3LDZ turbo technical question
Do not respond if you feel the need to inform me that I should just send this turbo out for rebuild..
I am taking the turbo apart and it seems like the journal bearing is stuck to the turbine shaft. I assumed that this would be a slip fit as on other turbos I have worked on. The vent line from the turbo oil sump was cracked, so there could be corrosion holding the bearing on the shaft. I have cleaned it with Ultrasonic and now it is soaking in Evapo-Rust.
So is the bearing a press fit or slip fit on the shaft?
Old 05-22-2015, 04:49 AM
Old 05-22-2015, 04:53 AM
Definitely a slip fit. The shaft and bearing are carboned up. get it apart and polish the shaft and see how it looks.
Old 05-22-2015, 05:07 AM
Thanks, that's what I suspected. I got a lot of carbon off with the ultrasonic cleaner, that picture is before cleaning. I will let it soak in the Evapo-Rust for a few days and then see how it feels.
Old 05-22-2015, 05:23 AM
Try some carb cleaner, that will work better for carbon.
Old 05-22-2015, 05:39 AM
Try WD-40 first, works great for cutting through gunk.
Old 05-22-2015, 05:52 AM
IMR-Merlin's Avatar
maybe a little heat also. put the part in an oven and use some penetrating oil on it.
Old 05-22-2015, 06:06 AM
Already did carb cleaner, WD40 and PB Blaster. I am trying least aggressive methods first. Like I said before, at this point I suspect a tiny bit of corrosion between the bearing and the turbo shaft, if this is the case, time and the 5 gal bucket of Evapo-Rust will get rid of the corrosion.
Old 05-22-2015, 06:18 AM
IMR-Merlin's Avatar
Think it ran dry and friction welded to the shaft?
Old 05-22-2015, 08:09 AM
Put it in the oven at 350 for 30 minutes and it came right off. The shaft looks fine, must have been some old oil holding it on.
Old 05-22-2015, 06:17 PM
3 restos WIP = psycho
kenikh's Avatar
Give the shaft a few taps with the soft blow hammer. It works.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-22-2015, 09:18 PM
IMR-Merlin's Avatar
ha. a broken clock is right twice a day!! LOL
Old 05-22-2015, 09:49 PM
Banned
Originally Posted by kenikh View Post
Give (yer) shaft a few taps with the soft blow hammer. It works.
Old 05-22-2015, 09:52 PM
