Brake caliper seal question
Brembo 930 calipers, I'm rebuilding mine on the 79 turbo. When doing tear down I found the seal lips were toward the fluid chamber on the front calipers and facing out on the rears.
I learned a long time ago while working at MD pneumatics that the lips should face the fluid to prevent leakes. I did an Internet search and confirmed that the lips should face the fluid and face out for grease. I had issues with one piston on one caliper so I sent it out for removal and they installed the seals and pistons while they had it. I was sent pics after the work was completed and the lips on the outer seals faced out. I asked about it and was told by the service guy that he would inquire but never did hear back. I recieved email notification that it had shipped and would be back home Friday. Does anybody know how Brembo says to install the outer lip seal? |
There are a few threads on rebuilding the brakes. The ones I saw did not really refer to your problem. I got the impression there was no lip - there are a few pics. I did mine a while back and can't remember anything odd.
Maybe check thru a few of the older threads and see if there is a light bulb moment. I searched 'brake seals'. Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
When I did mine, the seals were simply a square shoulder "O" ring, no lip, no front or back.
I've done many other brands of calipers as well, and have never seen any other style of caliper piston seal. German, American, Japanese....no difference. Mark |
These have 2 per piston the square ones are the inner seal.
Ok so you are talking about the "scraper ring" AKA dust seal, not the piston seal.
Those "scraper rings" have 2 distinct sides , one side you only see black rubber, the other side you see an outer steel ring with some black rubber on the inside. Those "scraper rings" should be installed so that when pressed in there is still the visible steel ring showing and pointing toward the brake pad. At least that's how mine were from the factory, and is how I installed them when I rebuilt them...40K miles on them so far...no issues. Mark |
take a closer look at the groove the seals go in. to me it looked like the bottom of the grooves were not "square" to the sides. IE, the bottom was angled so it would make the seals angled.
I put new seals in mine (don't think they needed them) and the new seals are "square". some of my old ones were like yours, had a raised side. you need to use grease on the seals, especially if you put in new ones. I could not get the pistons to move at all without grease. once you get the calipers back together, put a 2x4 in place where the rotor goes then use compressed air to pop the pistons out. make sure all come out at the same time. you should not need much air pressure, the less the better.
Everything I read referred to them as scraper seals making me think they were a second oil seal. Someone before me redid the fronts, which I did first and they installed them backwards so I installed the same way. When I did the rears the seals there were opposite making me think those were backwards, now I know better. I wish these seals were referred to as dust seals, not scrapers. I would have questioned the installation of the fronts when I did them. |
Since the outers are simply dust & grim seals, I would not loose too much sleep over your current installation direction.
I certainly would not try to pry them out {and most likely damaging them in the process} , just to flip them around. Most folks don't drive these cars enough or in dirty situation to warrant much concern over such a minor thing. My .02 worth. Mark |
That's what I was thinking also, just would have been nice to know up front. Maybe someone else will see this thread and learn from it. |
Well if it makes you feel any better....I completely rebuilt all 4 of my calipers trying to rid myself of an inconsistent wheel lock up under braking....only to find, all I really needed to do was have a proper corner balance done.
It's always something with these old girls, and always a learning curve. Mark |
Mark,
I have my turbo front calipers on the bench right now and am waiting for the seals and scraper rings. If I am understanding your reply the metal side of the scraper ring goes in first but the metal should still show? Thanks, Bob |
T77911S,
What kind of grease did you use on the caliper pistons? |
Hey there Bob,
When you get your new seals and scraper rings, you will clearly see that 1 side of the scraper ring is all rubber and black, the other side has a metal ring {steel donut}. This steel ring {donut} should be facing the brake pad....NOT facing the caliper piston. Hope this clears it up for you. When I rebuild calipers, I only use fresh DOT 4 brake fluid for assembly lube, if you feel that you must use grease, use some synthetic wheel bearing grease, but use is so sparingly that it would seem to be not being used at all! Mark Last edited by full quack; 06-10-2018 at 06:03 PM.. |
I HAD to use a wheel bearing grease because I needed to get the car back on the road because I ran out of cars to drive.
there may be a specific grease for the pistons but I did not have time to look it up. the inside seal is the one that needs grease. I did NOT replace the outer scraper rings.
Wheel brg grease on brake caliper seals, NOT!
Whoa!!! Stop!!! WARNING!! Never use wheel bearing grease on caliper seals
I have never heard of silicone whl brg grease used. Maybe OK. Never ever use regular wheel brg grease/engine oil on brake seals. The seals will eventually swell and fail. The same The same reason one does not use motor oil in a master cylinder. I use a brake assembly lube made by Raybestes (way old).Good Luck, Gary |
