-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Winter engine rebuild project (http://forums.pelicanparts.com/showthread.php?t=868939)
b930 06-08-2015 06:05 AM
Getting a bit cold in Australia so I thought I would go about the next stage of motor upgrades. I have a nice set of 3.2 heads twin plugged with Turbokraft performance valve and spring package fitted. Also got 964 cams, and a nice carrera manifold and full bay intercooler bought from a fellow pelicanite as shown below (not my engine).
http://forums.pelicanparts.com/uploa...1433767754.jpg
Dropped the motor and started tearing it down last weekend
http://forums.pelicanparts.com/uploa...1433768500.jpg
http://forums.pelicanparts.com/uploa...1433767905.jpg
Other items per my sig, will use the existing GT30 twin scroll and twin gated rarlyl8 headers. I'll be running coil on plug for all 12 plugs off 4-three channel igniters.
One thing I need to decide on is P&C's. I'm thinking 102mm machine in cylinders with 8.0:1 CR Pistons for a 3.65L, but can't find any stock!!
For rods I an thinking stock with ARP fasteners and keeping red line 6500. Head studs also ARP. Will be interesting to see what this set up puts out......
I'll snap some more pics as I go.
boosted79 06-08-2015 10:04 AM
What COP's are you using? I'm planning a similar build but staying with 3.4L, I'm considering COP but not sure it's worth the extra expense.
Tippy 06-08-2015 10:24 AM
You will be WAY out of breath with the GT30. You will have some serious flow. I'd get a GT35 or 40. Also, you'll need 1 5/8" headers for the Carrera heads.
b930 06-08-2015 04:12 PM
Hi, I'm using denso dumb coil sticks from a 600cc bike. I also use these in a cosworth powered mk1 escort and they work great.
http://forums.pelicanparts.com/uploa...1433804984.jpg
Also I have 1-5/8" headers already. I hear what you are saying on the turbo, but I have the GT3582R with 1.07A/R housing and not the GT30. I reckon it will get me a decent 600-650 hp. I plan on getting a Borg Warner EFR maybe next year.
http://forums.pelicanparts.com/uploa...1433805127.jpg
Cheers.
Tippy 06-08-2015 07:16 PM
You're totally set then. I HAVE to hear your boost onset (RPM to hit 1 bar in 4th) numbers when complete.
That thing is gonna be sick! GL.
b930 06-08-2015 07:51 PM
Cheers, yep it should be totally nuts. This is what the boost onset is like already with the current set up (std P&C and heads, SC Cams, twin scroll GT35).
0.5 bar at 2200 rpm
1 bar at 2900 rpm
1.2 bar at 3000 rpm
http://youtu.be/NhHYF3mlU4o
Tippy 06-09-2015 07:12 PM
0.5 bar at 2200 rpm
1 bar at 2900 rpm
1.2 bar at 3000 rpm
Nice! Please report back when done. :)
b930 06-14-2015 02:56 AM
Motor all stripped to the block
http://forums.pelicanparts.com/uploa...1434275487.jpg
http://forums.pelicanparts.com/uploa...1434275596.jpg
Interesting to note the difference between the 930 heads and 3.2 heads on the port size.
http://forums.pelicanparts.com/uploa...1434275654.jpg
Big valve twin plug 3.2 head on right.
http://forums.pelicanparts.com/uploa...1434275720.jpg
Tippy 06-14-2015 06:24 AM
^ why every 930 owner should be running these heads!
Couldn't believe folks here were hung up on, "oh, the casting is better on the 930 heads". So what? Mine have been running over a decade over 1 bar without cracking or fatigue.
Nice photos!
IMR-Merlin 06-14-2015 06:30 AM
What are you using for engine management? I would love to go this route and get rid of my electromotive coil packs with associated plug wires. Looks like a much cleaner install!!
Cheers.
boosted79 06-14-2015 07:47 AM
"What are you using for engine management? I would love to go this route and get rid of my electromotive coil packs with associated plug wires. Looks like a much cleaner install!!"
x2
b930 - what specific 600cc bike are those sticks from? Merlin, Clewett has a TEC3r kit for the 996 that uses COP so it can be done, probably just a matter of getting the right harness and programming the TEC for one coil per plug? It sure cleans it up.
b930 06-14-2015 06:32 PM
Hi,
I use a Performance Electronics PE3 ECU. It runs full sequential ignition, and has 6 logic level ignition outputs. It does have 4 ignition drivers in it so I can run wasted spark right out of the box (direct wire dumb coils) but I wanted full sequential, so use 6 logic level outputs and a pair of Bosch 3 channel igniters. The Bosch igniters run the denso coil sticks.
One thing I need to experiment with twin plus is running another pair of bosh 3channel igniters for the lower plugs. I think I can just wire the second pair of igniters inputs in parallel off the 6 logic level outputs of the ECU.
I have to run a pull up resister on the 6 logic level outputs as it is, so maybe at worst, I may have to adjust the value of the pull up. Anyone know if this will work?
PE3 is a great unit by the way, very cost effective, made in the USA and very easy to tune. Both my 930 and my old 73 Cosworth powered Escort start and run like modern cars with no hiccups at all.
The short Denso coil sticks are from 600cc bike, fireblade I think. There are a bunch of bikes using the short sticks which suit the 930 better such as a Triumph Daytona 600. Long sticks from 1000cc bikes work as well (I have used them before) but stick out a bit too much for my liking.
Cheers.
krasuskyp 06-14-2015 06:47 PM
Originally Posted by b930 (Post 8667625)
...and my old 73 Cosworth powered Escort ...
*ballar*
pics, yes!?
great pics, love the big ports / valves
sounds like it's going to be a killer build, I'd love to run something like that. No, wait - stock is moar betterer :D
b930 06-14-2015 08:41 PM
Ballar indeed, pics :-)
YB motor, T5 box, BW78 axle w/ LSD, big brakes, etc (too much to to go off track on this thread!).
940kg fuelled, screwing the nuts out of the T3 at around 26psi midrange, with a big intercooler, big injectors, PE3 ECU sees around 350 hp, and around 380lb.ft. With only only 940kgs to move it flies! Tempted to run a bigger turbo but just love the punchy T3.
http://forums.pelicanparts.com/uploa...1434339557.jpg
http://forums.pelicanparts.com/uploa...1434339588.jpg
I think its the only street legal (fully engineering) cosworth powered mk1 in Western Australia and one of very few in Australia.
b930 06-14-2015 09:11 PM
http://forums.pelicanparts.com/uploa...1434341489.jpg
IMR-Merlin 06-15-2015 05:24 AM
x2
looks like I'll be building a new harness this winter. :D
boosted79 06-15-2015 06:23 AM
That is one nice car, you do great work. I don't understand why Ford didn't bring them into the states. I looked at the PE3 site, very interesting. Not crazy about the crank wheel though, only 12-1 pattern vs 60-2 for the Electromotive. But you can't argue with success. Looking forward to your build. Those sticks are on ebay for $30 used for four, way way cheaper than having to use two 3-coil DFU's, wires and caps. Can you tell me the Denso part number on the stick? I'd like to see what they are new. Thanks.
IMR-Merlin 06-15-2015 06:31 AM
I have a motorcycle salvage yard I am sponsored by. So I can probably get 12 cheap. I'd love to know how to convert the wiring on my Tec3 6/12 to run these.
And that is one badass Escort!
boosted79 06-15-2015 07:13 AM
"looks like I'll be building a new harness this winter."
Do you have TecGT or Tec3R? I don't think the GT will drive a twin plug six cyl. with one coil per plug since it only has four inductive coils built into it. It needs the DFU's that pair two plug leads to one DFU and uses wasted spark. The 3R has six coils built in. Clewett says use the 3R for twin plug six cyl with one coil per cylinder.
boosted79 06-15-2015 08:15 AM
After doing some more research on both the Clewett and the Electromotive sites I'm not sure it will even work with the COP? It's not discussed in the installation manual and all the Clewett kits show the coil packs included. I won't hijack this thread though.
boosted79 06-15-2015 08:40 AM
Found this. Looks like the TEC will not work with COP's without some kind of amplifier to increase the voltage to the COP's.
"Which is why I'm getting such a weak spark, the TEC-3 uses a normal inductive coil circuit where it draws battery voltage through the coil during the dwell period and then cuts the flow (float the ground line) to dump the coil. Oh, well, I guess COP's not going to work with TEC-3, time to go back to wasted-spark direct-fire coils and big bulky spark-plug wires... "
boosted79 06-15-2015 09:13 AM
One more comment, sorry for the hijack. The TEC3R will work with a GM LS coil near plug set up. The LS coils are inductive so only need 12v input. A bracket would need to be made to mount the coils on the valve covers and then use a short plug wire. Not sure if it's all worth it vs. just using the Electromotive DFU's.
IMR-Merlin 06-15-2015 10:04 AM
Tec3 - 6/12
http://www.electromotive-inc.com/wp-content/uploads/2013/08/tec3.pdf
Page 45 shows 6 coil leads back to the ECU, but I believe it is a wasted spark situation as there are only 3 coils per pack and each coil goes to 2 cylinders.
IMR-Merlin 06-15-2015 10:11 AM
Sorry to jack the thread as well, but it's keeping it at the top...
I guess I can look for a different ECU too. This is a much better set up. Much easier than running new plug wires ever couple years.
http://forums.pelicanparts.com/uploa...1434388312.jpg
Tippy 06-15-2015 10:14 AM
^ holy crap!
JJ 911SC 06-15-2015 11:02 AM
Correct the TecGT will only do 6 plugs (1 x 3 coil pack) but can be setup to run sequentially (need to have a Cam trigger).
Here is the link to the Electromotive forum (low traffic compared to PP). Electromotive Group • Index page
boosted79 06-15-2015 11:35 AM
The problem is I think the TEC ECU only puts out 12volts to the coil packs. The motorcycle COP's have a much smaller secondary to primary winding ratio so they need a much higher input voltage to get the req'd output voltage to the plugs. I think they use CDI to drive the stick coils. So without some kind of amplifier to increase the voltage coming from the TEC ECU I don't see how it's going to work with those motorcycle stick coils. Probably the easiest thing to do is call Richard Clewett to see if he knows if it can be done.
WinRice 06-15-2015 12:18 PM
The coils above are CDI coils with a low turn ratio and need roughly 400V to fire properly. Something like a M&W CDI box.
b930 06-15-2015 05:16 PM
Hi
I run 60-2 on both cars with PE3, it can run may trigger patterns so no drama with at all.
Cheers
b930 06-15-2015 05:19 PM
I have run these coils with no CDI at 20psi with no issues. I think it depends on which bike you get them off. There are many builds using PE3, both on bikes and cars running the denso sticks directly from the internal igniters with no problems.
Cheers
WinRice 06-15-2015 05:31 PM
Interesting!
I talked to the guys at M&W and they recommended the Denso 129700 series and said they were true CDI coils, not really intended for 12 volts.
Here's my write-up:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/587211-935-suspension-moton-coilovers-street-4.html#post7857172
b930 06-16-2015 04:20 AM
Thanks for the thread link, great reading!
boosted79 06-16-2015 06:11 AM
b930 - Are you going to use the Bosch three channel igniters? The more I read about that PE3 the more I like it. Will you have access to a base map from them or setting up your own? Merlin - This may allow the Tec to drive COPs, external igniters driven by the ECU but I'm not positive. You have to be able to set up coil charge time in the ECU to match the requirements of the coil used and I don't think that's possible with the Tec. Pg. 41 of the Tec3r manual addresses coil per plug but only 6 cyl odd fire and then it says you have to use the Electromotive individual coils.
Edit -b930, never mind, already answered on both questions. So you are already running the PE3 on this engine. Did you get a base map from PE and then tune it yourself or put it on a dyno? Thanks.
b930 06-16-2015 06:52 PM
Yep, I already run a pair of Bosch three channel for the upper plugs, I am going to add another pair to drive lower plugs. I have dwell times for the denso coils based on bench tests PE did for running their ECU's on bikes. Just make sure your trigger from the ECU is a compatibility. I developed my own map and am happy to share it. I run full sequention using a modified distributor to provide sync to the ECU.
Cheers.
b930 06-16-2015 08:36 PM
My sync trigger, I think this was an SC distributor I gutted and fitted a mag sensor out of a cosworth distrubuter inside it. Works great.
http://forums.pelicanparts.com/uploa...1434512184.jpg
b930 06-26-2015 09:39 PM
My 930 heads have what looks like a 60degree chamfer breaking the head seal surface to the combustion dome. The chamfer OD measures same as the stock bore where it meets the sealing surface. The 3.2 heads have a straight surface with no chamfer. 3.2 heads on right, stock on left.
http://forums.pelicanparts.com/uploa...1435379328.jpg
Stock cylinders and heads showing how the chamfer sits.
http://forums.pelicanparts.com/uploa...1435379807.jpg
I was looking for advice on whether to chamfer the 3.2 heads into the dome. I'll be using 100mm bores with them. Since they run bigger valves I might not be able to do 60degree with an OD of 100mm as it get very close to the valve seat.
Cheers
b930 11-09-2015 09:30 PM
Been quiet for a while. So I decided the following for my build after a bit of a financial assessment (i.e. realizing I needed deeper pockets than I have for my big bore plans). The bottom end will stay together, and I have sourced:
LN Nickies 3.5L slip fit cylinders.
JE 8.0:1 coated pistons.
LN FFA connecting rods.
Sitting on this will be Carrera heads with high flow (993) valves, 964 cams, twin plugs, the big ass intercooler pictured earlier. Should still make some stout power with the twin scroll turbine GT3582R and equal length 1.5/8" headers.
Here is the bottom end with rods in and checking deck height, supertech studs installed. Getting 1.2mm with stock base gaskets which I think is good.
http://forums.pelicanparts.com/uploa...1447133409.jpg
boosted79 11-10-2015 06:25 AM
Looking good. What made you go with the FFA rods vs. Pauter or Carrillo? Also what did you decide on the 60 deg chamfer? It might be good just to break the edge with a slight chamfer even if you can't go all the way to 100 mm.
jsveb 11-10-2015 07:50 AM
Have you got more info and pictures about this?
