Was thinking repainting my shroud as well, but has seen how ugly it is when paint peal off, so decided to do a "boat treatment" on the fiberglass shroud
Cleaned the shroud from all oil etc. Then started to rub with boat rubbing, then polished with red car polish to get a better color. This is after all the treatment
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Totle, that shroud looks like new. I'm going to have to give that a try. Kind of sounds like what Flat6pac's friend did with his.
Flieger I tried to send a picture using your hints, however I keep getting told that my file is too big even though I am only trying to send 1 picture. ??? |
Max Sluiter
How big is it? It needs to be less than 2MB, though it usually resizes it for me even if it is significantly more than that- maybe even double.
Just open it in microsoft picture viewer, edit picture, compress image for "documents", save as edited version, don't save changes to original, upload the edited version. or you can email it to me and I can post it for you/email back. maxsluiter@earthlink.net
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
OK I think I've got it this time.
![]() Recently finished short block. |
83 911 Production Cab #10
You got it
Looking good and hopefully I'll never have to post one like that ![]() Cheers JJ
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Finished Product
I went the route of polishing compound and wax. It looks much better. I think that the parts cleaning tub had made the surface dull. Have a number of deeply worn grooves from the wiring, but there's not much to be done about that. So here's a photo of the finished product.
Great work. Much better than paint IMO.
I found this picture from last year. It shows the wrinkle a little better in the light.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
1962 356 Ruby Red acrylic urethane
10 years later no peeling, no staining from gas or oil, still looks great imho easiest is to clean and use shoe past wax. Paint and urethane are different animals when dealing with gel or glass ![]() ![]()
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Now thats beautiful ! Do you have a brand for that paint and can you get in a spray can?
thx I received a wet sample from that pictured 356. Then I sent the sample into Sherwin Williams paint tech directly. Basically I have the paint formula for a custom color. It's two thin coats of acrlyic urethane. No polishing and it's shot without generating any orange peel. You either have to know how to do this or be prepared to drive your paint guy nuts because he's going to tell you it can't be done.
Unregistered non-user
cheers |
I used the "2K in a can" high temp engine paint from Eastwood. Very happy with it.
My gelcoat was crazed. So sanding and polishing wasn't going to help. I just sanded to roughen the surface and sprayed per the instructions. One year later still glossy. |
![]() mine doesn't look too bad after removing old paint,quite a few marks but i'd like to preserve the original colour . maybe clearcoat |
