JoeMag's Avatar
Hastech rockers
Anyone have an experience using these?
Old 05-08-2024, 06:10 AM
Looks like LN sells them.
whats your goal here?
1976 914
1986 951
Old 05-08-2024, 08:05 AM
JoeMag's Avatar
Yes, I see you can buy them...
Looking for experience from anyone on their quality, characteristics, and functionality.
Did a little picture cut&paste comparison... left std rocker, center pauter, right hastech. Noticed the angle of foot on hastech is different.
Old 05-08-2024, 09:11 AM
It's a 914 ...
stownsen914's Avatar
Could that pic be cropped? It would be a little strange to mess with geometry on a replacement rocker, as it would change cam timing events.
Old 05-08-2024, 03:20 PM
JoeMag's Avatar
No manipulation... I took these two pics, did a little manipution of mirroring one and making sizes match, then cut the section out and saved.
I'm not sure it would change the ratio, would need to do some measurement center line of rocker bore, pad, and foot. ...I kinda like the reduced angle as when you're at max lift the angle of the adj screw is more "in line" with the valve stem, however, porsche picked that angle for a reason.
Old 05-09-2024, 04:34 AM
the alignment of the pad of the third rocker, is not the same as the first two. I would suggest the rockers are all the same .
Always learning.
www.aircooledporsches.com.au
Old 05-09-2024, 04:56 AM
It's a 914 ...
The contact pad on the Hastech rocker looks a little longer than the other rockers, but the curvature looks pretty similar. Changing curvature within the contact range would affect rocker lift. So not change the critical cam timing events (I misspoke in my earlier post), but it would cause lift to be different than a stock rocker.
Old 05-09-2024, 05:11 AM
No I am asking what are you doing that you need these rockers?
1976 914
1986 951
Old 05-09-2024, 07:02 AM
JoeMag's Avatar
High lift cams where start to run off the lower side (as shown in above pic) of the pad at max lift.
Old 05-09-2024, 09:11 AM
Interesting.
Old 05-09-2024, 05:32 PM
safe's Avatar
They specialize in FIA approved RSR engines etc, so I would guess that the rockers isn't "trick" but follows what is legal in historic racing.
Magnus
Old 05-14-2024, 08:22 AM
Clearly the top pic rockers are far out of alignment with each other. Rocker on left you can see a lot of the inside top right of bushing opposite for left.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-14-2024, 09:06 AM
Got em backwards but you know what I mean
Old 05-14-2024, 09:08 AM
