-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Thanks Cole/ Cole Air Intake (http://forums.pelicanparts.com/showthread.php?t=831131)
tadman 09-23-2014 07:34 PM
http://forums.pelicanparts.com/uploa...1411525669.jpghttp://forums.pelicanparts.com/uploa...1411525745.jpghttp://forums.pelicanparts.com/uploa...1411525877.jpghttp://forums.pelicanparts.com/uploa...1411525984.jpg
Miguel Antonett 09-24-2014 07:46 AM
Prrrrrreeeeeettycool!
So, you believe on that inverted cone function, what is it about it?
quattrorunner 09-24-2014 10:48 AM
Wait, what?
Tippy 09-24-2014 11:31 AM
What's it sound like?
JFairman 09-24-2014 12:33 PM
Looks like it's supposed to help spread the incoming airflow out a little so it flows over the edges of the round sensor plate better. Maybe it works maybe it makes no difference. I wonder if anyone ever did a dyno test with it and without it... I doubt it.
If you put a round K&N air cleaner on the air flow meter housing then air is coming in from 360 degrees all the way around. Seems like that would be best in all respects.
Miguel Antonett 09-25-2014 07:25 AM
^^^I'm with you, but there is another trend of thoughts as you mentioned... and Tadman definitely believes it. Regardless, it makes you wonder why Porsche put it there to start with. I did some testing a while back with the round K&N vs. OEM = no significant difference in power or torque but liked the free access and sound of the K&N.
wjfk32 09-25-2014 07:36 AM
WHOA............... :)
luv the fuel lines setup!!!!
Walt
voitureltd 09-25-2014 08:13 AM
Yes we did a dyno tune with a aftermarket air cleaner housing which was on the car when I got it.. My shop wanted me to go back to a stock air cleaner as they felt the cone was important with CIS. It did improve the HP . It has been quite awhile but I think it was around 6 hp.
I think Porsche always has reason for what they put into a build.
Ronnie's.930 09-25-2014 08:42 AM
Like the choosing to use Dilivar head studs, and even continuing to use them for many years after it became clear that they were garbage? :D
Tippy 09-25-2014 08:55 AM
The 993TT Dilavars are great. But yes, the IMS bearing in the M96 996/997 engines were a disaster!!!
cole930 09-25-2014 09:12 AM
Gents:
Just a little background on this addition to Tadman's great build.
The cold air intake was a gracious contribution to the Old Sled build
donated by RSRFAN. He originally planned on using it on his RSR build.
The cold air intake was off an old 935 bodied 930 race car and when
RSRFAN decided not to use it he sent it to me.
I could not use the cold air intake because I decided to relocated
my CIS to the right rear of the engine compartment (ala 934) in an effort
to see if there were any advantages to a shorter intake track. My intake
track from the metering plate to the turbo inlet measures about 9" of 3"
tubing. Turbo spool up is nearly instantaneous.
Tadman contacted me looking for a cold air intake for his track car.
This allows him to feed cool air from 1/4 window to the dual air inlets on
the cold air hat. When Tadman contacted me I sent the hat to him.
No dyno, no R&D, no complicated science, just old school throw it
on and see if it makes a difference.
Cole
http://forums.pelicanparts.com/uploa...1411661406.jpg
voitureltd 09-25-2014 09:14 AM
Many reasons stock as built may not always be better than upgraded ones ( early dilavar studs, early chain tensioners, rubber clutch etc). Porsche was on a learning curve especially with new performance models, even to this day. Changes with subcontractors can be a problem. Just ask me, I worked in warranty administration ( not for Porsche) for almost a decade.
quattrorunner 09-25-2014 09:25 AM
Whatever, it's cool and doesn't hurt.
I'm more moved by the pay it forward attitude I see on this forum.
I've been at the recieving end a couple times and once it was also from rsrfan. Good dude.
Lots of good guys here even with silicone and jb weld asside.
rsrfan 09-25-2014 01:30 PM
Cole, I love you man. You are way too gracious. Glad to see the intake being put to good use. Tadman, the car is an inspiration. Truly beautiful work...
And thanks Brandon. Right back at you!
tadman 09-25-2014 07:47 PM
Cole, Rsrfan thanks again for air intake, passing it forward as you both did. There truly are some special folks and good natures to go around this group. Its funny with all the parts on my car that air intake now has special meaning, makes me :)
The Cone.......................................
http://forums.pelicanparts.com/uploa...1411696201.jpg
So any of you who had a stock 930 intake had one of these. I did ad one to the intake at the same location above the mixture bowl and sensor plate. It was not because I think it adds horsepower and if it does its probably minimal. Now I am guessing like everybody else but I think Porsche engineers put the cones in the intakes and later cone shape sensor plates in the mixture bowls of 934's because the cone somehow helps stabilize and balance AFR's.
As for the the air intake, just wanted cooler outside air feed to the turbo.
