Homemade P237 Camshaft Securing Bar - Tool
Quick & easy homemade Porsche P237 camshaft tool.
All you need is a welder, a 2 1/2" length of 2" I.D. black pipe, a foot or so of 1" black pipe and 3 bolts. Picked up the materials at Home Depot. Cut out a section of the pipe to fit past the chain tensioner: ![]() *** Before proceeding block off the oil galley with some paper towels so you don't drop any parts into the engine*** I made some pins from some bolts I had in the garage (sorry don't know what size - something that fits reasonably snug in the sprocket holes): ![]() Place the pipe over all 3 bolts and clamp 1 down with a needle nose vice grip: ![]() Weld the first bolt to the pipe. Return to the cam, line up the second & weld and finally the 3rd. ![]() Tack the short piece of 1" pipe across from the tensioner cut-out and you are done! ![]() Shout out to "Squidmarks" for the inspiration. http://forums.pelicanparts.com/911-engine-rebuilding-forum/323411-anyone-ma-ri-nh-cam-sprocket-removal-tool.html Gordo
Don "Gordo" Gordon '83 911SC Targa |
Cool. Show us a pic of the final assembly showing all three bolts.
I actually bought the tool with the intention of selling it after my rebuild. |
Is the notch in the tube there to clear the tensioner?
Notched P237
Walt - you got it. Similar to the cut out on the actual P237, needed to clear the left side hydraulic chain tensioner. I positioned the parts on the left side prior to welding to ensure the pins lined up & the pipe cutout cleared the tensioner.
![]() Green993 - I don't have a pic of the completed body handy, but it looks like the in-process one that I posted except it has 3 bolts welded in place ![]() Gordo
Puny Bird
I have a borrowed real one here and I'm also going to copy it, unless of course I can keep it till I do my engine mid summer.
I found that VW 36hp crank dowel pins are the perfect size.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
wo what a great thread this turned out to be .. im going to forward this to my buddy so he can build one .. he loves building tools.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Thats much better than what I made. I gas cut a chunk of steel which was about 10mm thick. Cut in semi circle to clear the cam nut. Then drilled and welded a couple of pins in it, plus a handle. Works OK, but doesn't want to sit tight in place. Pins want to deform or slide out.
I am gonna make one of these. Not that I plan doing a head job anytime soon (fingers crossed). Gordo - were the bolts strong enough - not deforming? Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Under the radar
Sometime ago there was a thread on homemade tools. Maybe that thread should be revived.
Well done, Gordo.
It may be a minor point, but the actual Porsche tool is 9191. P237 is a replica, made by Sir Tools.
Jon B. Vista, CA |
love this thread ..
Under the radar
http://forums.pelicanparts.com/porsche-911-technical-forum/981468-ultimate-home-made-ptools.html#post9860373
You can see all my homemade tools and others here.
Trackrash - how does that ball joint thing work?
Thx Alan
Drive it like u stole it.
I just made a bushing for my P237 tool to keep the socket aligned. I used my 3d printer. The PLA material is slick on the inside and I made it with just enough clearance for the socket to spin free. I took the idea from Stomski's nice all in one tool. Since I already had the P237, and socket, it just made sense to print a bushing up. The thingiverse link has the .stl as well as the Fusion360 file as you would likely need to modify it for your specific tools.
https://www.thingiverse.com/thing:5262102 ![]() ![]() ![]() ![]()
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ Last edited by jonesb930; 02-24-2022 at 06:40 PM.. |
Under the radar
It fits in the "nut" that holds the ball joint in place.
![]() ATTN: ADMIN. When I search in the Porsche Parts catalog here for ball joint, I get "NO Matches".???
Got - thx. Was thinking ball joint separater.
I will post pic in a day or so for what I made for same job. Think I did same. I was able to get my impact gun on it to move the cursed nut. Alan
