totle's Avatar
Was thinking repainting my shroud as well, but has seen how ugly it is when paint peal off, so decided to do a "boat treatment" on the fiberglass shroud
Cleaned the shroud from all oil etc. Then started to rub with boat rubbing, then polished with red car polish to get a better color.
This is after all the treatment
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 03-07-2011, 02:07 PM
Targa Time's Avatar
Totle, that shroud looks like new. I'm going to have to give that a try. Kind of sounds like what Flat6pac's friend did with his.
Flieger I tried to send a picture using your hints, however I keep getting told that my file is too big even though I am only trying to send 1 picture. ???
Old 03-07-2011, 03:51 PM
Max Sluiter
Flieger's Avatar
How big is it? It needs to be less than 2MB, though it usually resizes it for me even if it is significantly more than that- maybe even double.
Just open it in microsoft picture viewer, edit picture, compress image for "documents", save as edited version, don't save changes to original, upload the edited version.
or you can email it to me and I can post it for you/email back.
maxsluiter@earthlink.net
Old 03-07-2011, 04:19 PM
Targa Time's Avatar
OK I think I've got it this time.
Recently finished short block.
Old 03-07-2011, 07:12 PM
83 911 Production Cab #10
JJ 911SC's Avatar
You got it
Originally Posted by Targa Time View Post
OK I think I've got it this time. Recently finished short block.
TT
Looking good and hopefully I'll never have to post one like that
Cheers
JJ
Who Will Live... Will See
Old 03-08-2011, 01:57 AM
Targa Time's Avatar
Finished Product
I went the route of polishing compound and wax. It looks much better. I think that the parts cleaning tub had made the surface dull. Have a number of deeply worn grooves from the wiring, but there's not much to be done about that. So here's a photo of the finished product.
Old 03-10-2011, 04:48 AM
totle's Avatar
Great work. Much better than paint IMO.
Trond R.
1986 944 Turbo
Old 03-11-2011, 01:42 AM
Arrow Wrinkled
I found this picture from last year. It shows the wrinkle a little better in the light.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-12-2011, 09:39 AM
1962 356 Ruby Red acrylic urethane
10 years later no peeling, no staining from gas or oil, still looks great
imho easiest is to clean and use shoe past wax. Paint and urethane are different animals when dealing with gel or glass
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2011, 04:20 PM
Targa Time's Avatar
Now thats beautiful ! Do you have a brand for that paint and can you get in a spray can?
Old 03-12-2011, 07:15 PM
thx
I received a wet sample from that pictured 356. Then I sent the sample into Sherwin Williams paint tech directly. Basically I have the paint formula for a custom color.
It's two thin coats of acrlyic urethane. No polishing and it's shot without generating any orange peel. You either have to know how to do this or be prepared to drive your paint guy nuts because he's going to tell you it can't be done.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2011, 11:43 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2011, 11:52 PM
Unregistered non-user
maddin's Avatar
In the process of bringing my shroud back to it's former glory and was wondering how your treatment held up after the install? Considering a boat will never be exposed to temperatures the engine shroud will be i'm wondering how resistant that stuff is?
cheers
Old 02-10-2016, 06:16 PM
VFR750's Avatar
I used the "2K in a can" high temp engine paint from Eastwood. Very happy with it.
My gelcoat was crazed. So sanding and polishing wasn't going to help. I just sanded to roughen the surface and sprayed per the instructions.
One year later still glossy.
Old 02-12-2016, 06:10 PM
maddin's Avatar
mine doesn't look too bad after removing old paint,quite a few marks but i'd like to preserve the original colour . maybe clearcoat
Old 02-13-2016, 01:09 AM
