A few shots of the oil return sump plate I've been working on. Both sides are tapped at 22mmx1.5. -10an to 22mm adapter for the oil line and a 22mm magnetic drain plug on the other side. It's 1.200" thick at the center.http://forums.pelicanparts.com/uploa...1416433188.jpg
http://forums.pelicanparts.com/uploa...1416433201.jpg |
I love that idea! That looks great too.
Looks great. Am interested. Need one.
Very nice!
I just reviewed this thread and understood your installation, but not sure where/how exactly the pump drains into the chain cover. Did you have to modify the cover? How is that working out for you? I think it would be great to bypass a catch can. QUESTION: If the electric pump should fail, would there still be gravity feed through the pump to the sump? |
I plan on making a couple more of these next week (without the black grooves). This Mishimoto an10 to 20mm banjo fitting may be another alternative for the oil line return.http://forums.pelicanparts.com/uploa...1416494406.jpg
Its easy to do. Take the chain cover off, drill hole... have a -8 fitting welded in... wallah!!!! Then, I had a -8 fitting welded into the other side of the catch can... connected the two with a AN line.. You can see it in this picture here. It is way below the bottom of the turbo, but it doesn't look that way in the picture [IMG]https://farm7.staticflickr.com/6047/...b80a79c9_z.jpgIMG_0147 by turbobrat930, on Flickr[/IMG]. |
What kind of catch can is that (I assume it's the black beer can looking item in the pic?)? Thanks. |
Neat. Gravity feed is back up in case of pump failure! No wonder you never get oil past the turbo seals due to back pressure. |
[QUOTE=gumba;8361990]I plan on making a couple more of these next week (without the black grooves). This Mishimoto an10 to 20mm banjo fitting may be another alternative for the oil line return.QUOTE]
Gumba, Are you making these for purchase? If so, what's the price? Thanks. |
I am today working on quantifying the rates of oil flow through the turbo and pump. I have previously measured the flow into the turbo to be approximately 0.28 gal/min. With this flow rate, and the pump running, I send a lot of oil past the turbine bearings. I have had a valve on the feed line in the past, but It's a PITA, so I want to establish a fixed orifice flow IAW Borg Warner's recommendations.
I am going out now to try and quantify the flow through the pump, via 3/8" ID hose on barb fittings (pump inlet and outlet are 3/8 FPT). My pump is supposed to flow WAY more than it seems to. BTW, the gravity drain is non-existent. I tried it once to the sump plate, didn't work well. This is a big problem when you don't have the factory 930 oil return system. |
I didn't want to totally hijack this thread...
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/839460-turbo-oil-return-non-930-specific.html#post8362319 |
Harold, that's an awesome bit work work you've done there.
I would be interested too. I got the new sump plate back today with the AN-8 welded on. http://forums.pelicanparts.com/uploa...1416508654.jpg Compared to the first sump plate, TIG is certainly alot neater than MIG : http://forums.pelicanparts.com/uploa...1416508702.jpg All being well I should get the new plate on, on Saturday, plus get a few other jobs done like change gearbox oil and fit turbo mount. |
| All times are GMT -8. The time now is 04:13 AM. |
