Banned
Headstuds
Hello what would be the best headstuds if you're rebuilding your porsche engine Thank you
Supertec.
when you see hoof prints, dont automatically assume zebras |
PCA Member since 1988
Need more info about your build and its purpose. Supertec head suds are great, but expensive overkill for most uses, unless you are building a real race car. Porsche steel studs are sufficient for most purposes.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
How does a head stud know its in a race? The use of good fasteners has nothing to do with racing. |
I completely agree but he simply asked which are best and I shared my opinion. Supertec studs aren't going on every engine I build but they are on the ones that are built well outside of factory performance parameters.
It's a serious question, because cost is always a consideration.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 09-14-2024 at 01:56 PM.. |
Try not, Do or Do not
Cylinder head studs are about creating the most consistent cylinder/head platform [stability] no matter what the intended use.
Supertec is a good choice for those interested in improved design features. Precision ground, heat treated, rolled threads Quality corrosion resistant aged 17-4PH steel Better expansion rate than stock steel More consistent clamping force than nonsensical Dilivar Fine thread for more precise torque and force retention Highest quality (12.9), 12 point serrated flange nut [allowing nut to spark plug clearance when twin plugging] Ground and hardened washers Additional threads at case end for more engagement [important for non-inserted mag cases] Longer over all length for custom rod length applications Ease of engine assembly No need for height adjustment Piston can be installed without the stud interference. Price includes studs, nuts and washers. No need to reuse the ridiculous Porsche Allen head nut.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 09-14-2024 at 05:21 PM.. |
A head stud knows it is in a race because it usually sees a rebuild in under a hundred hours where a street engine properly maintained can go well over a hundred thousand miles. The environment on the race track is completely different in terms of heat cycles, stress and just basically hitting redline between nearly every shift which is just not feasible on the street. Kinda like the way race brake pads can't even get into their engineered heat range on the street.
Banned
ARP sounds like the one to use I have my mechanic doing the work and I have to buy the parts. Any recommendation where to buy the parts
Constitutional Liberal
Why?
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
It's a 914 ...
Have a read on ARP head studs. No experience with them personally. I do use other products of theirs and believe their stuff is good in general, but feedback I've seen on their 911 head studs has been mixed
Why is your "mechanic" having you buy the parts? Does he not have a recommendation and relationship the vendor who will supply them?
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The 9 Store
Usually you want your mechanic to pick the parts that they are comfortable and familiar with, not make their choices for them. For example, my painter has his favorites for what the job requires; cost, time, labor, etc. If I'm choosing his materials, he's not my painter, just the guy spraying paint. My engine tech definitely has a head stud preference. It's based on a hundred + builds plus the experience of another engine builder with a couple thousand builds. Not to mention your builder should be able to buy wholesale, not retail.
All used parts sold as is. |
Tough crowd just reuse your old ones
What if your engine has the original Dilivar studs? Like 3.2 Carreras with steel studs on the top and old style Dilivar on the bottom?
In general, "just reuse your old ones" is a ludicrous decision. Every rebuild should be treated as a unique opportunity to build something special.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell Last edited by Turbo_pro; 09-19-2024 at 07:28 AM.. |
...except Dilivar!
Realistically, you can reuse the OE steel head studs if they are not significantly corroded. If they have any more than surface corrosion, you should consider new ones, because the pitting will eventually lead to "stress corrosion cracking." Those pits cause stress concentration,just like a sharp machine edge or other sharp points. The stud is under constant tensile stress, but that stress also varies due to thermal cycles. The largest changes are due to start up and shutdown, but there are also variations in stress due to operating at different power settings. Therefore, eventually, cracks may propagate through the stud and crack it. Bottom lines: If in doubt, replace it. Otherwise, you can reuse the steel studs. I personally like to clean them and epoxy paint them to help prevent future corrosion. Those of you building and running race motors, do whatever works for you.
Scammer. Answered my WTB post, ghosted me when I asked for more pictures and where I can come see them
Is Raceware a good choice? Sorry double post
https://lnengineering.com/products/aircooled-porsche-parts-and-upgrades/raceware-porsche-vw-hardware-and-fasteners.html Last edited by 540964; 09-24-2024 at 07:11 PM.. Reason: Sorry double post |
Absolutely
