Try not, Do or Do not
Short Stroke 2.8
Almost done, what could be nicer?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I would rather be driving
Is this 66x95? Early turbo C3.0 case? I think we all want more details.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
3 restos WIP = psycho
A 2.8SS is indeed a 3.0 carrera/turbo case w/ 95mm pistons and 2.0/2.2 crank by defintion (unless for some crazy reason he has a 962 crank in there; then you can use an SC case). SWEET motor. I bet is runs ~11:1 CR w/ those twin plugs and RSR cams for over 300HP at >8000RPM when installed. I must stop typing before the drool fries my laptop...
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Cool!
Super Moderator
zzzzzzzzzzingggggg!
I recently picked up a '76 turbo case and talked with Henry about building a similar motor using 46mm Webers. The compression ratio would be around 10.? /1 and would run on pump gas. I wanted to use it in a street car and as a backup race motor. After looking at that picture the best use might be in the living room as art.
3.4 twin plug in the works 2.8 twin plug in boxes 906 cams for sale
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
HEY GUYS, THANKS FOR THE KIND WORDS.
What you are seeing is what happens when you love what you do. It's a blessing to be able to make a living doing what you truly enjoy. Just a note: Dean Polopolus of 4 cylinder 911 fame is standing in while my arm heals and it's like having Babe Ruth coming in off the bench. Even though his own engine building company keeps him busy, he found time to help a friend. Come by a meet a legend.
Henry,
What type of header system are you going to use on this engine?
Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head |
It's hard to teach an old dog new tricks.
1 and 5/8 inch flat collector header system with cookie cutter megaphones from European Racing Headers. Old school but very affective. We tend to lean towards old school solutions when building our engines because we like the overall feel and performance of the things we know work.
Correct me if I'm wrong!! ![]() |
The heads on a 3.0 Carrera and a 911 SC are identical.
IT'S DONE
AFTER OVER A YEAR IT'S DONE
2.8 SHORT STROKE 66 MM STROKE 95 MM BORE 2.2 "S" CRANK 3.0 TURBO CASE TURBO OIL PUMP SC HEADS PORTED TO 40 MM IN 38 MM EX TITANIUM VALVE SPRING RETAINERS TWIN ANDIAL DISTRIBUTOR DC80 CAMS (JOHN DOHERTY) camgrinder on this forum 10.5 TO 1 COMPRESSION MODIFIED 2.2 '"S" MFI PUMP, SEALED W/ BREATHER 41.5 MM BUTTERFLY HOUSINGS 41.5 X 46 MM MAG STACKS SUPERTEC FUEL INJECTOR LINES SUPERTEC ENRICHMENT DEVICE EURO RACING HEADERS (George does a nice job) 226 FAN W/1.3 TO ONE DRIVE RATIO SINGLE WIRE ALTERNATOR RSR SHROUD ( GETTY DESIGN) SOLID TENSIONERS (never fail) THIS BAD BOY SHOULD MAKE 300+ HORSE POWER AND TURN 8500 RPM ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Holy Schmoly. That looks the part!
Truly a work of art..I bet the inside looks even better!
I'm interested about the MFI pump..I can see the enrichment mod..neat..what else is done to it? And, I'm about to set up to machine a batch of heads for twin-plug for me and some buddies.. Not having access to any Factory twin-plug heads to compare, I'm planning to copy the 3.6L heads positioning for the second plug..I have some here to copy.. I'd be truly grateful for any hints please.. Kind regards David |
Very nice looking Henry.
Please say hello to Dean for me too. Hey! this is my 500th post! woohooo
John Dougherty Dougherty Racing Cams |
What flywheel are you using?
Thanks Eddie |
Beautiful work Henry!!! Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Author of "101 Projects"
Which distributor is that?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
