loose nut behind wheel
California Smog -vs- JE Pistons
Looking to see if anyone using JE pistons in their 3.0 has had any problems passing smog. Before I pull trigger and get new P&C's I want to make sure the smog gods will smile once more upon me! Building a 80 3.0 possible going to a
3.2ss
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
I'm here to cause trouble
FWIW, just upgraded a friend's 3.2 to 3.4 with JEs and Nickies - no problem at all with smog....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Did he upgrade the cams? That's the next thing to look into...
Yes, 964 cams from Camgrinder....
Jim
3 restos WIP = psycho
I don't see the CARB guys tearing down your motor to check what brand of pistons you run...
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Correct, but if the dome design isn't as efficient as the stock design, then they will "see" it on the sniffer
I'd be curious to see if that is possible.
I thought JE optioned a CIS dome too. Can anyone confirm that? EBS maybe?
I was curious if they offered the CIS dome on their new piston style casting.
'82 911 previous: '86 951 '72 914 |
Not living in California, I need to ask:
Are there any emission exemptions for cars older than 25 years or for that matter older than a specific year?
Al Morales 77 911 S (930 steel conversion) 88 BMW M3 79 Honda CBX |
1974 and earlier are exempt. They eliminated the rolling exemption years ago.... :-(
It's actually 75 and earlier.
I believe there is a classic car exemption still available. Somewhat restrictive on when you can drive the car.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Cam specs would be more of a factor in passing smog than piston design I should think. Smog specs for that 30 yr old engine are going to be fairly lenient and a fresh engine should be much cleaner than a friend's stock 3.0 with 200k that just past smog.
I took my parts to Aaron at Rennwerks with the 3.2SS in mind, and just send the cams to Camgrinder to be ground to the 964 profile
Once I build up my cash reserves again, then I'll get the Supertech head studs and find some used 3.2 cylinders to send out for the 98mm bore and re-plate for the JE pistons. If it doesn't pass smog, I always have family in Oregon!
No leniency in Calif for smog.
