skipdup's Avatar
pic of 930 oil separator
Anyone have a picture of the location for the oil separator that later model 930's came with? I want to add to my '79.
Thanks,
Skip
1972 911T
1972 911E "RSR"
Old 08-23-2007, 08:14 AM
skipdup's Avatar
Nevermind... found where it goes on an 87 (or 8???) 930S that was at my mechanic's.
1972 911T
1972 911E "RSR"
Old 08-23-2007, 12:40 PM
A fellow Pelacanite
NathanUK's Avatar
Some pics would be good!
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-23-2007, 03:28 PM
A930Rocket's Avatar
Kind oif hard to see with all the stuff hanging down...
Old 08-23-2007, 05:30 PM
A fellow Pelacanite
NathanUK's Avatar
Thankyou for the pics Rocket.
Re: the hose that goes onto the bottom of the seperator. Where does it come from?
TIA
Old 08-25-2007, 04:57 AM
A930Rocket's Avatar
The oil tank.
TIA
Old 08-25-2007, 02:37 PM
A fellow Pelacanite
NathanUK's Avatar
Ah, is that the port that has a cap over it next to the port that takes the oil line from the turbo (return)?
Old 08-25-2007, 03:55 PM
Crotchety Old Bastard
RarlyL8's Avatar
Ignorant question; what does that thing do? Why would you want to add the complication?
Old 08-25-2007, 06:32 PM
A fellow Pelacanite
NathanUK's Avatar
I'm hoping it would eliminate any chance of oil being sucked into the engine from out of the oil tank.
Old 08-26-2007, 03:47 AM
RarlyL8's Avatar
There is no chance of oil being sucked into the engine from my oil tank.
Old 08-26-2007, 06:42 AM
skipdup's Avatar
I have had a (Bond worthy) smoke screen problem which only happens on sharp right turns with heavy/full throttle. I can not replicate when I try, the frequency of the occurrence seems random and it only happens once in a while (not often at all). I found posts where similar symptoms were alleviated by adding the separator.
- Skip
1972 911T
1972 911E "RSR"
Old 08-26-2007, 10:59 AM
RarlyL8's Avatar
So is that a track-only issue?
Do you think it is caused from oil being sloshed/pulled from the tank by the G-force of the turn?
Have you tried lowering the oil level towards the bottom of the stick during track days? I have heard a few track junkies comment that they keep the oil at just above the "add" line on the stick due to excess growth in the tank under continual hard (track) driving conditions. I keep my oil level under 1/2 on the stick as well.
Old 08-26-2007, 06:14 PM
skipdup's Avatar
RL8- No, happens on the street. I usually keep the level at (or just below) 1/2 full. I think it happens less when there's less oil in the tank (near the fill line), but I'm pretty sure it still happens.
I haven't been driving the car much (which is changing), so I haven't been able to figure out exactly which conditions are needed for it to happen. But, when it does, it's a remarkable amount of smoke.
- Skip
1972 911T
1972 911E "RSR"
Old 08-26-2007, 06:31 PM
A fellow Pelacanite
NathanUK's Avatar
Brian, can you take some pics or explain what you did with the vent from the oil tank that the photo hides?
TIA buddy.
Old 08-27-2007, 01:16 AM
RarlyL8's Avatar
WYSIWYG
There is a filter attached to the oil tank vent as seen in the picture. That's it.
I've been running this setup for a few years now without any issues at all. As you can see from the picture there is not even any oil residue from fumes.
I have heard of the smoking issue before from track guys, there must be something to it if Porsche went to the trouble to add that gizmo in the schematic above. It is curious that it does not happen to everyone and it is sportatic. Somebody knows the answer to this, I hope they chime in.
Old 08-27-2007, 07:16 AM
skipdup's Avatar
That's what I'm counting on.
1972 911T
1972 911E "RSR"
Old 08-27-2007, 08:10 AM
A fellow Pelacanite
NathanUK's Avatar
I think I prefer your lightweight idea Brian.
Old 08-27-2007, 10:20 AM
A930Rocket's Avatar
RarlyL8,
What did you do with the line going from the oil tank to the bottom of the oil seperator? Cap it off? I wan't to say ther is one fitting coming off the oil tank filler and that would have to be split between the crankcase line and a small filter like you have to get rid off al the parts.
Old 08-28-2007, 05:49 PM
RarlyL8's Avatar
My engine is a '78 and did not come with an oil seperator. The filter you see on the oil tank replaces a hose that ran to the stock air cleaner assembly. If I were to make the mistake of over-filling the oil level the tank would belch oil into that filter and likely all over the engine bay.
Old 08-28-2007, 06:27 PM
RarlyL8's Avatar
Here is a picture of the stck assembly for a '78. You can see the black hose that goes to the oil tank on top of the oil filler neck and the braided hose that connects to the crank case on the bottom of the oil filler neck.
What year did they start using the oil seperator?
Old 08-28-2007, 06:31 PM
