Thread sealant for cam housing to cylinder head bolts?
Do these bolts get some sort of thread sealant? Bentley does not mention it, but the threads in the head are a through-hole - so the only oil seal is the captured steel washer under the cap screw head.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" Last edited by burgermeister; 09-06-2020 at 03:25 PM.. |
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Application
If you installed the 574 correctly there should be no leakage.
Bruce
The factory workshop manual does state to apply 574 to the bolt threads.
That, then, would be why they were such a bear to remove ... thanks!
Well, removing & 574-ing one at a time ought not be too bad.
I’ve never seen sealant on the threads of any factory motor I’ve ever taken apart...
Bruce |
I only sealed the outer bolts as they are through bolts, the inner row are blind holes. ![]() ![]() see the installation note 1 |
Good picture of the areas to be sealed but missing required sealant around some
of the holes-remember that some of the studs are inside the valve cover and should have sealant as well.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
