Try not, Do or Do not
Actually. Porsche experimented with short and long stroke 2.5 liter engines and the results were as follows. 70-71 2.5l short stroke 87.5 x 66 250hp @ 7800 188 f/lb@ 6200 70-71 2.5l long stroke 86.7 X 70.4 270 hp @ 8000 191.6 f/lb @ 6200 Of course in the development of the long stroke engine they discovered the inherent problem with the 70.4 crank at high RPM. The crank would develop a high RPM harmonic that would spit the flywheel off. The cure for that issue was a redesigned crank used in the later 2.8 and 3.0 RSR engines.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-04-2025 at 09:30 AM.. |
According to the above specifications , the short stroke was a 2.38 liter engine and the long stroke was 2.49 liters , so not really
a simular comparison . Last edited by Richey; 03-05-2025 at 07:47 PM.. |
Rosco_NZ
Carrera 3.0 engine rebuild
No, there were long and short stroke 2.5’s. 2.3’s all SS.
Thanks guys for all the replies.
I went for the Cat Cams as this camgrinder is very local to me and I read on this forum of someone from Denmark who had the same cam in his 2.7 with ITBS and he had 270hp at the crank. If I can get to similar number i would be very happy! I'm also using the valve springs from CAT Cams which are made by PAC springs in the USA. Just ordered a lot of tools from Stomski Racing and my case, crank and heads are at the machine shop to have them checked and rebuild, balance the crankshaft with pulley and flywheel.
Jesse '76 911 backdate with Carrera 3.0 engine |
Lovely tools by Stomski have arrived today. Not bad one week after ordering in the USA to Europe.
yep, I use them and love them.
Always learning. www.aircooledporsches.com.au |
Rosco_NZ
The piston pin C clip tool from Stomski is a very good thing!!
My reground cams for Cat Cams arrived together with their springs. Now waiting for the machine shop.
Some more parts.
Supertec head stud kit ![]() ECUMaster Black ecu and sensors
Nice pieces & parts. Thx for keeping this thread going. This will be fun to watch. Best of luck. Patrick
912E-3.2ss |
You will love the Stomski bits and they will take the likelihood of an error on your part down to near-zero. Excellent investment!
Ken 1986 930 2016 R1200RS |
I use this dynamic compression ratio calculator, I hope it’s of use to you,
https://uempistons.com/p-27-compression-ratio-calculator
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Administrator
What ITB's are you using?
Glad to see another Emu Black ecu join the group. Amazing value.
Still deciding between Jenvey ITB or a local dutch company KMS. https://kms.vankronenburg.nl/products/throttle-body-kits/porsche/throttle-body-kit-porsche-911-optional-airhorns-45mm Thanks Mike. The value of the EMU black does seem to be excellent!
In the meantime I have received my DP motorsport amber fanshroud. Also had some parts Cerakoted.
My 3.1 supertec piston/cylinderset will arrive this week ![]()
Jesse '76 911 backdate with Carrera 3.0 engine Last edited by Jesse911; 07-31-2025 at 05:54 PM.. |
And the 3.1 pistons and cylinders received. Now waiting for the engine shop to have my heads, crank, case ready.
So picked up all the parts from the machinist. Crank was balanced and checked, heads rebuild, case cleaned and inspected, rods checked and new ARP bolts, all new bearings.
I also balanced the the connecting rods to within 0.1 gram. Had a friend 3d print a jig to balance the rods. Worked great! ![]() ![]() I'm now looking into all the sprockets for the timing chains. Does anyone know if the Sebro sprockets are any good? Or am I better of using the old sprockets with new chains?
When it comes to sprockets, I tend to re use them if they are not showing obvious signs of wear. You can go crazy and repace EVERYTHING but if the chains were aligned previously and nothing solid went through the engine, then they should be good to reuse. If I come across one which shows signs of wear from the chains rubbing or if it suffered a tensioner failure, then they are all likely being replaced.
Thanks Mike I will have a good look at my sprockets than. Unfortunately I misplaced my chains so I don't know which one was left and which one right side. If the sprockets look to be in good condition some new chains would be ok?
