b930's Avatar
Cheers, I may have been a bit premature in observing slower boost onset as I had a persistent problem with a hose blowing off. It's sorted now but can't run it till back home from Thailand. Still trying to work out the real women from the lady boys...not as easy as I thought😁
Don't think I would go back to a 0.82 hot side after feeling the engine pull at red line with the twin scroll big housing, it's just too good...feels manic. I thrash it whenever I drive it as its a weekender only so I have no problem with the trade off, feels like a much torquier motor all round anyway with higher comp and twin plugs so even though boost is a bit lower, it still tractors very nicely at low engine speeds.
Brian, thought I had the 42mm headers??? When I ran them on stock heads I had to open the ports up and I'm pretty sure they measured 42mm but I'll measure them when I'm back home. Beautiful things those headers👍
Old 03-07-2016, 01:50 AM
b930's Avatar
Motor is very zippy and fast to rev with no load as can be seen, feels super sharp. Not that that means too much to the way the car actually drives but it gives some idea how responsive a worked 930 can be, some improvement down to light clutch but most to light rods and pistons. Would make some of my NA cars blush.
http://youtu.be/xoA2PrE0SgM
Old 03-07-2016, 02:12 AM
b930's Avatar
Originally Posted by philip j View Post
would love to see your timing map! Philip
Here it is.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 03-29-2016, 11:10 PM
What muffler are you running, it sounds good but not too loud?
Old 03-30-2016, 05:38 AM
b930's Avatar
Its a 3" dynomax, 3" in at top left and dual 3" out either side at the bottom. Its full 3" internal (basically like a 'Y' on its side). Home fabricated, sounds great.
Old 03-30-2016, 04:42 PM
