loose nut behind wheel
cudabnu's Avatar
Just split the case, is this a problem?
Not sure what happened here, but is this of big concern, should I have it welded up?
Main bearings and crank journals look good, should I still do the rod bearings since I'm in this far?
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 04-14-2010, 01:04 PM
a.k.a. G-man
Geronimo '74's Avatar
about that hole.. I have no clue how it could've happened.
I was looking at the pics of my teardown but that particular area is not in any of my pics....
I can have a look at my case tomorrow, it's not reassembled yet.
There are some good engine rebuilders on this forum, they'll chime in, I'm sure
I don't know if it is an absolute must to do the rod bearings as well, but I would do them just for good measure even if it was not necessary. Definitely if you plan to do some HP increasing upgrades. If you do, replace the rod bolts as well.
Old 04-14-2010, 01:51 PM
cudabnu's Avatar
Thanks.
From the looks of it, it appears that a tube was installed down the bottom of the thermostat hole, and that is where it broke thru the casing. I pluged the thermostat hole and blew compressed air through the oil pump end and filled the area with the break out with oil to see if I got any bubbles from it leaking, but it appears to be tight. I have a great aluminum welder friend that can weld it up just in case.
PS the black in the hole is the actual tube, the pic makes it look like it is broken open into the oil gallery.
Old 04-14-2010, 02:12 PM
Try not, Do or Do not
Henry Schmidt's Avatar
What you are looking at is normal. The casting is designed that way.
If you want, you can seal it with Permatex Hysol epoxy.
As for bearings: replace mains, rods bearings ( bolts and nuts) and intermediate bearings. Anything less is half assssed.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-14-2010, 02:13 PM
cudabnu's Avatar
Thanks Henry. I refuse to do anything half assed, It's Full assed or nothing!
I'm very familiar with VW engines (I'm in the VW restoration parts Biz) I have a Turbo charged fuel injected 71 VW Convertible, but this is my first Porsche engine rebuild attempt, I bought this engine just to learn on, and like you said, I don't want to do anything half assed. I've been reading Wayne's book every night before bedtime!
Old 04-14-2010, 02:20 PM
SchnellSchweitz's Avatar
I had a hole in the exact same location. Mine wasn't as big, but I think would have been had I not done a rebuild. I used JB Weld over my hole.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 04-14-2010, 04:10 PM
...edit... I've been reading Wayne's book every night before bedtime!
Talk about a recipe for nightmares!!!!
They invented Playboy for that particular time. Sweet young things dancing in your head not torque values and cleaning solvents.
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2010, 07:27 AM
cudabnu's Avatar
Married for 17years and 4 Kids, this is my escape!
Old 04-15-2010, 07:41 AM
Married three times, single now, no kids and she's my escape!
No, she doesn't play chess.
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2010, 07:58 AM
cudabnu's Avatar
That would explain the divorces!
Old 04-15-2010, 08:36 AM
a.k.a. G-man
Damn Henry, nice lamp!!
Old 04-15-2010, 10:46 AM
vmisquez's Avatar
Henry..... she's going to messup that chair. make sure you check for snail tracks.
Old 04-15-2010, 02:28 PM
That seems rather presumptuous not to mention judgmental.
Perhaps she's the reason I have time and incentive to give advice.
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2010, 02:48 PM
120 HP/Liter is all I ask
You sure know how to live Yoda, is there any reason you come to work at all?
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 04-15-2010, 03:20 PM
Jeff Alton's Avatar
Lamp? Where? I didn't see a lamp.......
www.turn3autosport.com
Old 04-15-2010, 04:37 PM
I walk to work so it's really no big deal. Everyone should try their best to be productive.
Once you're done producing everyone should enjoy the liberty of this great country.
Life liberty and the pursuit of ...... what shall we call it? Happiness
I'm thinking about building a hot rod or two. Just picked these up. What do you think? a mid engine flat six 29 hi boy on duce rails?
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2010, 04:59 PM
Yoda, now let me get this straight.
You go from home here:
to here at work
to find happiness? I think I would stay at home if it were me.
Old 04-15-2010, 08:03 PM
efhughes3's Avatar
Rat rod? I fully expect to see one of those on a Friday night Cruising Grand in Escondido sometime in the near future.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-15-2010, 09:36 PM
Don't worry about that hole inside the case. It's normal like Henry said. I wouldn't put epoxy there either, it could break loose and cause problems. There is an equivalent hole on the outside of the case behind the oil cooler. This one you should fill with epoxy to prevent leaks. If the one inside the case leaks it won't matter.
-Andy
Old 04-15-2010, 09:45 PM
to here at work to find happiness? I think I would stay at home if it were me.
Oh confused one: I travel not to find happiness, happiness seems to find me.
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2010, 10:23 PM
