Shopping classifieds early this AM.
What's the story on used Turbo P/Cs? The thing I learned today was that turbo cylinders have cooling fins only on the bottom on 3.3 so that they cool the piston more evenly as the exhaust side is hotter. Edit: Land clearances, detonation pitting, out of round? food for thought I found some clean low miles 97mm 3.3 Mahle P/Cs for pennies on the dollar. Is there a good resource to explain taper and tolerances related to taper? 8.0:1 vs 7.5:1 I guess the difference would be 8.0:1 would be a little more responsive off boost? Will cooling tin off the 3.2 fit the turbo cylinders? Will 3.2 heads fit the turbo cylinders? Do 3.3 turbo pistons use the same wrist pin as 3.2? Will the stock 3.2 rods hold up if I use good rod bolts? If I just get pistons, is boring and re plating my existing mahle cylinders as easy as sending them off to US chrome or other and specifying size? I'm pretty sure they are Nikasil as I did the magnet test when I took them apart. Any other cautionary tales to running dual spark on COP setup with a turbo? I'm sending out the heads, the fee to convert to dual is nominal compared to total cost. Of course there are more plugs to buy and wires etc. VEMS people talk to me. What's the cost, support and satisfaction with the product? EDIT: Raceboy I see you are the VEMS guy. I found an older VEMS thread here. I'll probably reach out to you in the near future about more questions. |
Take-off 3.2 turbo kit listed here in the parts section. Want $3K. Maybe not everything you want or need but will get you turbo’d quickly, you learn some things in the process then make changes in part or total down the road.
Nowadays many people want to leave their cars mods reversible and most harnesses are good.
Regarding support, why is there prejudice that it is not good enough when it is not in US? My customers can vouch for the support I provide and I reply usually in an hour whoch is far cry from the "support" many US based vendors provide (not replying to emails at all, when problems arise ignoring them or blaming a customer etc). I have personally experienced that and so have many of my customers (who have turned to me after non-existant support for their MAF kits, mostly from 944 Turbo world, just do a search). PnP with working config and no need for any hacking beats any time the need to build harness+having to take your car to the tuner for even getting it to run for a user that is not a die hard specialist. Many of my customers have NEVER touched a standalone before and yet manage to get their car running (and running well at that) without issues. I have provided help and answered questions if needed. |
Thank you! :) |
| All times are GMT -8. The time now is 02:50 AM. |
