Life moves pretty fast.
quint22cp's Avatar
Question Distributor bung
Hi all
I have fitted a direct fire ignition system to my 1988 coupe and no longer require the distributor, so I want to remove it and bung up the hole. Does anyone have a drawing of an aluminum bung that I can machine up to do this job?
I know I can pull out the dizzy and measure it all up and make one but that means taking the car off the road for a couple of days
Twin plugging, you know it makes sense
Old 01-13-2009, 11:44 AM
safe's Avatar
Originally Posted by quint22cp View Post
Hi all
Make me one too!!
Magnus
Old 01-14-2009, 11:32 AM
Wer bremst verliert
JohnJL's Avatar
I think Smart or JB racing sells them. Works well but be sure to lube up the o-ring (hehehe) or else you won't be able to remove it without splitting the case.
You dont need to take it off the road, just measure the outside diameter of the distributor and re-install it.
If you do make your own you might weld/machine a loop or hook on it for easier removal.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-14-2009, 02:44 PM
Insane Dutchman
Make me one too...but I don't want to have anything outside the distributor hole, meaning no need to bolt it to the adjustment stop bolt. Just a bung that is locked somehow in place.
I have thought and had the idea to glue it in (using a loctite of some sort) and then drill two small holes in the case at the bung location to pin it in for sure.
Likely overkill....
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 01-14-2009, 03:55 PM
Wer bremst verliert
JohnJL's Avatar
Sorry, its Clewett that makes and sells them....page 6 of the catalog...http://www.clewett.com/products/catalog.pdf
$64.00
Old 01-14-2009, 04:33 PM
quint22cp's Avatar
Thanks for all the replies and photos.
I will knock a couple up, maybe with a threaded blind hole so I can screw in a bolt if I need to pull it out.
PM me your address and I will post you one when I find out what works best.
Old 01-15-2009, 10:44 AM
rsscotty's Avatar
Distributor plug
This is a picture of a factory plug. The engine is a 993 GT2. Same 30mm hole in case. The plug as I remember had a 996 part number on it.
Old 01-15-2009, 12:04 PM
quint22cp's Avatar
Well here's how it came out
Old 01-18-2009, 09:02 AM
abit off center
cgarr's Avatar
nice! Myford lathe?
______________________
Craig
G2Performance
Old 01-18-2009, 10:56 AM
