Break in oil- first 20 minutes- Brad Penn or standard non detergent
Hello,
Yet another engine break in question. In short, do I save my case of Brad Penn break in oil for the 20 minute initial start up or use it for the first 1K? I hope to start my engine up this weekend or early next week. I reused the P&C and had them re-ringed, reground cam and rockers, so for the first 20 minutes, should I use some FLAPS non-detergent 30W oil and save the BP break in oil for the next 1,000 miles or should I use it for the first 20 minutes and then get a decent 30W oil? What is a decent non-detergent 30W oil that you can buy locally? Any advice on this tiresome question would be appreciated. |
I understand that the Porsche world loves Brad Penn but we're seeing some of the worst results (wear) in engines that use exclusively Brad Penn. We're using Delo 400 in everything.
So I should be fine with this stuff then? http://forums.pelicanparts.com/uploa...1371240778.jpg Thanks for the advice! |
And... You can get it at Costco. Although, their version is Delo 400 LE. Not sure what the LE stands for?
Not sure I'm tracking vs the original question. My understanding is to just use a basic 30 weight oil for the very initial run it to get rid of the assembly lube, initial metal wear and other junk from the first 20 min or so. Are you recommending the "Delo" for that, or for regular use?
Hopefully days away from heads coming back and getting on the road again.. |
The Delo 400 LE 15W-40 that I can get at Costco is labeled as having "ISOSYN" technology and touts "synthetic performance" though it is not a synthetic oil. I couldn't help but wonder, given the conventional wisdom against using synthetic oil for break-in, if these near-synthetic properties would make it unsuitable for break-in.
I'm determined to make sure my rings seat, so (based on fear and superstition) I'm breaking in with Rotella-T before changing to the Delo 400 LE I've got in a box in my garage... |
Hi Henry,
Interesting observation on the engines running Brad Penn. I was going to pick some up in a couple of weeks. Now you've got me rethinking. The Chevron site shows a Delo Multigrade 15W-40 for use with pre-2007 engines. Curious if this is preferable to the LE designation? Also, would you recommend SAE 30 for the first 20 min run in period, then the multigrade after that? I was planning on just using the multigrade from the get go. cheers |
interesting, the lycoming service bulletin i just looked at says it is ok to use the same oil (like 20W50 phillips 66 aircooled engine oil) for both break in and normal use. I always used the mineral ashless dispersant oil for the first 25 hours. Now it is ok to use the same oil for that. the oil game continues.
Gibbs BR.
Cheapest oil you can get off the shelf at autozone/checker/oreilly/bond/napa/advance auto/parts plus/krager/pep boys which is normally the store brand stuff. Change after the first 30mins of operation and again at 1000 miles.
Synthetic after that at 2500-3000 miles. I've done this on a number of engines with great results. Mobile 1 or Castrol Syntec for the life of the engine. Dino oil is far more prone to caking/sludging. The brown surface stain/slime is not present inside a synthetic oil engine if you may have noticed... |
I switch to the good synthetic oil after around 100 miles in a turbo though. |
Sorry for the sorta hijack, Its interesting on the Brad Penn comment. I moved from Mobile one to Brad Penn and notice better oil pressure for a given engine temp. I even started a log book to make sure I wasn't convincing myself b/c its what I want to believe. Maybe Bard Penn is better than mobile one and Delo is better than Brad Penn in the order of things. I guess this should be obvious but maybe factors other than psi at a temp are more important
Another observation is that air-cooled 911 engines that don't leak quite often leak when synthetic oils are substituted for petroleum oils. |
..and toilets flush counter clockwise in Australia for no apparent reason.
Coriolis
Speaking only for myself, I just haven't seen ANY wear problems using B-P 20w-50 racing oil or the 15w-40 stuff.
Recently, a 3.0 race engine was disassembled after 200+ hours (thats a LOT of time for a race engine) which has been driven quite hard and everything was virtually like new: cams, rockers, bearings, etc. We simply installed new rings (old ones were still within spec), new rod bearings for insurance, and buttoned it back up. P/C's had 100K++ on them. Two things come to mind: we are very careful about air filtering and do not use glass beading during the engine cleaning process due to the difficulty in getting every last bit of abrasive out of everything (same reasoning for never using abrasive discs for cleaning gasket surfaces). We use soda for all parts cleaning task since it leaves a virgin surface, is water soluable, and leaves no abrasive residue. Maybe we are just lucky, but I've been very pleased with the Brad-Penn oils for many years. Its the same basic product as the original Kendall GT-1 oil which was the gold standard since the early sixties. |
I re-ringed my Nickasil cylinders and used a generic 15W-40 oil the first 200 miles before changing to the usual Swepco 306 15W-40
I took great care to really load up the engine the first miles, as that has always worked well on my other engines However the rings took more than a year and some 6000 miles to bed in and the burnt oil smell did not go away until I did a track day. If I were to do it again I would use Millers break in oil AND run the engine hard |
They are put together so loose you can drive between most parts in a semi. Very old school engineering and technology. They are so mired in the RED tape paper work deal, it takes 5 years to get a great idea to be "allowed " to be changed or installed. Its most EZ to do it the "always has been" way.LOL They are still running around with one cam, magnetos, and so on , Yes they should have dual ignition..but wow, 30 pounds worth ? And so govt rolls.......................... When it comes to cams they are in the center in a oil bath..drowning |
have to agree, but the point is that any oil can be used as break in oil, if changed at the specific time. I do call the engines tractor engines!!!!
The set of JE pistons I got came with a specific warning to use non-detergent oil (30?) for initial run or void their warranty.
Otherwise see tronds comments below; "I re-ringed my Nickasil cylinders and used a generic 15W-40 oil the first 200 miles before changing to the usual Swepco 306 15W-40 I took great care to really load up the engine the first miles, as that has always worked well on my other engines However the rings took more than a year and some 6000 miles to bed in and the burnt oil smell did not go away until I did a track day." |
nicasils might be the exception and as always follow manufacture procedures
Oil is a Religion around here
and i respect what Henry has to say....all albeit he left out the whys... For the most part it has been the Borg of thought around here- Non detergent for break in because it helps the rings seat faster better. Dump it go to a count race oil. Brad pen has been up on the list. I have never used it I have 30000 miles on my car and 2 valve adj. I use what I can find like Valvoline V1 or Kendall Race oil. So far the wear on the lobes is negligible .I am a couple 1000 miles past a due adj on the valves, but all is quiet in there In the end as many pros have said "use a high P.M. count." Some swear by syn oil, others hate it Maybe Henry will explain his stand on Delo. I know its a great oilf for a diesel |
The intent of Non detergent oil is to prevent any intermixing of the detergent packages in different oils and greases. If they mix they can react and cause a chemical reaction that resembles soap.
Now, I have used all types of oil for break in (except syn) and have never had a reaction nor has it influenced the seating of rings. This non-detergent rule may simply be tradition now as the oil companies may have settled with one type of detergent, which I was told was bleach based. Delo is intended for heavy duty Diesel turbo applications, mechanical injection, as well as a detergent package to keep Diesel engines from forming deposits. It has translated well to Air cooled Porsche engines. |
Then I am thinking Shell 15/40 Rotella ought to work too !
Yup!
I posted some observations. I've spent years explaining why my studs work and life is too short for conjecture on every observation. I have taken apart a few engines recently that ran exclusively BP and seen wear I didn't expect. That's it. No grand scheme, no hate, just an observation. I have used Delo for a few years now (in the street and race engines) and it's easy to find and it's relatively cheap so Delo it is. As an anecdotal story to rival most, we built a titanium 4.0 liter race engine that performed flawlessly for 200+ hour in the sand. Upon freshening we found no issues with bearings, rings, or any wear items. 200+ in the sand with Delo from break-in to present. Recently a dyno guy told us that Delo is showing better readings than BP on the dyno. Why? I don't know.......does it really matter? For you conspiracy theorist: I forgot to ask my dyno guy if he had a position in Chevron futures...... :) As for : converting from synthetic oil to petroleum oil in an air-cooled early 911, I have no science there either, just observation. If we ask, we'll get 30 guys that tried it with the same result. Leaks......where no leaks existed before. |
Thanx Henry......
I just needed a short good answer Purrfect |
If you have sludge keeping you from leaking then imagine what your internals look like. I've made the switch to synthetic on non-porsche engines specifically prior to a rebuild or modification and used CRC detergent to flush before tear down. Rotten, leaking gaskets and seals replaced.
Then once on Synthetic, there's nothing quite like cracking into an engine after a decade and having it be cleaner after those 10yrs and zero bearing wear. |
First time, to lower compression for turbo and replace timing chain ramps. Second job was for a hotter cam.
So, the question is; Does the application of an engine assy. lube (EOS or equiv.) mitigate the absence of Zn and Potassium in the suggested "break-in oils"? Or perhaps an assy. lube wasn't used; does the short oil change interval minimize the feared scuffing and wear at the high-load areas (e.g. cam lobe/rocker arm contact area)? And if so, why?
Or have we started yet another "Why I hate........ oil" thread in this engine rebuild forum? :) Sherwood |
pretty much
You have used "all types" of oils for break in? What do you use once broken in? (I have also done this but have been shunned as all the "technical data" on oils was typed up on the internet.) I may be old school, but I truly believe in clean oil with a clean filter. |
For a flat tappet engine, it's all about the Zinc.
Mobil 1 V-twin has 1750 PPM. I believe that is the highest of them all. 100% synthetic - check Highest Zinc - check designed for air cooled engines - check Expensive - check :-( I have used it exclusively and am doing a bottom end rebuild after 100k hard miles. The bearings show very little wear. Facts, not opinions. Synthetic is better. High Zinc is better for flat tappet engines like mine. Do not use if your car has a catalitic converter. Chris 73 911 E |
Oops forgot the original post topic. Breakin
My machine shop and Porsche expert talked me into useing Brad Penn Break In oil. This is a streight 30 weight designed for break in. I plan on using it for 500 miles then back to the V-twin stuff (20-50). Chris |
Running the Delo (Chevron) right now for my stretch following new P/C and top-end from 1000 to 2500 miles prior to a planned switch to synthetic. I noted how cloudy the oil was near the bottom of the freshly sealed gallon relative to the first few quarts that came out. If you're adding a partial container then I would recommend shaking it up first.
