-   911 Engine Rebuilding Forum (http://forums.pelicanparts.com/forumdisplay.php?f=257)
-   -   Homemade P237 Camshaft Securing Bar - Tool (http://forums.pelicanparts.com/showthread.php?t=741749)
Gordo2 03-29-2013 01:52 PM
Quick & easy homemade Porsche P237 camshaft tool.
All you need is a welder, a 2 1/2" length of 2" I.D. black pipe, a foot or so of 1" black pipe and 3 bolts. Picked up the materials at Home Depot.
Cut out a section of the pipe to fit past the chain tensioner:
http://forums.pelicanparts.com/uploa...1364589402.jpg
*** Before proceeding block off the oil galley with some paper towels so you don't drop any parts into the engine***
I made some pins from some bolts I had in the garage (sorry don't know what size - something that fits reasonably snug in the sprocket holes):
http://forums.pelicanparts.com/uploa...1364589715.jpg
Place the pipe over all 3 bolts and clamp 1 down with a needle nose vice grip:
http://forums.pelicanparts.com/uploa...1364589864.jpg
Weld the first bolt to the pipe. Return to the cam, line up the second & weld and finally the 3rd.
http://forums.pelicanparts.com/uploa...1364590021.jpg
Tack the short piece of 1" pipe across from the tensioner cut-out and you are done!
http://forums.pelicanparts.com/uploa...1364590128.jpg
Shout out to "Squidmarks" for the inspiration.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/323411-anyone-ma-ri-nh-cam-sprocket-removal-tool.html
Gordo
Green993 03-29-2013 01:56 PM
Cool. Show us a pic of the final assembly showing all three bolts.
I actually bought the tool with the intention of selling it after my rebuild.
Walt Fricke 03-30-2013 12:50 PM
Is the notch in the tube there to clear the tensioner?
Gordo2 03-31-2013 07:31 PM
Notched P237
Walt - you got it. Similar to the cut out on the actual P237, needed to clear the left side hydraulic chain tensioner. I positioned the parts on the left side prior to welding to ensure the pins lined up & the pipe cutout cleared the tensioner.
http://forums.pelicanparts.com/uploa...1364783202.jpg
Green993 - I don't have a pic of the completed body handy, but it looks like the in-process one that I posted except it has 3 bolts welded in place ;)
Gordo
Mark Henry 03-31-2013 09:39 PM
I have a borrowed real one here and I'm also going to copy it, unless of course I can keep it till I do my engine mid summer.
I found that VW 36hp crank dowel pins are the perfect size.;)
theiceman 02-13-2022 08:09 AM
wo what a great thread this turned out to be .. im going to forward this to my buddy so he can build one .. he loves building tools.
Alan L 02-23-2022 02:30 PM
Thats much better than what I made. I gas cut a chunk of steel which was about 10mm thick. Cut in semi circle to clear the cam nut. Then drilled and welded a couple of pins in it, plus a handle. Works OK, but doesn't want to sit tight in place. Pins want to deform or slide out.
I am gonna make one of these. Not that I plan doing a head job anytime soon (fingers crossed).
Gordo - were the bolts strong enough - not deforming?
Alan
Trackrash 02-23-2022 08:10 PM
Sometime ago there was a thread on homemade tools. Maybe that thread should be revived.
Jon B 02-23-2022 09:00 PM
Well done, Gordo.
It may be a minor point, but the actual Porsche tool is 9191.
P237 is a replica, made by Sir Tools.
http://forums.pelicanparts.com/uploa...1645677735.jpg
theiceman 02-24-2022 01:34 PM
love this thread ..
Trackrash 02-24-2022 04:34 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/981468-ultimate-home-made-ptools.html#post9860373
You can see all my homemade tools and others here.
Alan L 02-24-2022 05:02 PM
Trackrash - how does that ball joint thing work?
Thx
Alan
jonesb930 02-24-2022 06:26 PM
I just made a bushing for my P237 tool to keep the socket aligned. I used my 3d printer. The PLA material is slick on the inside and I made it with just enough clearance for the socket to spin free. I took the idea from Stomski's nice all in one tool. Since I already had the P237, and socket, it just made sense to print a bushing up. The thingiverse link has the .stl as well as the Fusion360 file as you would likely need to modify it for your specific tools.
https://www.thingiverse.com/thing:5262102
http://forums.pelicanparts.com/uploa...1645755922.jpg
Trackrash 02-25-2022 10:04 AM
Thx
Alan
It fits in the "nut" that holds the ball joint in place.
http://forums.pelicanparts.com/uploa...1645812129.jpg
ATTN: ADMIN. When I search in the Porsche Parts catalog here for ball joint, I get "NO Matches".???
Alan L 02-25-2022 03:42 PM
Got - thx. Was thinking ball joint separater.
I will post pic in a day or so for what I made for same job. Think I did same. I was able to get my impact gun on it to move the cursed nut.
Alan
