82sc tensioner help URGENT (car is apart)
I am replacing a chain tensioner on 82sc 3.0
I did not notice the position of the actual tensioner orientation I was so concerned with keeping chain tension and everything in order.
OK, first, pics of old tensioner
Now, I am not sure if this is correct or not
the piston is not 100% under the idler, its out about 1mm
there is about 1.5mm-2mm of space between idler and tensioner
Is this correct? does this allow the idler to "float" a little bit?
I have verified that both the old and new tensioner are the same thicknesses on these measurements.
I pulled the other side cover off and there is about 1mm-1.5mm space between idler and tensioner, but the piston is all the way under the idler
CORRECT?
Old 11-28-2015, 09:17 AM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Can't help. I had oil fed. Someone here is sure to help you.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 12-15-2015, 01:44 PM
This has been done and buttoned up. Everything was okay.
Old 12-15-2015, 02:36 PM
