Alternator problem , so I thought
first my warning light was glowing very deem , so replaced the voltage reg, no change, so i replaced the alternator, no change , then my battery went to hell, so I thought the Bosch alternator was bad, so ordered a replacement, same thing, then i checked the diode at the warning light, nothing, sometimes it charges sometimes it doesn't. whats going on here,
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 02-27-2014, 01:44 PM
pete3799's Avatar
Have you had the battery load tested?
Pete
79 911SC RoW
Old 02-27-2014, 01:50 PM
Check your chassis grounds at the battery and the engine.
Old 02-27-2014, 01:53 PM
I have checked all the grounds at the chassis up front and rear and engine and got .000 ohms , I also checked for drainage and got 0. and I just put a NEW battery again to make sure, Autozone was great, free replacement
1992 964 C2 turbo
Old 02-27-2014, 02:02 PM
Have you checked the starter connections?
Old 02-27-2014, 02:14 PM
speednme1's Avatar
Diode went/ going bad..had a similar issue years ago...diodes are really cheap..install a new one...here is a link that should help you http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/769047-alternator-warning-light-diode.html
Rey....77 930 "the Mistress"
Old 02-27-2014, 02:39 PM
mark houghton's Avatar
Two alternators, one voltage regulator, two batteries, a veritable mint in replacement parts. Wouldn't that just about frost your ass if it was just a cheapo diode doing the sporadic funky chicken? Weird, though, usually electronic type things give up the ghost only once and they're done.
You said you checked the diode....how? Ohm meter, looking for continuity one way and none when the polarity is reversed?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-27-2014, 03:09 PM
After all that, I wiggled the starter cables and they were lose, and the warning light went out, ahha problem solved. and she running alot better to boot.
1992 964 C2 turbo
Old 02-27-2014, 03:52 PM
Asked me how I knew it. Lessons learned... be glad it didn't cook the engine harness.
Enjoy it!
Old 02-28-2014, 05:30 AM
Forced Induction Junkie
WERK I's Avatar
heliolps2, you might want to have the charging circuit tested just to make sure nothing was damaged on the alternator when it was running with an intermittent open circuit between itself and the battery.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-28-2014, 06:26 AM
WERK I, how would i go about testing the charging circuit ?
1992 964 C2 turbo
Old 03-01-2014, 11:42 AM
WERK I's Avatar
Some auto parts stores (AutoZone, O'Reilley, etc.) offer to test the charging system of the car. All the unit does is put various loads on the circuit and checks to see if the alternator responds appropriately.
Dave
Old 03-01-2014, 04:04 PM
