Need advice on strut inserts for '78 930/Boge struts.
I believe my '78 930 has Boge Struts (pictured). In my limited research it seems the only option for direct replacement are Boge Inserts? How are these for spirited street driving? Is there a Bilstein option that will play nice in the Boge strut housing? I don't mind paying for something decent but not looking to go full race etc. Would like to keep cost around or under $200/side. Looking to stay within the same budget for replacement rear shocks... anyone have opinions here? Looks like Bilstein has a direct replacement (Part #46169).
Looking to replace front strut inserts and rear shocks along with lowering the car and a fresh alignment in the next few weeks in anticipation of the nice weather! Thanks in advance! ![]()
In doing some research it seems Bilstein P36112 should work, can anyone confirm?
If they are Boge, then Koni adjustable sport inserts will work if still available. These have a single adjustment valve at the top of the shock. There is also a matching adjustable sport shock for the rear. They are painted yellow. This is what I have on my turbo. I modified a set of Boge struts from a 911SC by cutting the strut below the spindle and adding a section of pipe to raise the spindle and then cut out section at the top and re-welded the top section back together keeping the total length the same.
Did some checking, loos like they are still available, 8641-1039Sport (F) and 8210-1159Sport (R).
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R |
Hello Patrick,
There is a whole article about shocks & inserts via a pelican article. Simply search on Pelican Technical Articles "shock replacement". Boge struts accept a variety of different brand inserts in various levels of performance. You will find all the info you need there. Mark |
Well, after doing some more research I have settled on the following part numbers.
Bilstein Sport Front Strut Inserts for 930 w/Boge - P36113 Bilstein Sport Rear Shocks for 930 w/Boge - B46975 Hopefully this helps anyone who finds themselves in a similar situation moving forward! |
Hello Patrick,
You should find those pretty good for a casual upgrade over the stock stuff. The sports tend to be a little bit harsh over mild, slow speed bumps, but improve as speed increases. Mark |
Patrick,
Just to clarify, the Koni sport inserts do not require any modification to install in a Boge strut. I modified my struts in order to raise the spindles to lower the car. I think you will be happy with the Bilstein inserts.
![]() Ah, thank you for the clarification Dennis - sorry for my confusion! I don't have anything against the Konis, I actually have them on my 951... for some reason Bilstein was just calling my name on this car. I really appreciate your feedback! |
