-   911 Engine Rebuilding Forum (http://forums.pelicanparts.com/forumdisplay.php?f=257)
-   -   Break in oil- first 20 minutes- Brad Penn or standard non detergent (http://forums.pelicanparts.com/showthread.php?t=756001)
KTL 07-25-2013 06:54 AM
Understood the Mobil Vtwin is intended for air/oil cooled use. But the one thought I had, is there any downside to the dual usage it provides- it also serves the motorcycle transmission and wet clutch?
BURN-BROS 07-25-2013 11:03 AM
Originally Posted by johnman001 (Post 7567711)
Please sir, could you expound upon this please?
You have used "all types" of oils for break in? What do you use once broken in?
(I have also done this but have been shunned as all the "technical data" on oils was typed up on the internet.)
I may be old school, but I truly believe in clean oil with a clean filter.
All types meaning off the shelf any brand Detergent.
I would run the engine, set up a baseline tune then drain the oil. About 2 hrs of run time in total. Then Delo or Brad Penn...I'll discuss Henry's Brad Penn finding with him as I have not heard about it.
The only critical area for oil I have seen is the Cams/rockers. The majority of issues been reground rocker arms that are not parallel.
johnman001 07-25-2013 07:04 PM
Thank you!
Ronnie's.930 07-25-2013 07:29 PM
This question usually gets the same type responses that all oil related questions get - some say "yes" and some say "no". Based on my personal experiences with using motorcycle oil in non-wet clutch engines (Ducati 748R which I endurance raced for three season and my 930 - both engines which I overhauled at one point), the answer is no, there is no downside. Obviously, mine is a very limited experience base, however.
earossi 07-25-2013 10:07 PM
Kevin,
My understanding is that the V-twin Mobil 1 lacks the friction modifiers present in the normal Mobil 1 for cars. So, without the modifiers, I guess you could expect a slight degradation in fuel economy. The normal Mobil 1 in the 15W50 viscosity still has the elevated ZDDP that our flat tappet motors need. Or, if you go to Mobil 1 Racing oil, all the viscosities have the elevated ZDDP levels.
cmcfaul 07-26-2013 04:23 AM
Regualr Mobil 1 15 /50 has 1350 ppm Zinc
V-twin has 1750 ppm Zinc
Brad Penn has between 1200- 1500 http://www.penngrade1.com/Zinc.aspx
Flat tappet engines need 1400-1500 ppm zinc
Chris
earossi 07-26-2013 06:16 AM
Brad Penn has between 1200- 1500 Penn Grade 1 High Performance Oil
Chris
Chris,
You are generally accurate on your comments on zinc. What needs to be added is that most oil suppliers have cut the ZDDP levels from 1300-1500 ppm to levels around 650 - 750 which appears to be unsatisfactory for our flat tappet motors.
If you are in the market for 15/50 oil, then I question that the Mobil 1 formulation isn't a good choice, even though it does not quite meet your criteria of 1400 ppm for zinc.
In reality, whether you run Mobil 1, Mobil V-twin, Motul, Joe Gibbs, Total or some other brands I may have left out, it will come down to availability and cost. All these oils are expensive and may not be readily available. And, all thanks to the USEPA for creating this dilemma for people with older cars.
KTL 07-26-2013 06:28 AM
Thanks for the tips on the V-twin formulation. Sorry for the sidetrack but I thought i'd ask since the mention of it came up.
I'm going with the Chevron Delo 400 for my motor when it's done. If it's good enough for Henry, good enough for me! Already got two boxes (6 gallons) on hand from Costco!!!
CBRacerX 02-10-2015 04:22 PM
Thanks for the tips guys. Just got six 1 gallon Delo 400 30w jugs from Amazon. Let the engine break in begin.
3literpwr 02-11-2015 01:33 AM
Here are the numbers. Note that all the break in oils have triple the zinc.
1. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
ZDDP= 3000 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
2. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
ZDDP = 1500 ppm
NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use.
3. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
ZDDP = 1500 ppm
4. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
ZDDP = 1100 ppm
5. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
ZDDP = 2100 ppm
6. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
ZDDP = 1400 ppm
7. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
ZDDP = 1000 ppm
8. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
9. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
ZDDP = 1500 ppm
10. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
ZDDP = 900 ppm
11. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
ZDDP = 1200 ppm
12. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
ZDDP = 1300 ppm
13. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
ZDDP = 1100 ppm
14. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
15. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
16. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
17. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
18. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
ZDDP = 1500 ppm
19. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
20. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
ZDDP = 1600 ppm
21. 15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1133 ppm
phos = 1,168 ppm
ZDDP = 1100 ppm
22. 30wt Edelbrock Break-In Oil conventional = 69,160 psi
zinc = 1545 ppm
phos = 1465 ppm
ZDDP = 1500 ppm
23. 10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
ZDDP = 100 ppm
24. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
ZDDP = 1300 ppm
25. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
ZDDP = 1500 ppm
26. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
ZDDP = 1100 ppm
27. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
ZDDP = 2100 ppm
28. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi
zinc = 2436 ppm (up 1848 ppm)
phos = 2053 ppm (up 1356 ppm)
ZDDP = 2200 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
29. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
ZDDP = 1100 ppm
30. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
ZDDP = 1900 ppm
31. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi
zinc = 1673 ppm
phos = 1114 ppm
ZDDP = 1300 ppm
32. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
ZDDP = 1300 ppm
33. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
ZDDP = 2400 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
34. 10W40 Summit Racing Premium Racing Oil, API SL conventional = 59,483 psi
zinc = 1764 ppm
phos = 1974 ppm
Claimed ZDDP level on the bottle = 1800 ppm
NOTE: Summit discontinued this line of oil, as of spring of 2013.
35. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
ZDDP = 2500 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
36. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
37. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
ZDDP = 2800 ppm
38. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi
zinc = 1565 ppm (up 573 ppm)
phos = 1277 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
39. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi
zinc = 1680 ppm (up 573 ppm)
phos = 1275 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
40. 30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
ZDDP = 4000 ppm
cmcfaul 02-11-2015 09:03 AM
The Mobil 1 V twin stuff is $14/ qt expensive. I usually mail order it through Amazon. Some times it goes on sale locally.
A real V-twin has the transmission and clutch separate from the engine (attached by a fat belt). I question if the Mobil V-twin oil is designed for a wet clutch environment.
Chris
911pcars 02-11-2015 09:33 AM
This could quickly morph into another 50 page oil thread, so let's keep this topic to "break-in lubes".
GM's EOS additive (now marketed as AC Delco Assembly Lube) is widely used on engines, for break-in as well as long term. Here's some discussion about it:
E.O.S (Engine Oil Supplement) | Oil Additives | Bob Is The Oil Guy
Sherwood
boosted79 02-11-2015 10:01 AM
So should one conclude from post 50 that the Lucas 30wt is the best oil for break-in due to the very high concentrations of ZN, Ph and ZDDP?
MetalDoc 02-11-2015 04:56 PM
Just curious where you got all the data from post #50? Also how was it determined?
Trackrash 07-31-2015 04:38 PM
What about this stuff?
http://forums.pelicanparts.com/uploa...1438389522.jpg
skier8 12-17-2015 06:25 PM
I believe Porsche,AMG,Corvette and etc use Mobil 1 from the get go. I have disassembled quite a few air cooled 911 engines and have yet found any tappets (my MG has 8 my 6 has 0). The 20 min cam break in? The main reason is flat tappet engines need the oil splash from the crankshaft to lube the cam.
RedCoupe 12-18-2015 03:52 AM
True, our P engines do not have tapperts or lifters in the traditional sense. But, the rocker arms are lifted directly by the cams, so there still is the same sliding kind of motion that there is in an OHV engine with flat bottom lifters. If you contrast that with, say, the valve train of an LS engine with its roller lifters, you cam see why people desribe a Porsche six as a "flat tappet" engine.
James Brown 12-18-2015 05:39 PM
http://forums.pelicanparts.com/uploa...1450492775.jpg
get this, done
faapgar 12-19-2015 07:47 AM
break in oil.
Hi,I have always used Valvoline non-detergent straight 30W for the first 500 miles.Then do your leakdown te full st to determine ring seatage.No full throttle at first 500 miles.
JOHN21BLACK 12-28-2015 01:36 PM
Henry, My mechanic used Valvoline VR-1 20/50 for break in. Was told to change after 1,000 miles. Have not put any miles on new rebuilt yet, only been starting for 30 min at a time while I do my brake upgrade and bushings replacement. Was told it would be fine to stay with the VR-1 20/50, but should I go to the Delo 400 SAE30 after the 1,000 miles?
rkeele 01-03-2016 10:04 AM
Been using Total racing 20-50 any opinions or numbers
rkeele 01-03-2016 11:45 AM
I was told by a SC oil dist. and the latest is Diesel Oil is no longer optimal for air cooled motors , they have reformulated it for the new catalytic converters in the new diesels, also told that by 2 diff. mech. that I know.
bigred23 01-07-2016 03:31 PM
That's interesting; as I understand, the primary difference between older CI-4 vs CJ-4 oils is the ash content (which acts to obstruct diesel particulate filters). CJ-4 oils still have fairly high zinc and phosphorous levels; for example, Chevron Delo 400 LE 15W-40 (CJ-4) has ~1200 ppm P and ~1300 ppm Zn. Non-LE Delo 400 15W-40 (CI-4) has ~1400 ppm P and ~1500 ppm Zn. As Henry's comments were from a few years back, I wonder if he still goes with Delo?
rkeele 01-11-2016 08:41 PM
good question he said he uses the LE which has lower numbers, Total racing is different than non racing has more zddp from what I was told.
VFR750 01-29-2016 11:28 AM
Oil Analysis by ANA Labs.
Oil Analysis performed on oil bought in mid-late 2015
20W50 Valvoline VR-1 Conventional Racing (Silver bottle)
Zinc: 1177 ppm
Phosphorous: 1281 ppm
20W50 Castrol GTX Conventional (Yellow bottle)
Zinc: 1074 ppm
Phosphorous: 816 ppm
I thought the 20W50s were not subjected to the required drop for the SN rating. Well it turns out Castrol GTX is off my list. The 20W-50 actually tested out as only a 40W at 100C test conditions. It's really only a 20W-40....
Even VR-1 now seems a little low.
Determined 02-09-2016 03:40 PM
subscribe
Alan L 02-09-2016 09:20 PM
Originally Posted by Henry Schmidt (Post 7498604)
I understand that the Porsche world loves Brad Penn but we're seeing some of the worst results (wear) in engines that use exclusively Brad Penn. We're using Delo 400 in everything.
Henry - would the SAE 30 recommendation apply to turbo as well (930) - break-in and track use? I've got to break my engine in shortly - because the last lot of rings never seated in the deglazed bores.
New P/Cs this time round.
Alan
Damon88 02-23-2023 10:06 AM
Been searching and decide to bring this thread back to life... (without starting a debate) Interested in current thoughts on break in oil itself. I have a new complete rebuilt engine ready to start soon. Locally I can get Lucas Oil SAE 30 Break in oil. This is the Data specs. Thoughts...
http://forums.pelicanparts.com/uploa...1677179146.jpg
winders 02-23-2023 10:48 AM
I recommend Driven break-in oil. I am going to use Driven BR40 to break-in my new race engine on the dyno and then switch to Driven XP6 once broken in.
I believe Driven BR is the 30 weight version of their break-in oil.
Damon88 02-24-2023 08:43 AM
Interesting. Never heard of this brand. I will have a look and read up. Not sure if it's available locally in Canada. Cheers
winders 02-24-2023 10:28 AM
Driven is spectacular oil.....very well regarded in the racing community. Not cheap....
Jeff Alton 02-24-2023 11:30 AM
It is available... Mopac Autosupply and Lordco both carry it, though I am not sure of the availability of all different part numbers.
Cheers
OSC911 02-24-2023 01:45 PM
I’m a bit of an oil nerd. I have looked into the Driven range and it is pretty impressive. Also, available in Australia fairly readily - probably going to make the switch next oil change.
Damon88 02-24-2023 02:49 PM
Cheers
Thanks Jeff! I will go to Lodrco and inquire. Cheers !!
Emo993 03-06-2023 06:50 AM
Driven Oils, developed by Joe Gibbs Racing. Lots of Nascar titles/wins with lots of oil development. Just a great oil for our air cooled engines. Best, Mark
PeteKz 03-06-2023 05:12 PM
About 7 years ago, I was at Carlisle for a weekend Ford show. Joe Gibbs Driven had a tent set up. The presentation was given by their chief engineer (I forget his name). The main point of his presentation was to NOT use any aftermarket oil additives, and just as importantly, why. It turns out that there are several dozen different formulations of ZDDP, "zinc," or whatever name you use, as well as the other additives (detergents, friction modifiers, etc.). The oil additives have to be designed to work together, so that the one does not interfere with the other or actually cause it to precipitate out. Then you end up with less ZDDP or other additives than you started with. Therefore, don't user any oil additives. But you already knew that.
Of course, when you have access to a guy like that, you hang around after the presentation and ask more questions! It was a fascinating discussion, all the details of which I can't fully recount, but some important points: the highest pressure and wear points in an engine typically are the cam and follower contact, and the rocker to valve stem. These places have high loads that concentrate in a line or even point, with a wiping motion that tends to wipe off the oil film, so ZDDP is crucial at these points. Newer engines are designed with roller followers on the cam in order to reduce these point/line and wiping motions, because EPA regs have increased the time that emissions systems must be warrantied, and the zinc poisons catalytic converters, so in newer oils the ZDDP had to be reduced, forcing the followers to be redesigned toward with less of it.
Another important point: The break in occurs in the first 100 miles, usually much less, because engines are now manufactured to tighter tolerances, and the cylinder wall finishes are smoother, so the rings seat sooner. In addition, most new engines are now test-run on a dyno before they go in the car, so that part of break-in already occurs before a new vehicle even reaches the customer. The journal bearings (mains, rods, and cams) should not break in, because they should always be floating on an oil film. Some other parts may see high loads, such as timing gears or chains, but usually not if well-designed. Driven offers a break-in oil, but he said that for new cars and trucks it's not necessary. If you are building a racing engine with cast-iron and rougher cylinder finish or using older cams and lifters, then use it.
Well, as everyone now knows, our old air-cooled 911 engines weren't designed for low-zinc oils, so we want to find oils with high ZDDP levels. Diesel rated oils became the initial go-to oil for the older hobbyists, because diesel engines didn't have catalysts until recently, so they had higher levels of it. However, as most of you also know, in recent years, diesel engines have been fitted with catalysts and Diesel Particulate Filters (DPF), and consequently the zinc levels have been reduced somewhat. So just picking any old diesel rated oil no longer guarantees high ZDDP.
To further complicate things, the oil manufacturers change their oil formulation from time to time, and don't make widespread announcements about it. It's not a trade secret, but you have to go to their websites and look up the oils and see whether anything has changed recently.
Since that's a PITA, I've been using the Ford Motorcraft brand 15W-40 diesel oil for Powerstroke Engines. I don't have the experience that some of you do with building 911 engines for decades and seeing how long they last and what wears out, or what wears out in racing, so If you have good results with a particular oil, I won't argue. But I chose the Ford Diesel stuff because it says right on the bottle, "Contains more than 1000PPM of phosphorus (that's the P in ZDDP). Not for use in catalyst-equipped engines." Yeah, that sounds like the good stuff to me. I was using Delo for a long time, and still use it in some other old cars, and I can't say I ever had a problem with it. But the label on the bottle doesn't tell you much. So I lean towards the Ford Diesel stuff. Especially when it's on sale at Walmart!
Anyway, some things to think about when you go shopping for oil. And if in doubt, check the web site for the oil manufacturer.
