rear coil over supports
"This Year ferrari's Ass is Mine" |
duct tail coming along
some more today
Surprisingly easy, I got the rear suspension bits off, 935 here we come.
Some more progress today!
7.0:1 > 11.3:1 > 7.0:1
Your work looks great. Question, what the heck are doing to that engine shroud?
edit: I built a similar splitter on my old 930 and picked up on the outer most front torsion bar mount bolts. The bolts are canted at a bit of an angle as you noticed while doing your pan rebuild, but a couple bushings and longer bolts took care of this. Last edited by Jim2; 08-24-2014 at 08:30 PM.. |
Thank you Jim
The rear oil cooler is replaced with 993 oil console/filter. So we are flattening it out, the duct isn't needed.
Jim that's a good idea.
I might add a flat stainless steel tow hook/ring off of those front suspension bolts too.
knocking down the mold lines etc.
steering damper
Looking good!
I took the easy way out and got the non-oil cooler shroud from Damon Josz @ Series 900. While you have the steering rack out, pull off the pinion gear cover and check the grease. Mine was hard as a rock, so it was time for a disassemble, clean and re-grease.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
welding
Welding done today!
More today. Alloy block offs and getting ready paint
Shroud mods
Nice. This post I must follow
930 1979 951 1986 951 upgraded 1987 |
thank you, Primed and ready for seam sealer.
Time to tear into the rack and 993 console with alloy block off.
More cleaning today.
Some more progress today, cross brace PU points, 4" air filter hole.
