Btw, do you mean crank sensor when you have written TPS sensor? TPS is throttle position sensor and the crank sensor is for ignition no? Just to clarify.
Gone!
Old 11-19-2015, 02:34 PM
IMR-Merlin's Avatar
I've been off the board for a few weeks, nice work!!
Welcome to the darkside!
Can you add EBC?
I am running a Tech3 with EBCS, but I am going to change out my Tech3 for a VEMS, so I can do COP and boost per gear, my car is useless with 1.3bar in 2nd (1st is for parking).
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 11-19-2015, 02:46 PM
dos531's Avatar
Can you add EBC?
MS3pro has a ton of capability. I am running basic closed loop boost control now with a gm boost control solenoid. It also has boost by gear, traction control, launch control etc. I'm not using half of the features it has. The biggest one for me was the knock sensing capability with individual cylinder knock detection and knock windowing.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 11-19-2015, 02:57 PM
dos531's Avatar
Got the links mixed up. Fixed and added a couple items
Ducati 748R
Old 11-19-2015, 02:58 PM
jbrown's Avatar
looks very familiar.
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter,
Old 11-19-2015, 03:21 PM
Chain fence eating turbo
Can you add EBC?
Question: can MSPro do EBC?
MSPro can do just about anything!
Old 11-19-2015, 04:05 PM
dos531's Avatar
It really does have a silly amount of features. The next thing I need to add is a clutch switch of some sort so I can use the launch control
Then I need to plumb in the Flex fuel sensor as well as replace all the rest of the fuel lines with e85 compatible hose.
If I can find a compatible VSS signal then the boost by gear and traction control feature would be pretty handy as well.
Ducati 748R
Old 11-19-2015, 04:25 PM
I have antilag (MS calls launch control) on my MSII.
I can hit full boost at a stoplight. Not that I've tried full boost, but 1 bar came quick at half throttle, so I chickened out and let off.
Can you PM me the III and X prices, please? Thanks in advance.
Old 11-19-2015, 05:19 PM
Work in Progress
Rich76_911s's Avatar
Dos531,
Again thanks so much for this wonderful bit of information! I was messing with your spreadsheet a little bit, and I noticed that your Total does not include the:
Crank Trigger
Coils
Coil connectors
Knock Sensor
Not hard to fix on our own, but just wanted to share that with you.
Again Thanks!
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 11-20-2015, 09:57 AM
dos531's Avatar
Originally Posted by Rich76_911s View Post
Dos531,
Crank Trigger
Coils
Coil connectors
Knock Sensor
Again Thanks!
Rich
Good catch, I didn't even notice. It's fixed now
Ducati 748R
Old 11-20-2015, 10:34 AM
dos531's Avatar
Tippy your messages are full
Ducati 748R
Old 11-20-2015, 11:46 AM
Mike80911's Avatar
Great job if you are bored now you can come over and do it to my car.
89 930 Cab Black
11 Cayenne
Old 11-20-2015, 03:35 PM
Cleaned out
Old 11-20-2015, 03:47 PM
The pro is pretty awesome. Super easy to wire and set up. If you want one let me know. I opened a wholesale account with diyautotune and they have a black friday sale going on right now so they're even cheaper. I actually have the ms2 that I was going to use, but I decided I really wanted the ms3pro.
I am interested as well... do you mind PM me the price of a MS3 Pro with their standard fly wires?
thanks!
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 11-22-2015, 11:38 AM
I'm interested in where you mounted the MS3-Pro. In the engine compartment? They say it can handle the heat, but I'm not 100% convinced.
Old 11-23-2015, 05:41 AM
The 930 engine compartment doesn't really get hot compared to a water cooled engine compartment.
The fan shroud blows hot air straight down out of compartment while engine tin blocks the radiant heat from coming up pretty good.
It should be just fine.
Old 11-23-2015, 06:18 AM
I am using pretty much same set up - GSF crank wheel and same VR sensor so am interested in knowing what air gap do you set with the sensor?
I had been chasing a high load/high RPM misfire and now 100% dead in the water as I started fiddling with the VR sensor (thinking it may be bad). Now can't even get MS3 to sync...
In fact, wondering if I had blown something in the HW so may need replacement
Old 11-23-2015, 06:45 AM
dos531's Avatar
Mounted the ECU under the seat where the stock one was. The engine bay doesnt get all that hot while running, but when stopped it heats up real quick. Not worth the risk to me.
Ducati 748R
Old 11-23-2015, 09:12 AM
dos531's Avatar
I believe we gapped the sensor to about .035". I also ran a 10k resistor in line with the vr sensor. In the manual it says if you have sync loss at high rpm with the high tooth count wheels to install the resistor, so I just put it in to begin with. I also installed a condenser on the supply wire to the coils, as that is supposed to reduce noise. I've never had any sync loss so far.
Ducati 748R
Old 11-23-2015, 09:15 AM
Thanks for the info. For the 10k resistor this is in series with the signal lead of VR (and not I parallel across VR signal and ground)?
Mine was running for a season but continued to have issue at high boost/high RPM and I never had sync loss as well before. But after trying to replace the VR sensor I can't even get her to sync anymore 😔
Old 11-23-2015, 10:24 AM
