-   911 Engine Rebuilding Forum (http://forums.pelicanparts.com/forumdisplay.php?f=257)
-   -   rocker arm and cam lobe failure (http://forums.pelicanparts.com/showthread.php?t=1180199)
trond 07-13-2025 11:40 PM
I just finished re-building 3.2SS with new cams and refurbished rockers. I ran engine 20 mins at 2000 rpm on mineral straight 30 and then changed to M1 5-50 (A40). Then took it for a drive an hour and removed valve covers to check. There I found #6 exhaust side rocker arm damaged and also corresponding cam lobe. All others were fine. As a part of the post mortem I checked flow pattern from oil splash tubes and all nozzles are spraying as they should. What may have caused this; 1) a problem with the cam or 2) a problem with the rocker arm ? Or can there be any other reasons ?
As a note the same happened on previous rebuild except it was #4 inlet. Same cam supplier but new OEM rockers
What to do on my next attempt ? http://forums.pelicanparts.com/uploa...1752478694.jpg
r lane 07-14-2025 10:53 AM
I would see this years ago when the chain ramps were a rubber type material. They would disintegrate and clog up the spray bars. Depressing. Bob
trond 07-14-2025 12:04 PM
yes depressing. Worse even. I tore down the previous fiasco inn November and the process of getting parts, getting machining done, the time and the money; it has been a long uphill struggle And now back to start and repeat. Same as two years ago. On spray bars; they are spraying as they should. I checked and rechecked both when assembling and when tearing down. And there is no plugging. never was. What is the problem here do you think ? I am thinking hardening of either rocker arm or cam. But hard to imagine it happening on both my two recent rebuilds. What else can be causing this ? This is no longer a hobby. It is a war
What happens to the debris. Will it end in oil filter or will it damage bearings/pump and other? I can not spot any anomalies in the cam housing bores for the cam and think debris pumped back by scavenge pump, to oil tank should be caught by oil filter. And hopefully not damage oil pump
Richey 07-14-2025 06:27 PM
I know that new rocker arms need to be resurfaced to be aligned with the cam . There was a time
when some new rocker arms were not any good . I think it is better to have good original used rockers resurfaced , but you need to find someone that does a proper job .
targa72e 07-14-2025 07:50 PM
do you have a picture of the adjuster end of the rocker. Wondering if its OE or aftermarket.
john
snbush67 07-14-2025 08:36 PM
Did you take pictures of, or do you recall, the position of the rocker shaft before you took it out. The wear on the rocker face looks like the rocker arm was not pivoting. Possibly the rocker shaft wasn't aligned correctly (shaft flush with the outside of the thinner boss) when torqued. A stuck rocker also may have resulted in the valve lash being out of adjustment.
Magyar Kiwi 07-14-2025 10:36 PM
Hi
I would suggest that the damage is consistent with a blocked hole in the spray bar.
Suggest firstly inspect all the holes using a small mirror for any blockage.
(In my case I was able to see a piece of debris plugging the hole that was meant to be lubricating the damaged rocker.)
Second, remove both spray bars for inspection from both ends and cleaning.
Cheers
trond 07-14-2025 11:49 PM
yes, I agree it looks like binding rocker could have been the issue, but I checked for free travel especially on assembly (have seen it happen before) and also when disassembling. No rockers were binding. I always adjust with feeler blade, then always wiggle by hand to check and yes I have caught issue on assembly caused by shaft not in correct posistion. I still agree with you based on the looks.,
Also on assembly the spray bar was replaced. And I checked spray pattern with spirits from a pressurized bottle. Perfect spray both on assembly and also on disassembly
trond 07-14-2025 11:57 PM
I used checked/resurfaced OE rockers straight from a well known machine shop. After re-surfacing; is it then the pad hardened ? to what hardness ? I plan to have mine checked to see if it is a hardness issue but need to know what rockwell c or maybe brinell it should be...?
Henry Schmidt 07-15-2025 04:42 AM
Given the large number of failures associated with "new" rockers we've chosen to avoid their use.
At the present we are testing some new forged rockers and so far they look pretty good.
In our rocker rebuild process, we've chosen to resurface the face (to insure bushing to pad parallelity ), dry film the pad and Cryo treat the entire rocker. Over the years, we've found great benefits associated with Cryo and cast materials.
trond 07-15-2025 07:02 AM
what would you say then is a safe way with rockers ? On previous lobe wipeout I had 12 new OEM on new cam. On this lobe wipeout I had 12 rockers checked for alignment and resurfaced. Eliminating oil supply as a cause I see two common factors; same cam supplier and I as mechanic
Henry Schmidt 07-15-2025 08:28 AM
I can't speak intelligently about what caused your issue.
My guess is rockers are at fault. Compatible materials and properly ground faces are critical.
trond 07-15-2025 10:31 AM
I checked contact patch and they were all perfect. I was thinking cam issue as the same happened on previous rebuild with same cam supplier & new OE rockers. But hard to imagine such damage in just 1 hour caused by hardness anomalies so need to investigate oiling further... maybe crank engine without valve covers and check how much of a mess I get.
Meanwhile I need to start sourcing new parts. Cams from another vendor to eliminate that question, and rockers from I don't know where. I would be happy with any advice on rockers... can not take any risk of a 3rd disaster
Magyar Kiwi 07-15-2025 09:48 PM
Hi
I would suggest that if it was a cams or rockers manufacturing issue you would have had 12 rocker failures or 11 rockers with signs of impending failure.
Limited or no oil supply from one spray hole is sure to cause a single rocker/lobe failure.
In my engine I identified the problem when adjusting the valve clearances and was able to repair by removing and cleaning the spray tube and fitting a replacement rocker.
Porsches later removal of the engine mounted oil cooler and fitting of a (pressure side ) oil filter has some merit.
Cheers
trond 07-15-2025 10:36 PM
agree. But HOW can there be an oiling issue when I have good oil pressure and no plugging in the spray tube ? (new tube and bench tested they all spray). No lack of oil when I took off the valve covers (after draining engine). But there was one more rocker/lobe that had scuff marks on same cyl bank... All others and opposite bank looked good as new
Originally Posted by Magyar Kiwi (Post 12498701)
Hi
Cheers
trond 07-16-2025 01:33 AM
looking at oil circulation diagram it appears all returns from engine go through the oil filter. What are chances for metal debris from cam lobe goes back into engine ? I have not seen any damage in cam bearing surfaces. Should I still split the engine ? Enough to inspect rod end bearings and if good then rebuild. Or split engine. After this repeat fiasco I don't feel certain about anything
http://forums.pelicanparts.com/uploa...1752658326.jpg
Classic 911 07-16-2025 05:13 AM
Start the engine for a few seconds without the upper cam cover to check spray pattern and amount, not just crank it. Then you will see what actually happens.
Do you have original cam covers?
Some aftermarket ones can alter / change the direction of the upwards spray pattern because the oil hits not a flat surface as on the original ones but hits an angle.
Henry Schmidt 07-16-2025 06:28 AM
There are a number of rockers on the market including some you would get from the dealer (OE) that are just low quality.
We are also seeing "re-manufactured" rockers with less than stellar technique in the grinding process.
At this point, I'm still thinking rockers not cams or oil delivery.
All of the images below were offered by John @ DRC
http://forums.pelicanparts.com/uploa...1752675948.jpg
MoreGAS 07-17-2025 10:51 AM
You might weigh all the rockers, and if all the same type, get an average and see how much cast iron material is missing by noting the weight differences. You didn't share which rockers you are starting with. That debris is floating in your engine as well as what is missing off the camshaft lobe, it is very abrasive, like cast iron lapping paste.
We very recently pulled apart a clients extremely costly engine, where someone chose aftermarket "trick"rockers(Brand remaining nameless) , DLC coatedpads ... well all the DLC coating wore off in no time at all, and the rockers began eating the cams, one rocker was missing 7 grams of material and the cam a whole bunch more not determined but it had to be welded-up to repair. Long story short , I had to advise we pull the engine apart with all that debris circulating in the oil . ALL rod bearing looked critically wounded and one was flopping in the rod cap with zero press or retention as all crush was gone and I don't know how it didn't over lap the other 1/2. If car was not towed to our shop, it would have tossed a rod straight out the top of the new case I am convinced. It also damaged the Nitriding on the crank on a couple journals.
Realize also that changing cam brands may do nothing for you as I believe from talking to the Porsche cam providers, all the billet blanks come from the same source. Billets are less prone to these issues vs. the hardwelds and regrinds, we never take that path any longer.
Who resurfaced you rockers and rebushed them? We have seen the new OEM rockers recently, not run parallel to the bushing bores, and not touch flat on the pads to lobes, Brand new. They also are senselessly heavy. Pass on those.
BeST
Kevin
GAS Motorsport
trond 07-17-2025 11:51 PM
thanks a lot. Much appreciated. I am now in the process of splitting the block. From oil flow diagram all debris is pumped back to oil tank, via oil filter. Yet I found no magnetic debris in oil filter. The failed cams (same brand as previous failed cams) were both welded up cams. My rockers were all rebushed and reground by a reputed machine shop, and they all had perfect contact with the cam. I checked this especially. The failed rocker is marked DP1120.
Question on rocker arms; is the pad surface hardened or not ?
BeST
Kevin
GAS Motorsport
trond 07-18-2025 02:30 AM
opened engine and all look perfect, including main bearings, con rod bearings and ims bearing. Not one spec of debris in sight. I will look closer at pump, but as oil pressures are as they should I expect it be fine. After weekend
Henry Schmidt 07-18-2025 05:07 AM
We just got a set of rockers from a prominent So. Cal. Porsche shop. Apparently they encountered some strange cam wear on a recently "rebuilt" engine. The rockers looked rebuilt and cosmetically stellar. When we received these rockers, I called the shop to ask why we were rebuilding these rockers. That's when we heard about the strange cam wear.
We skipped our usual process and went straight to the grinder to help evaluate the rockers. Half of the rockers had pads that were not ground correctly.
Obviously, not all rebuilt rockers are rebuilt correctly.
Classic 911 07-18-2025 10:17 AM
So then there’s the $1000 dollar question:
Which vendor / vendor’s to use for camshafts and rockers ?
mikedsilva 07-19-2025 01:41 AM
Originally Posted by trond (Post 12497601)
Hadn't seen this pic till now.
Hoping someone knows the reason for this as I have experienced it too.. an engine I pulled apart to rebuild a few months ago, had very similar looking rocker shafts. From cylinder 6. Last one in the bank to receive oil??
This engine was sitting for ages and had all sorts of muck inside it. I suspected insufficient oil to the rockers, maybe a blocked spray tube, but when I pulled them all apart it was clear. The engine had not been rebuilt before.
It's a weird shape for it to wear like that.. almost as if the metals had different hardnesses or maybe the valve springs were not keeping sufficient pressure? I don't understand enough about metal wear to explain why it would erode away in those wave-like forms.
One of the theories I have is if a rocker had insufficient clearance, then perhaps a sufficient oil film between the cam lobe and rocker pad was not maintained. ie, if the rocker pad was in near constant contact all the time, then it would be wiping away the oil film?
Or perhaps the rockers are just duds to begin with?
MoreGAS 07-19-2025 10:31 AM
"Question on rocker arms; is the pad surface hardened or not ?"
The stock cast rockers(69-93) are not heat treated as one cannot heat treat cast iron materials. The 993 rockers are a different cast iron material that I believe are stronger.... The early rockers 65-to mid 68 were steel I believe and the faces were Hard chrome plated, they ran without a bushing(though some rare ones may have come with one and we have converted them to run a bushing) and there were problems with them sticking on the shafts...
The race rockers like an RSR , 934, 935 were also a steel rocker (no adjuster screw or elephants foot-PITA to service and adjust even with a pile of lash caps on hand ) with a chromed face. We had some tested years ago and learned the Chrome plating was .004" thick ...By this time mid 70's Porsche started coating the shafts as they have a Black color to alleviate that galling issue(cannot recall the process-Parkerizing?) . Another novelty , these race engines also had steel billet cams .
We recently saw new rockers from The Dealer be off by as much as .003" on the pad surface. (That is the heaviest one in the pictures above with all that mass around the bushing -yes not as bad for moment of inertia but still not likely necessary) Sometimes they touch in the center, sometimes just the 2 sides...this will be an issue no matter what rocker you start with if your's are ground improperly.
The cams on cast billet blanks today are likely made from a very similar hardness cast iron material as the cast rockers, so we avoid the issues of the much harder welded material I assume one ends up with after hard welding the cams to change the profile. We simply had way less issues once we switched to the Billet Blanks when they became widely available for fair (Thanks China) 10 years ago or so, and we've never looked back.
BeST
Kevin
GAS Motorsport
Henry Schmidt 07-19-2025 03:14 PM
A few thing we've discovered over the years. The forged rockers with chrome faces offered the most strength and longest service life at a much lighter overall weight.
Porsche abandoned them early on because they were quite expensive and caused catastrophic failure with that all too common "money shift".
Cams and rocker used in the later engines 66-83 or so, were both fairly generic cold castings, similar material running in contact with each other lubricated by a spray of oil.
In or about 84 the rockers were redesigned to a heavier configuration and I believe a lower quality metallurgy.
Before 84, we rarely saw rocker wear without an oiling issue. This is also the time we started seeing the "Green Idiots" removing lubricating compounds from engine oil.
Cam lobe failures were relatively rare until people started chasing huge horse power. Higher lift meant increased friction and from higher load rates.
Although welded cams have been a common modification on high performance cams, this process started having undeserved negative reputation.
Moving to more modern times, we start seeing billet cams flood the market. Although China would seem to be the likely culprit, most new billets are actually cold cast in Turkey.
Given the great collector value of the older cars, more and more are being restored.
That means more and more companies are looking to cash in on after market parts.
Some very good and some just plain horrible. Poorly designed with low quality metallurgy.
That is what we are seeing in the rocker market.
While other are experimenting with "new " rockers we are rebuilding our cast rockers to a higher standard than even the Porsche factory specs.
For those of you who like the early forged rockers (money shift and all) we have taken them to the next level. We bore them for out proprietary DP4 bushing, regrind them to the proper radius, re-chrome them and finish with a dry film coating on the pad.
Thousands in use and no complaints "YET". 3-2-1
http://forums.pelicanparts.com/uploa...1752966334.JPG
http://forums.pelicanparts.com/uploa...1752966334.jpg
rs-vic 07-19-2025 03:38 PM
trond, could you please post pictures of the sides of the rocker showing the casting numbers or insignia?
trond 07-21-2025 11:59 PM
picture of failed rocker
http://forums.pelicanparts.com/uploa...1753171116.jpg
trond 07-22-2025 07:54 AM
latest update is I should have used hardwelded rockers with hardwelded cam. Clearly advised on cam vendors webside but I missed it. Cost me two years off the road and enough money to launch the space shuttle
stownsen914 07-22-2025 11:20 AM
I've not heard that special rockers are needed for hardwelded cams. Why would that be the case?
mikedsilva 07-22-2025 01:41 PM
Still cannot understand why only 1 rocker arm was affected...
trond 07-22-2025 11:28 PM
I don't understand either why it is only one out of 12. Or how it is possible that that one could be completely destroyed so fast. Or why rockers would need to be hardwelded if the cam is hardwelded ? I understand there is a big hardness difference on a hardwelded cam and a cast iron rocker, but why that would be a problem I don't understand. It would make more sense if it was a lubrication issue but I have not been able to find any flaw with oil supply through the splash tube. Good oil pressure and no obstructions in splash tubes. I have been recommended to send in cams and rockers for assessment.
Meanwhile to get the car on the road before snow I consider using the second hand DC GT2-108 cams I got from you, 9.5CR and stock valve springs. I had 14 rockers refurbished so detracting the eaten up one I have a full set of used cams & rockers that have seen 1 hour only. No cost as I have all the parts already. And do a visual check too of how oil is moving.
dannobee 07-23-2025 12:15 AM
Would you happen to know what valve springs are in it? And the seat and open pressures?
trond 07-23-2025 12:44 AM
Asco springs set to 34 mm. Don't know spring pressure but more than stock
Henry Schmidt 07-23-2025 07:02 AM
My thinking is that failure of this magnitude would suggest a metallurgical failure.
Not all cast iron is the same compound. It can have different levels of carbon (1.7% to 4.5%) and a variety of silicon, manganese, sulfur and phosphorus ect.
This iron mixture is perhaps effecting the ability to take and hold a surface hardening
with any consistency.
It's also possible that these rockers are not chill cast. The chill casting creates a surface hardness that reduces friction, increases durability and at the same time maintaining a softer interior that enhances compressive and tensile strength.
I've heard people talking about heat treating rockers but I believe that process is counter-productive. That is why we Cryo treat our rockers
These "new" rocker appear to function to the point of failure and at that point, the collapse accelerates. Simply put, given more time they will all fail.
We are doing a large number of rocker rebuilds and this specific rocker has not come into the shop yet.
I am surprised at the number of companies attempting to manufacture Porsche two valve rocker arms.
Henry Schmidt 07-23-2025 07:37 AM
Aasco valve springs set at 34mm have a target seat pressure of 70 lbs.
Set at 34mm we are seeing over the nose pressures of around 240 lbs @ .500" of lift.
At 34mm we have a target coil bind clearance of .070" with .050" being the minimum.
trond 07-23-2025 11:35 AM
I checked all rockers again today and it only the one marked with DP1120 that has failed
http://forums.pelicanparts.com/uploa...1753299191.jpg
stownsen914 07-24-2025 04:38 AM
Would be interesting to know the source of the bad rocker.
trond 07-24-2025 05:10 AM
unfortunately I don't know where that DP1120 came from but it was used in my engine previously, with stock cams, and survived in that application
Henry Schmidt 07-24-2025 07:45 AM
The first rockers you posted are early (pre-84) and generally considered to be of better quality. Perhaps a better mix of compounds or simply chill cast where others may not be.
As a side note: they are actually quite a bit lighter.
http://forums.pelicanparts.com/uploa...1753371733.jpg
The others your posted with the H are the same as the dealers in the US sell as OE.
They are crudely made, heavy and prone to failure.
I have never encountered the DP 1120.
