Tinkering Pays!!
mooney265's Avatar
Blinker is Blinking 5X per Second?
Recently, my left and right blinker have begun to blink at a very high rate [including the hazards]. I notice all of my bulbs are working, but the blinking is at high rate.
It seems this happened in the past and was due to a bulb not being in good contact in the socket. That all seems fine, now...
Should I be looking at the blinker relay? Grounding Issue? Thanks guys!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-16-2014, 07:26 AM
Chain fence eating turbo
Once all contacts and bulbs are good with clean contacts, the flasher could be dying.
It's behind the brake booster IIRC.
Old 09-16-2014, 08:31 AM
Tinkering Pays!!
mooney265's Avatar
i'll look at the p/n of the flasher and get another. thanks!
Old 09-16-2014, 08:46 AM
Bad light bulb/contact.
Old 09-16-2014, 08:49 AM
Tinkering Pays!!
mooney265's Avatar
I'm now thinking it may have to do with the LED's in installed some months back. The quick flashing wasn't a problem back then, but now it is...
I purchased a specialized relay for LED installs. I'll post back when I get it installed.
Thanks!
Old 09-16-2014, 09:50 AM
^^^oh, well...
Old 09-16-2014, 11:01 AM
dos531's Avatar
Thanks!
Definitely the LEDs. Need to install a resistor.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 09-16-2014, 01:20 PM
Tinkering Pays!!
mooney265's Avatar
I installed an LED relay and everything works perfectly, now.
Sent from my iPhone using Tapatalk.
Old 09-19-2014, 07:30 PM
