ruf speedline classics, fitment?
Hey guys, would these wheels 8×17 and 10×17 be a direct fitment on my 86 930? Or will I need spacers?
Thx
Old 11-06-2013, 01:21 PM
I've gone native
Tt surgeon's Avatar
Regular 930 yes, factory slant no.
Old 11-06-2013, 01:35 PM
I did some searches and there seems to be many different thouhts on this. Especially the rears needing 15mm spacers. My car is a regular 930
Tx
Old 11-06-2013, 01:43 PM
speednme1's Avatar
Yes your car will need them (rear)15mm...if you can get 17x9 for the fronts it will fill the front much better.
Rey....77 930 "the Mistress"
Old 11-06-2013, 02:14 PM
Driver
Noah930's Avatar
What's the offset of those Ruf wheels? Stock was 15 mm on the Fuchs.
Also, the stock set-up already has 28 mm spacers on the rear (under those Fuchs) for later 930s. So if you find that people say they are running 15 mm spacers with the Rufs, see if that's 15 + 28, or just 15 alone. I suppose you could just put on the wheels and see what they look like and if there are any clearance issues. If so, then buy a pair of 15 mm spacers (or 43 mm spacers).
1990 Black 964 C2 Targa
Old 11-06-2013, 02:16 PM
My fronts are 8×17. Will this fit without spacers? Sorry wheel fitments have always confused me.
Old 11-06-2013, 03:15 PM
Driver
Noah930's Avatar
I'm running 9x17 on the front, so an 8" wide wheel can fit. But the offset has to be close to the stock 23 mm otherwise the wheel won't sit properly (too far inboard or too far outboard).
Old 11-07-2013, 08:22 PM
twin plugged targa's Avatar
I have RUF speedlines on my 930 9"and 10"
I do think the 9"s are a bit large on the front and would have preferred 8"s .
Don't 930's come with spacers as standard with Fuchs?
My car has spacers and can I measure them tomorrow if it is any help?
PM me if I can help?
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 11-09-2013, 11:01 AM
I have 9 and 10 Speedline for Ruf on my turbo club sport as well,
as per Ruf Tuv certificate the rear should ideally fit on 15mm spacers,
I used the 21mm to maximize rear track, the fitment is very tight with both the tire
brand I use (Toyo R888 and Michelin PS)
I tried unsuccessfully to upload a photo
Simone
Old 11-10-2013, 12:35 PM
930/66's Avatar
I have 9-inch rims on the front axle without spacers
At the rear I have 10 "rims with 28mm spacers
With the original Fuchs wheels were until 1980
Front 21mm spacers
Rear axle 28mm spacers
From Year 1981 28mm spacers were only mounted on the rear axle
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 11-11-2013, 09:16 AM
Front spacers
Here's a pic of 9s on front. They fill out the wheel arch pretty fully. Mine ('85) does not use spacers in front. 15mm in the rear on the 10s--as others have mentioned.
Jon
'85 930
Old 11-11-2013, 03:27 PM
speednme1's Avatar
9 and 10's on mine
Old 11-11-2013, 05:08 PM
