Couldn't get a ball bearing nor the fitting off the EGR hard pipe without cutting it.
For now, I've put a small plate across the end of the EGR pipe, blocking the hole. So it is a dead end. It is a pain to thread it below around the exhaust/heat exchangers, but at least it isn't up in the airbox region.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Engine is in! Spent longer than I'd like figuring out the EGR bracket. Forgot to put that little rubber clip on the other bracket, but I can reach it now so I can fix it.
Darkness has fallen, mount bolts are torqued. Time for dinner. Might hook stuff up after dinner, but not going to do a startup until I get some sleep and can re-check stuff in the morning.
