PCA Member since 1988
That's resourceful!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-29-2025, 10:09 AM
Hi Spoke
Two words- Bubble wrap
lol
Upland, CA
Old 03-29-2025, 07:15 PM
Banned
There’s not many Porsche’s more iconic than a black 930.
Old 03-30-2025, 01:20 AM
spoke's Avatar
Originally Posted by MoreGAS View Post
Hi Spoke
lol
Yeah, Mark suggested bubble wrap. I used bubble wrap for 914 calipers before but I had none available and had a ton of boxes available for free. The 930 calipers are huge. They are 11 inches long (w/o the connecting pipe) and the large flat rate boxes are 12 in leaving just 1/2 inch on either side. That's why I did 2 boxes at diagonals.
Also had to remove the short connecting pipe between the caliper halves. I couldn't place the caliper in the box w/o the pipe hitting the box.
BTW, according to USPS tracking all calipers arrived at PMB but they were closed on Sat so will be delivered on Monday.
Find Spoke's LED Products:
www.spokeworksled.com
Old 03-30-2025, 04:38 AM
My other thought is the free USPS boxes make great packaging that can be placed to cushion the item being shipped.
Old 04-20-2025, 10:09 AM
My other thought is to use USPS Boxes internally of the outside box as packing.
Old 04-20-2025, 10:11 AM
Banned
Mine looked very much like this.
Old 04-24-2025, 01:58 AM
spoke's Avatar
Calipers are in shipping back to me.
Old 04-30-2025, 04:39 PM
spoke's Avatar
Got the drive shafts removed. Will be cleaning out the CVs, repack and replace the boots. Plan to swap the shafts from right to left.
Haven't made much progress because of work on Mega Pond. I had to get this pond in so I could turn on the pond pump and get the water cleaned. Smelled like a sewer when I first got the pump running. Will have more time now to work on the 930.
Old 04-30-2025, 06:20 PM
spoke's Avatar
The transmission is all together now except for the differential. Looks fantastic.
Internals for the engine are on order. Here's a list of the items:
camshaft flange cover
dowel pin for cam gear
barrel nut for camshaft oil line
camshaft oil line restrictor
alternator shim washer
camshaft thrust washer
rod bearing set
#8 nose bearings
camshaft drive gear
woodruff key
main bearing set
head studs - canyon
engine gasket set - case
engine gasket set - heads
oil pressure relief valve
plug for oil pressure relief valve
guide sleeve for oil pressure relief
spring for oil pressure relief valve
lock plate
oil return tubes
exhaust valves
intake valves
rocker arm shaft
fuel injector
intake manifold flange
intermediate shaft bearings
rocker arm shaft bolt
bushing for rocker shaft bolt
nut for rocker shaft bolt
rocker arm shaft o-ring
timing chain
timing chain rail (5)
timing chain rail (1)
valve adjusting screw
mahle p & c's
oil line banjo bolt
New SC turbo cams
Refurbished rockers
Rocker locks
Old 04-30-2025, 06:27 PM
930 Air Flow Meter Unit………..
Jerry,
You dropped off your 930 AFM unit 3 months ago and did not leave any address or telephone # to contact you. I found the problem and fixed it 2 weeks later. Do you want me to send the AFM to Mark Epstein or you will pick it up? The service is FREE but I will charge you for STORAGE fee. You owe me a cup of black coffee from Dunkin Donuts no cream.
Tony
Old 05-06-2025, 03:41 PM
spoke's Avatar
Originally Posted by boyt911sc View Post
Jerry,
Tony
Tony, you drive a hard bargain. I will comply with your storage fee. I can stop by to pick up the AFM. I feel bad about not going to lunch with you that day which was also your birthday. My car's battery dumped and I barely made it home. I drove straight to the dealer and let them take care of it. So I owe you a cup of black coffee and a lunch.
Old 05-08-2025, 04:57 AM
spoke's Avatar
The calipers are back from PMB. They look fantastic. Looks like they are new from the factory.
The car is being moved from the lift so the 914 can get ready for a few road trips.
Old 07-09-2025, 06:23 AM
Those are beautiful!
Old 07-09-2025, 06:55 AM
spoke's Avatar
The long block is assembled.
The p/c are 98mm. The displacement is 3.4L.
Since the distributor push/pull vacuum can is leaky and NLA, we're thinking about a crankfire system with coil overs.
Old 07-30-2025, 06:37 AM
spoke's Avatar
Pulled the driver side rear hub off to install new bearings. Used a Dremel tool to remove the inner bearing race from the hub.
Old 08-27-2025, 02:37 PM
spoke's Avatar
Rear trailing arm is off. Need to clean it up an remove the outer bearing races.
I couldn't get the hard brake line off the flexible line. Waiting on flare nut wrench to remove this.
Should I use heat on this fitting to remove it. It just won't budge. The other fitting to the chassic came right off no issues.
Started disassembly of the drive shafts to repack the CVs and flip them.
Turns out the half shafts are remans from CVJ Axles in Denver. I thought the boots look in great shape for nearly 40 year old boots. I don't have any info on when the half shafts were installed.
Old 09-07-2025, 06:54 PM
spoke's Avatar
I'm adding a flat belt alternator drive to the list of items to do on the engine. Was never a fan of the 'add shims to adjust belt tension' method. As long as this is compatible with electric AC I'm in.
https://www.clewett.com/index.php?main_page=product_info&cPath=60&products_id=445
Old 09-15-2025, 09:38 AM
spoke's Avatar
Again with the custom made box. This one is for the drive shafts going to CVJ Axles for refurbishing. They already have CVJ stickers on them so they were refurbished in the past. I bought the car with 114k miles and put another 75k on. Not sure when they were redone so sending out just to make sure.
The driver side rear bearings and races are out and the swing arm is cleaned up. Now to give to someone who is more talented than I to have the new bearings pressed in. Probably check with John Butz as he did the passenger side bearings a few years ago. At that time the inner bearing had blown apart. This work is just preventative.
Old 11-29-2025, 08:25 AM
spoke's Avatar
The driveshafts are done and look great. They sent the driveshafts in the box I made. They replaced everything except the outer races.
Is it ok to reuse the bolts or should I get new ones?
The trailing arm is getting reassembled and should be done soon.
Old 01-02-2026, 06:52 AM
