Con Rod Spec
Can someone please confirm this for me guys.Quiet suprised at how ovalised these rods are for "only" 100k engine.3.0SC.
Size is as image.According to Bentley book, im way out of spec.Just for info, new bolts are not torqued only finger tight.
Will double check this, with "precision" Vernier in morning.This is a cheap chinese job.
Old 12-12-2019, 01:08 PM
Under the radar
Trackrash's Avatar
You will find that torquing the bolts and using a precision measuring tool will make a big difference.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-12-2019, 05:16 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yes Gordon is correct. You can't measure the rod bore dimension with a pair of calipers. You need to use a bore gauge.
Kevin L
'86 Carrera "Larry"
Old 12-13-2019, 08:15 AM
I concur, as the Vernier is good for certain types of required measurements, bores aren't one of them. Any measurement with a Vernier where the tool alignment is critical will not be accurate or consistent. Bob
Old 12-13-2019, 10:36 AM
Thanks buys.Bore gauge is on order.
Old 12-14-2019, 06:20 AM
