I have never seen them approve a blank case. When presented with a blank case they (law enforcement) will assign a new number and attach a tag. If you have the old case and it matches the vehicle title they can ok the use of the original number. I never suggested anyone by pass proper procedure. Nor did I ever suggest that I would do it for them. But as usual, people make assumptions. |
It's okay to be in the wrong and admit it once in awhile Henry. You can do it - I have faith. |
time out
Seriously, I'm the owner of the 911T in question and all I can say is I don't give a darn what number is on the block as long as I can drive my car. This thread is about figuring out how to fix a crack so the car can be driven not "lets see who knows more useless crap than the other guy." How about we sort out a way to fix the problem and take the arguments to an off topic thread.
Henry, thanks for the suggestions helping Rusty, hopefully the JB weld sorts the leak when we start it tomorrow. If not a new block may be in the works. Stretch |
You discredit yourself and your well deserved reputation as an expert engine builder when you resort to such schoolyard bully tactics. Come on man. You are more of an adult than that. Not only do you not know Scott and have zero knowledge of who he is, what his background is, or what he really knows or does not but calling him names doesn't make you right. Make your argument on the merits of your argument, not the fact that you have built more engines than Scott will ever see. I personally don't consider a restamped case a true numbers matching car. It is a car with a replacement engine that was an unnumbered case and restamped to match the original number. That is not an original engine. That is an original engine number on a replacement engine. Pretty cut and dry really. Not illegal and not decietful unless a seller tries to pass it off as an original engine instead of a correctly numbered replacement engine. |
| All times are GMT -8. The time now is 04:39 AM. |
