Driver's License Owner
The Watson's Avatar
Originally Posted by Jeff Alton View Post
"the Watson"
Top or Bottom studs?
If top, you should be able to get access by removing alternator and releasing the tin deflector. Replace o-rings, and re torque. If bottom bolts, you have more work to do...
NO to RTV.....
Cheers
It was the top right side. Was able to replace orings without removing the shroud. I did use a fine bead of rtv on the outside edge of washer and nut, where there is no risk of it entertaining the crank case. No leaks after cure and restart.
Old 12-31-2022, 07:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #721 (permalink)
Cevan's Avatar
Originally Posted by Privateer383 View Post
Same list as previously posted by others, except I added the return tube o-ring lubricant as recommended in one of Henry Schmidt’s previous posts.
Outer Case Halves: Threebond 1104 (now 1184)
Bearing Saddle Surfaces: Loctite 574
#8 Bearing (balancer end) O-Ring: Threebond 1211 (now 1215)
Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings
Flywheel Seal: DRY
Balancer Seal: DRY
Intermediate Shaft Cover to Case: ThreeBond 1211 (now 1215)
Oil Breather Cover to Case: ThreeBond 1211 (now 1215)
Cylinders to Case: Curil K-2 or ThreeBond 1211 (now 1215)
Cam Towers to Cylinder Heads: Threebond 1104 (now 1184)
Cam Chain Housings to Case: Threebond 1104 (now 1184)
Cam Chain Housings to Cam Towers: Threebond 1104 (now 1184)
Cam Chain Housing Cover to Cam Chain Housing: Threebond 1104 (now 1184)
Gaskets: Thin coat of Loctite 574
Oil return tube O-rings: Dow 55 o-ring lubricant (alternate: Dow 111).
Can someone clarify this?? Oil Breather Cover to Case, Cam Chain Housings to Case, Cam Chain Housing Cover to Cam Chain Housing, Cam Chain Housings to Cam Towers: Threebond 1184?? All of these have gaskets. Are you saying apply 1184 to the gaskets? Then down below it says thin coat of Loctite 574 on gaskets.
I thought gaskets were installed dry. So is the consensus dry or 1184 or 574?
1986 Carrera coupe - black on black
1972 CB500/4
Old 03-01-2023, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #722 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
1184 on all metal to metal surfaces. Gaskets are designed to be installed dry but as parts get older (torquing and heat cycles) distort sealing surfaces. We like to resurface as many of those areas as possible but some as very difficult. Gaskets often need some assistance.
As a general rule, if a gasket may need to be changed or the thermal characteristics of the surfaces require movement, we use Curil "T" If the surface is stable and not likely to need replacing anytime soon, a very thin coat of 574 is applied.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-02-2023, 01:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #723 (permalink)
...I presume both sides of the gasket of course...
D.
Old 03-02-2023, 01:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #724 (permalink)
D.
Very thin coat on both sides.....basically just wet. No bead.
Henry Schmidt
Ph: 760-728-3062
Old 03-03-2023, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #725 (permalink)
Cevan's Avatar
Thanks Henry.
1972 CB500/4
Old 03-03-2023, 07:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #726 (permalink)
Am I correct that 574 would be preferred over 1184 for the air breather cover? This does not seem like an application where a lot of movement would be occurring for the surfaces?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-04-2023, 06:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #727 (permalink)
efhughes3's Avatar
Hey Buck, long time! Hope you're well. I've always used 574 for that, as have many, many others.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 06-04-2023, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #728 (permalink)
Hey Ed! Great to hear from you! Thanks for the info, now just waiting for the 574 to arrive so I can wrap up my project.
Buck
'88 Coupe, '87 Cab,
Old 06-04-2023, 10:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #729 (permalink)
How about a recommendation on the plugs on the cam tower. The ones on the forward end as installed on the engine. To clarify, the same diameter as the cam bearing.
Old 09-30-2023, 11:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #730 (permalink)
I was recommended to use 574 on that cam plug. Have not had a leak in over 20 motors.
Always learning.
www.aircooledporsches.com.au
Old 09-30-2023, 03:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #731 (permalink)
Thanks Mike!
Old 09-30-2023, 04:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #732 (permalink)
Jeff Alton's Avatar
We use 574 there as well.
Cheers
www.turn3autosport.com
Old 09-30-2023, 06:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #733 (permalink)
Thank you Jeff.
Old 09-30-2023, 09:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #734 (permalink)
Banned
The only issue I encountered were a few rocker shafts that "walked", and even with the RSR seals, leaked until I finally got them right.
Old 10-02-2023, 07:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #735 (permalink)
haha
sounds like a legit account for sure...
Always learning.
Old 10-02-2023, 03:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #736 (permalink)
WYDBODY1986's Avatar
How hard is 574 to remove if you have a leak and need to redo a part you used it on? Say the chain housing to case area?
Old 10-12-2023, 12:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #737 (permalink)
Racer
winders's Avatar
Main bearing web surfaces should be nothing.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-12-2023, 05:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #738 (permalink)
Question Clarifications and Updates
I have spent my Sunday morning skimming all 37 pages of this thread. Thanks to Henry Schmidt, CBRacerX, Wayne 962, and others who have contributed. A few questions as I am near assembling our 914-6 (aka 1969 911T) engine in 2023.
  • Current Availability: Are the products listed in post 1 and sold in the SuperTec / Pelican kit still current and available in 2023?
  • Cylinder Base with Copper Gasket: Master list perhaps updated to include Henry’s recommendation for cylinder bases with copper gaskets: Curil T?
  • O-rings: Bruce Anderson had recommended (circa 2009) Dow 111 silione paste. Is it worth comparing to Dow 55?
  • Terminology: There are some words being used interchangeably. Do I have my engine anatomy labeled correctly in this photo?
Old 10-22-2023, 12:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #739 (permalink)
Are folks putting rubber grease on the oil pump seals?
Old 10-22-2023, 10:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #740 (permalink)
