Identifying Intake Manifolds
I purchased a set of 40 IDA 3C/3C1 Webers back in 2018 for a 914-6 2.4 project. Can anyone tell ne about the intakes? The only markings are F.R.P. cast into them.
Top side has 40mm ports. Bottom side are 35mm.
thanks
Old 11-11-2025, 11:20 AM
Sorry I posted twice. I was trying to add a couple photos.
Old 11-11-2025, 11:29 AM
PCA Member since 1988
Just go back and delete the other two threads.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-11-2025, 01:13 PM
I have not had any success with deleting the duplicate posts. I've attached a pic of the intake and carb.
Old 11-11-2025, 05:11 PM
...and the cast marking is R.E.P. - not F.R.P.
Old 11-11-2025, 05:12 PM
Did a quick Google search. Apparently REP may be pre PMO.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1065905-r-e-p-pmo-46mm-intake-manifolds.html
76 911S Signature Edition w/ 3.2
Old 11-11-2025, 05:40 PM
OK, thanks. I couldn't find anything when I searched.
Old 11-11-2025, 05:46 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I'm not certain about the manifolds but the velocity stacks came from TMW.
Now sold under the Borla banner.
https://www.borlainduction.com/product-category/component/fuel-injection-component/air-horn/
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-11-2025, 06:14 PM
It's a 914 ...
stownsen914's Avatar
REP is PMO. Can't recall what REP stands for though.
Old 11-11-2025, 09:08 PM
Richard E. Parr
Old 11-11-2025, 11:22 PM
