Piston ring gaps
Can anybody give me some guidance on what to set the piston ring gap for 2.0S rings? Everything is Mahle if that makes a difference.
The factory workshop manual shows the ring gap to be 0.15mm (0.006") which seems a little small, not that I know more than the factory, only everywhere else I look they give a rule of thumb like 0.004" per inch. ![]() What gives? Do we run super close rings on early cars or did the factory have a misprint in their specs? andy |
Under the radar
The spec is 0.006 to 0.0177". So 0.006" is the minimum allowed.
I might ere on the loose side. An extra .01, .02 will have 0 effect on the compression. Too tight and they touch, the ring begins to twist or buckle and lose contact.
If the ring gap is too small it can pull the top of the piston right off. No, I'm not joking.
Functionista
Looks like your using factory parts and using factory specs won’t give you any issues. The spec is not a misprint, the cylinders really do expand on these.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
That spec is correct for air cooled cylinders.
.004/1” bore is for water cooled engines. I did 0.008” gap on all. Just fine |
All makes sense now, thanks all for your comments. andy |
