AM
At the risk of sounding stupid...
What, is a "WUR"?
Old 09-26-2013, 06:18 AM
ahenthus's Avatar
Warm Up Regulator.
Old 09-26-2013, 08:01 AM
Also called a control pressure regulator because thats what it does.
Old 09-26-2013, 06:05 PM
T77911S's Avatar
thats funny, BOSCH calls it a warm up regulator. i think its best to stick to that name as most call it a WUR, so why confuse people.
plus, i dont think it is much of a regulator. a true regulator maintains a constant output for a varying input. i would be currious to see if a WUR could maintain 3.5 bar with 4 bar input and 6bar input.
RACE CAR:: sold
Old 09-26-2013, 11:40 PM
Crotchety Old Bastard
RarlyL8's Avatar
The function is control pressure regulation; warm up is only one part of that function, along with cold, cruise/idle, and boost.
It is a bit odd that they call it a WUR instead of CPR.
Old 09-27-2013, 05:11 AM
T77911S's Avatar
but how well does it "regulate"?
if you change the system pressure, does the control pressure change with it?
i thought the lack of regulation was the reason you calibrate the WUR to the FD it will be used it due to the slight variations between system pressure of FD's
RACE CAR:: sold
Old 09-27-2013, 06:29 PM
RarlyL8's Avatar
The regulation points and warm up curve are static via electrical, heat, and vacuum/boost input. Yes the entire range is affected by system pressure input. The regulation that occurs is the change in control pressure during cold (low) warm up (low to high), warm (high) and boost (low). The specifications of these pressure ranges can be changed via the adjustment mod or statically to accommodate increased fuel needed beyond the stock settings.
Old 09-28-2013, 07:34 AM
Ty, Why are you looking for a WUR, I thought BrianB was rebuilding your WUR?
I sent mine directly to BrianL....took two weeks.
tim
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-28-2013, 08:34 PM
RarlyL8's Avatar
BL is no longer building them. He is finishing up a few we had in the pipeline but it is taking longer than anticipated.
Old 09-28-2013, 09:54 PM
I just purchased a rebuild WUR from SpecialTauto.com in Texas. I sent them my core and the charge was $370. 2 year warranty. I haven't installed it yet
Old 09-29-2013, 06:11 PM
RarlyL8's Avatar
Rebuilding is not the problem, it is modification. I haven't done the machining in years and an I'm no longer set up for it.
Old 09-29-2013, 07:07 PM
