otto_kretschmer's Avatar
3 webber IDF on a flat six?
has anyone ever tried this, or heard of someone putting three webber 40 or 44 IDFs on a flat six?
you would have to build your own manifold, but I'm sure there are many here who could do that
tig weld aluminum would be ideal
gas weld or braze steel would work too
solder one out of copper? you may have a galvanic problem it the copper touches anything steel
carb heat may be needed in colder climates, but probably not in So Cal
if your on a really tight budget or don't want to spend a ton of money for a mini science project, you could try three of those EMPI knockoffs
Old 05-15-2013, 09:11 PM
Where would you mount the carbs ?
On a flat six they'd need to be mounted centrally above the engine so that the inlet tracts were equal lengths (which would then be very long, reducing gas speed) ...
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 05-15-2013, 11:55 PM
You could maybe split them as was done with 48IDAs on Alfa Sud Group I cars and use one choke on each carb and mount 6 but the linkage could be a nightmare.
Old 05-16-2013, 04:10 AM
Puny Bird
Mark Henry's Avatar
I like IDF's, but I would do the motorcycle TB and programmable FI before I'd even think of going this route.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-16-2013, 07:09 AM
holley 4 barrel on corvair
I have seen a single holley on a flat six corvair. He had custom made an alum intake that mounted the carb above the fan with fairly even intake tracks. Ran this on the track for many laps and it seemed to work well. I though at the time that it would be easier and work better to have 6 one barrels, one at each intake
Old 05-16-2013, 08:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Farmers has a setup he puts on the 911 flat six.
http://forums.pelicanparts.com/porsche-911-technical-forum/525603-carbs-idea-enter-care.html
Kevin L
'86 Carrera "Larry"
Old 05-16-2013, 02:23 PM
