New cheap injectors for 930?
Was getting ready to order injectors for my 88 930...
Last I checked they were $130-150...
Just checked again, and Bosch injectors are popping up on this site and other for $60-75.
931-110-225-00-M14
I assume these are fine??? Way cheaper than the Porsche ones.
Not sure how I missed these before... Is this pricing new, or did I just not see this before? I could swear I paid $150 or so for an injector several years ago...
Old 11-30-2016, 06:42 AM
That price is about right. I bought a set about a year ago or so and the $60-$75 range each was about right. If you want more HP, you can purchase the euro ones, but they cost quite a bit more.
Old 11-30-2016, 08:20 AM
No porsche premium when buying Bosch injectors from Bosch
Old 11-30-2016, 09:47 AM
T77911S's Avatar
ah, I tried to look up and see if they were the 009 injectors but the site is not working correctly.
I paid about 115 from flowtech for mine, got 6.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-30-2016, 11:53 AM
Check out https://www.*******.com. Purchased some in April for $67.There $87 now.They are the Bosch euro injectors.
Old 11-30-2016, 03:12 PM
Ingenieur
The injectors have no influence on power. The metering slits do all the flow control. The nozzles just turn what would be a stream of fuel into a spray. Believe it or not, the 930 injectors have exactly the same maximum flow potential as a 2.7 911T's. They also have the same spray angle, and a similar opening pressure. The body is of course modified to screw into the intake manifold blocks with a M10x0.75 thread.
Old 12-02-2016, 09:21 AM
Sounds right.
The different numbers on 930 injectors may just be part numbers from different years and they all spray the same amount of fuel.
Do a flow test and you'll see how much fuel they can spray when you push the air flow meter down.
Old 12-02-2016, 05:48 PM
