-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Talk me out of/into a Turbo conversion (http://forums.pelicanparts.com/showthread.php?t=984519)
75 911s 01-17-2018 10:54 AM
I recently acquired an 87 3.2 long block. I've torn it down and the plan is a 3.4. The motor did not come with intake or exhaust so I was going to run an EFI / ITB setup with some racing headers. Motor was slated to go in my 75 911.
I have to admit I've been inspired by the boosted brothers build and since I'm at the start of the build I'd like to at least consider and price out a turbo conversion.
Why or why wouldn't you build a turbo?
Just how much more will all the turbo components cost?
I think the intake might actually be cheaper as I would buy a stock 3.2 intake and run EFI on that with the right injectors as opposed to ITBs which are an additional 2-4k
I think the exhaust would be more expensive for obvious reasons.
I'm emissions exempt. Car is street/show
Budget is flexible and I'm building it over a long period of time. Shooting for a Dec 2018 completion.
I've never even driven a Turbo.
My narrowbody car has 6" in front and 7" in back on 225/50. Would this be stupid? If I did build a turbo, I might look around for a widebody roller.
Thanks for any input and or resources. I have Bruce Anderson's Performance Handbook, but looking for any contemporary knowledge.
http://forums.pelicanparts.com/uploa...1516215167.png
http://forums.pelicanparts.com/uploa...1516215237.jpg
Tippy 01-17-2018 11:03 AM
Why would you turbo a 3.2? Because it has the same low end as the 930 does except the oil pump.
2nd, it has a higher flowing intake, higher flowing heads, and larger camshafts over the 930's.
It's a win-win.
I may have a 3.2 intake for sale.
Tippy 01-17-2018 11:26 AM
Some totally rough numbers.......like really rough (search for better numbers):
1. Rarly8 or B&B 930 headers - >$2000?
2. TiAL F46 wastegate - ~$500 (bolts right up to 930 headers) or TurboSmart - much cheaper
3. Blow-off valve, TiAL, TurboSmart, HKS, GReddy, etc. - $ all over the place
4. Intercooler - TurboKraft for nicest, Treadstone, eBay specials - $ all over the place
5. Injectors - ID1000's (probably the best in the market) - >$700? or Siemens Deka 875cc's - got mine for only $300 on eBay
6. MegaSquirt, AEM, MoTeC, Holley, F.A.S.T., SDS, Link, etc., etc., etc., etc..... - $ all over the place from $500 up to like $10,000
7. Mahle turbo 98mm P&C 7.5:1 CR (if you want high boost in the future) - ~$5k?
8. Bosch 044 fuel pump - $150 and up (lots and lots of counterfeits out there!)
9. Borg-Warner S256, S360, S362 - $750 and up or Garrett GT35R - ~$1200 and up or Turbonetics 60-1 - ~$750 and up
10. KEP stage I or II PP (to hold added torque) - $650 - 750
TurboKraft 01-17-2018 11:28 AM
Upgrade the oil pump and piston squirters, and you've got a great foundation for a Turbo engine.
EFI+ITB *and* pistons & cams, and lightweight rods (or at least rod bolts) and that's a fun non-turbo engine capable of 280-300hp on pump gas. Like a 3.0L GT3RS. Won't murder the 915 transmission, either.
But any version of Turbo pistons, with EFI and standard 930 go-fast parts (headers, GT35R, intercooler) and it'll make 500whp without hardly effort. You'd probably have to neuter it with a standard 930 J-pipe turbo-WG pipe and a K27 to keep the 915 in one piece.
quattrorunner 01-17-2018 02:06 PM
Even with those parts mentioned above that are to keep it underpowered as Chris says you’ll still probably kill the 915 gearbox.
So figure into your conversion another $10-20k for proper transmission mods.
That being said turbo power amazing. I love it. But to do it again I would be scared knowing what I know now all financially.
It’s espensive!
quattrorunner 01-17-2018 02:37 PM
BTW I'm in Vegas, Should have mine back on the road in the next couple weeks if you'd like a ride along. I don't trusty just anyone to drive it these days......
Hill3312 01-17-2018 03:37 PM
I tried my absolute hardest to keep things "budget oriented." Even with cheap headers and a tractor turbo the build easily exceeded 15k.
- Bottom end rebuild - 6.5k
- Lower compression pistons- 1.5k
- Head rebuild (port and polish) - 2.7k
- Headers, ECU/ EFI kit, misc turbo junk (wastegate, intercooler, bov, etc) 3.5-4k
... I'm not done yet, the car doesn't run. So who knows how much more it'll cost. Will probably be worth it, that's what everybody keeps saying.
1979-930 01-17-2018 04:12 PM
I think most of the costs in his build are accounted for N/A or Turbo.
The added costs will be
GT35R Turbo with install parts $2350.00
Dual WG $750.00 <-- Why not dual if starting from scratch.
Intercooler with install parts $2,200.00
Other Turbo Engine costs ?? Maybe $3,000.00
I think the added cost will be around $10k to go Turbo.
If you have it to blow then go for it. If it's going on a C.C. Don't!
Mr9146 01-17-2018 05:20 PM
Buy a 3.6 ...
TurboKraft 01-17-2018 06:27 PM
Originally Posted by Mr9146 (Post 9890206)
Buy a 3.6 ...
Yeah, but those aren't exactly cheap any longer, most seem to need at least a top end rebuild, then adapt it for the earlier chassis... That all adds up really quickly as well.
spence88mph 01-17-2018 08:41 PM
This is my engine, made 320WHP with 0.5bar in 2009ish, ran in the current configuration since without any issue until recently, it started blowing smoke, tore the engine down completely, split the case etc. Only thing that needed doing were 2 valve guides. Put some ARP rod bolts, new rings, some cleaning and gaskets and its back ready to go once my clutch arrives. I am going to add an W/A intercooler, VEMS, soon but getting it running first. I highly recommend this route, the car is proper fast.
Parts:
Garret GT30R 3071
Protomotive RRFP
Protomotive Stage 1 Chip
Protomotive Charge Pipe (no intercooler)
Rarely L8 Muffler
TiAL 46mm Wastegate
Oil line to turbo
Good luck!
http://forums.pelicanparts.com/uploa...1516250595.jpg
flat6pilot 01-17-2018 09:33 PM
Parts list from my 1980 SC conversion. (360whp/324tq)
http://forums.pelicanparts.com/uploa...1516253371.jpg
In addition to that, I already had this:
CARRERA MANIFOLD - $700
MEGASQUIRT MSII IGNITION (FUEL ONLY) ~$2500 (Give or take...)
MSD IGNITION - $300(?)
Good luck! I'm hooked on turbo power now... :eek:
My turbo thread: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/880468-another-911sc-turbo-conversion.html
LOWFAT 01-17-2018 11:09 PM
It can also depend on your driving style and the kind of roads you have available to you. Tight twisty roads staying naturally aspirated will be the better choice as the car is more controllable and more enjoyable. If the roads are a little more open with long flowing curves or a lot of highway driving the turbo wins hands down. I do a lot of spirited driving with a couple of my friends who have a 3.0 SC and a 3.2 Carrera. On most of the loops we frequent their cars are much faster until the straights where the turbo's power comes on and I shorten the gap very quickly. The sound of the turbo spooling and the jump to light speed never fails to put a smile on my face. I'd like to get either a SC or a 3.2 for myself at some point to make a proper back road burner. I do plan to do some suspension upgrades this spring and that may help tame the 930 a bit more but I still think a naturally aspirated car would be faster for our roads where I live.
RarlyL8 01-18-2018 04:45 AM
You could go a couple ways with a turbo build; keep the 915 and build an ultra quick spooling mild turbo engine that would be a riot to drive in the twisties or add a 930 tranny and build a yellowbird killer. Either way would be tremendous fun!
Tippy 01-18-2018 05:53 AM
Brian, beings that he is starting from a 3.2, keeping the 915 from grenading will be next to impossible, unless he uses stock 930 bits.
But what fun is that?!?!?! :D
I'd think he has an easy 100hp/80ft/lb torque advantage stock to stock between his 3.2 and a 930 engine??? No??
Tippy 01-18-2018 05:55 AM
Kyle, that is my kind of build! Love the "grassroots" stuff. :cool: Nice numbers! :eek:
Tippy 01-18-2018 06:10 AM
Parts:
Garret GT30R 3071
Protomotive RRFP
Rarely L8 Muffler
TiAL 46mm Wastegate
Oil line to turbo
Good luck!
Nice numbers for non-intercooled! But, I can't help but think, for a little bit of money, how much more power you'd make with one. I paid $500 for a V8 designed intercooler from Treadstone. It has a 15 degree raked back inlet (was made to go in front of their radiators) that I cut off, and rotated 90 degrees aiming towards the throttlebody. Then, I removed the outlet and mounted it 90 degrees on the outlet tank and welded in a plug to where the outlet used to go. Did all this a MIG and spoolgun. Took about an hour.
http://forums.pelicanparts.com/uploa...1516284484.jpg
Or, you can get a ridiculously cheap one from CXRacing. I bought one initially, it has a 5" core!!! It was only like $215. It was a horizontal flow, and in my mind, was going to be a restriction (not likely at all, after seeing high power cars with this design), so I opted for the vertical flow (Treadstone above of course) that every 911 turbo aftermarket house uses just to be safe. Was going to have to rotate the left tank 180 degrees, was the biggest hurdle too.
http://forums.pelicanparts.com/uploa...1516284511.jpg
75 911s 01-18-2018 11:44 AM
Wow what a great group of responses! Thank you to everyone who has given input so far. I obviously have a lot to research. I was entertaining the turbo just as due diligence to consider all options while I have the motor torn apart, but hadn't really seriously considered it...until now! Now I'm flat out excited about it!
Quattrorunner, would love a ride along when you get the car back.
One interesting thing is that when you pop the decklid on a turbo car, you get an intercooler... It's a lot less pretty, but it definitely says "turbo power!" This would allow me to change up some of the cosmetic stuff I had planned and implement a more basic, but clean, engine bay.
Tippy you mentioned the stock 3.2 intake and cams being bigger which is an advantage. I had planned on replacing the cams with something more aggressive for the ITB setup, but with the turbo setup, you are saying I could regrind my stock cams and save a little money that way?
Also what's the deal with twin spark in regard to Turbo? My understanding of it is that it helps with higher compression engines, and since Turbo, by their nature are lower... I shouldn't need to go twin spark anymore.
Thank you again to all the contributors!
Tippy 01-18-2018 11:54 AM
John Dougherty a.k.a "camgrinder" from DRC cams, can grind the stock 3.2's to the popular and sought after 964 grinds up to 993SS (super sport) if you beg him.
If you are running flat-top pistons, twin-plugging is not as needed as the general consensus goes, but is said to be safer and makes a little more power. If you are staying at lower boost levels, probably not all that worth it. But, "cgarr" here can do the twin-plugging to your heads for a pretty reasonable price if you must.
Tippy 01-18-2018 12:00 PM
Duane, I made my intercooler brackets/mounts from aluminum strap from Lowe's or Home Depot. Cheap as dirt and bends easily in a vise to whatever angle you need. Easy to drill through and cut to size too.
Raceboy 01-18-2018 12:13 PM
Twin plugging is obviously beneficial to turbo engine. Where did you take it that turbo engine is low comp? Yes, low static CR but boost effectively making it very high CR engine and whatever type of pistons you have it still halves the time needed for the flame front to travel meaning you need less advance and you have much better resistance to knock (because knock treshold moves further from MBT).
IMO best bang for the buck mod for 3.2 is turbocharging it, no contest. As noted above the trick is to spare poor 915, you could do this by controlling boost electronically depending on gear to reduce torque in 1st and 2nd gears.
And no, there is no need to purchase EBC kit for that (along with WBO2 kit, EGT kit, knock kit etc) as you can buy VEMS PnP for the price of two or three of any of those mentioned and have it all in one box.
'76 911S 3.0 01-18-2018 12:31 PM
Don't forget oil cooling upgrades if you do not have at minimum a Carrera cooler.
One of these days I'll get around to making a list of all the parts I required for the turbo build but I'm actually quite terrified at how much I have spent doing it (and that's on top of the almost $15k I spent on rebuilding the engine).
75 911s 01-18-2018 02:40 PM
Yes I have ER finned cooling lines and a widemouth carrera cooler with a relay/fan.
@Raceboy, my ignorance is exposed! Makes sense, I was looking at the static compression ratios. Like I said I have a lot of research ahead. Conversations like these help immensely because it gives me a framework to start with.
quattrorunner 01-18-2018 05:44 PM
As far as twin plugging NA: the dome of real high compression pistons have a bit of an problem to go around as opposed to a flat area free of angles or obstacles. Twin p[lugging puts a spark on each side of essentially two areas....
RarlyL8 01-18-2018 06:30 PM
The 915 is just fine paired with a mild turbo build, just as I did with the SC/930 in my signature line below. 350whp with short 915 gears, narrow body tires and a curvy road would be a riot! You also would not need a big oil cooler or intercooler. Go big and you need a 930 4spd and a lot of expensive add-ons to support the power. Both are great fun, which way you go depends on what you want out of the car and your budget.
Mr9146 01-18-2018 06:58 PM
We’ve been running non-intercooled turbo motors in our 75 Carrera for well over 20 years and hundreds of thousands of miles.
The current motor is a 3.2 with 8.5:1 compression, 964 cams, and a K27 backed by a euro 915 with LSD. Works great.
Before that it was a stock 3.0L non-intercooled motor...went about 150K miles on that one...daily driver...went cross country twice...never missed a beat.
I still think he’s be better off with a 3.6
quattrorunner 01-18-2018 07:01 PM
I agree with Brian, a mild turbo boost pressure engine with short ratio 915 gearbox is an absolute blast! However knowing that you can safely raise the boost for more power becomes an ever increasing reality that you want to realize after time. If you are diligent and can control your boostaholic urges, you can stay below 7 psi and the transmission will be fine. All that being said, I went through to 915 gearboxes at Stock 930 boost pressure (.8bar).
Tippy 01-19-2018 06:14 AM
Sure, you can run without an intercooler, but your chances of detonation go up and you leave a ton of power on the table. Less timing and hotter, less dense air.
Intercoolers have gotten so cheap, that buying an eBay special and having it adapted to a 911 doesn't cost that much. Many here have done it.
75 911s 01-19-2018 06:21 AM
This is really helpful, thank you!
Looking back at the last 3 years it's been mostly freeway!
School me. What would be your cam, pistons, turbo etc setup for a "mild turbo"? Are you just saying limit boost via the Tial?
Tell me more about Vems.
My 915 is non LSD, what are the implications, if any, of that in terms of adding a turbo setup?
I don't understand the relation of the short ratio to boost pressure. Would this be trying to emulate a 4spd 930 trans? or what is the advantage?
For non IC setup, is it worse in extreme heat environments? I'm in Vegas and I drive my car in the summer months. Ambient temps can get to 110. I also sort of want to use the new wing I just installed. It's a glass whale grafted to a steel decklid, so no immediate room for an IC unless custom like some I've seen stuffed up into the top of the bay. I also like switching to my stock decklid since it's generally a better look with super skinny hips.
What 930 oil pump am I looking for? Are there core trade opportunities for my stock 3.2 pump?
When I send my case to Ollies, ( I spoke to Zack last week) I need to specify 930 squirters? Are they just higher flow? whats the dif? Any other case mods I should be aware of?
Is the scavenge line (like gravity feed on 3.0) strictly a 3.0 conversion thing? Does that relate to my build in any way?
This is exciting, I think I'm sold on the conversion. Now I just need to start my own sunglasses company to finance my new habit. *uhhh TurboKraft intercooler....DROOL..... I think I'll call my company Turbo Shades. How does that sound? :-D (Totally kidding - Ordered me some boosted shades last week!)
Hill3312 01-19-2018 07:24 AM
- The best part is making a video series and writing off the entire turbo conversion as an advertising expense. Thanks for the support by the way, good luck on your journey!
jsveb 01-19-2018 10:23 AM
‘Like your way of thinking.
RarlyL8 01-19-2018 10:51 AM
Mild turbo build would not require much more than an exhaust change and intercooler. You already have the SC /Carrera cams, Motronic EFI and C/R to create good torque and drivability. Add my tuned headers and a GT30 or like quick spooling turbo with large intercooler then tune the EFI with a chip and fuel pressure mod. Add posi, bearing retainer and HD side plate to the 915. Oil tank will need a mod if using a return line. That’s about it. Crazy fun. But if the big power bug hits you a tranny change will be needed along with suspension brakes and everything else to support the power.
Carbster09 01-19-2018 01:34 PM
tough choice ... my only comment is the boost is addictive. No doubt about it! I ended up with my boosted / modded 930 almost by mistake. A dude needed the cash and I bought it with the intention of flipping it for a tidy profit. Well, love the thing. If I don't get stupid and buy a GT3 ... I will be buried in this!
quattrorunner 01-19-2018 01:43 PM
I’ve recently driven a 991 gt3 and it’s great but our cars feel quicker with simple upgrades. At least till you go around a corner.
75 911s 01-19-2018 03:55 PM
So sounds like with my stock components on my car (ie manual brakes and 915) I might be best served putting the 3.2 back together fresh with existing Mahle 9.5:1 compression and running mild boost on that. Still a 8k proposition but better than 15k and no need to go power crazy on such a light car. Especially after coming off a tired old 2.7.
That could be the most economical approach. It's not future building though, so If I decide to increase boost I would need to later do a top end and swap out the pistons. Maybe I can preplan a bit and upgrade the case, pump and rod bolts/studs as planned anyway. Any problem with running a turbo pump in there on the stock pistons. By the way, I have no harness, no motronic, I suppose I could source a harness and stock manifold.
quattrorunner 01-19-2018 04:18 PM
Sense you’re already in there I’d go with lower compression.
Yes you’ll have a giant smile with only .4 bar compared to even an sc3.0
sundevil64 01-19-2018 04:43 PM
You should buy my 79 rebuilt turbo EFI motor and 4 speed that I have in my Carrera so I can put a 3.2 back in it.
Raceboy 01-20-2018 09:07 AM
Why would it make sense to buy chips for Motronic, buy RRFPR and still have injectors totally maxxed out and AFM barn door complicating piping very badly? :confused:
One would still need WBO2 kit and when putting all things together it will almost make amount that you could buy VEMS PnP for and it already has WBO2, works on stock sensors and you can use proper injectors without any hack jobs.
What amazes me is that when it comes to building engine itself, people do not hesitate coughing up few thousand just to get 0.2 liters of more displacement (which is pintless performance wise) and yet trying to save few hundred when deciding whether buying proper ECU vs using Motronic with hackjob...Can you explain me this please?
baloo 01-20-2018 10:18 AM
Yah, it's a peculiar, and predictable (!), process of thinking.
My favorite is the investment in titanium lug nuts to lose a pound in unsprung weight, but meanwhile, the driver gains 20lbs over the year.
We see it over and over in similar performance car forums -- where sinking $$ into rebuilding an engine "to be more robust" produces minimal improvements in performance, compared to relatively simpler changes.
Trying to find a human behavioral explanation for this, I think it has something to do with the satisfaction of knowing something is technically and engineering-wise more robust, and thinking that dollars-spent equates with peace of mind.
I admire the enthusiasm, thinking and planning that is being put into this.
Will be interesting to see where this project is in one year, or whether it succumbs to economics, job-related-requirements, relationship problems, newer shinier objects, or just project fatigue.
75 911s 01-20-2018 11:07 AM
I think he was just looking at it from a stock 3.2 standpoint with minimal addons to convert to a turbo setup. So in that scenario it would include motronic I guess. But you're right, after dropping thousands in pistons and other upgrades, it would be better served to use a proper ECU. As I mentioned, I don't have the stock harness or computer or intake, so unless I found a complete setup for pennies, I doubt I would go that route.
Ha! Agree with a lot of what you are saying. I do a lot of lightweight mods for two reasons. 1. It's fun and it's tinkering and creative. It definitely brings joy in my life to work on the car. 2. It can lead to better performance, though the reality of it is very small gains probably.
Regarding gaining 20lbs..yes we all face that problem, the titanium lugs reference is funny. I actually rejoined the gym about 4 months ago and have been working on myself and I think working on my car inspired me to work more on my own body! :-D
Finally, I'm also fascinated by threads with big projects. I'm a forum junkie and It's crazy to check that first post date and see how long projects actually take. Many of course never get finished. I like bumping those threads and providing positive comments to see if I can kickstart them again. You never know how a small bit of encouragement can re-ignite enthusiasm.
In my build thread I talk about one of my core philosophies (regarding the car) is to keep it drive-able. No matter what mods I do, I plan out medium to small projects, complete them and then drive the car again. It keeps motivation up.
Buying this core was a great opportunity to keep my car running but to solve the long term problem of the 2.7 needing a rebuild. Though I can't predict what the future will bring, I think the main thing that will see the project through is the joy that I'm getting out of the whole process, whether it be building, research or just interacting with the community.
I came into my car project about 3 years ago with basic mechanic skills. I never thought I could rebuild a precision engine on my own. I've gained confidence in my skills by tackling various projects on my 911 of varying difficulty. This engine build will be the culmination in my mechanical skill set. Luckily I have a lot of help from you fine folks who have the experience I lack. :-)
http://forums.pelicanparts.com/uploa...1516475127.jpg
