Media blasted valves
Hi all, I asked a friend of mine to clean up my badly coked up valves, but on return I see that he has fine media blasted the stem as well, they are only slightly dull but wondered if they are now not usable or can I polish them up as long as they stay within spec or leave alone and fit ?
Never blast the stems, the guides will potentially wear out. Some do, some don't. Same goes with blasting steel crank gears. The softer aluminum intermediate gear will wear.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-03-2022 at 08:09 PM.. |
I thought that might be the case. They are only very slightly cleaned so was hoping to polish them up, is that not an option now.
Hi guys. Please see photos, I’ve tried to get as close as I can to show in detail but not sure it helps.
Junk, unfortunately. Imagine that rubbing inside a soft brass valve guide.
A bench grinder wire wheel does the job fast enough.
Pricey mistake
Otherwise competent shops sometimes do odd things. A shop balancing stock rods (indirectly) for me once ground heavily on the reinforcing rib on the bottom of the cap. Junk. Detroit iron rods had a big pad there to allow grinding it for balance. Not so our 911s.
I hate sending anything out gives me anxiety.
pm sent to op
Tonger |
Looks like I’ll learn the hard way, your correct about the necessity to give exact instructions when sending parts out. A lesson learned.
Don't feel too bad. Most of us have but a fraction of the knowledge, to say nothing of the experience, of John Walker or other professionals who are kind enough to share hard won knowledge. How are we supposed to know the details of the specialist work we are sending out?
At least your new valves will sit higher on their seats, giving you a bit more compression. |
Oh dear,not good,must have been very course media ? .
IMO used exhaust valves are not worth putting back anyway.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
