Finally did the strut bearing, bump stops and boots. Noise is gone. I thought I had to remove the strut. But it wasn’t necessary. I removed the top nut, unwound the coil spring, pulled the piston down and swapped the parts. Total of less than 1 hour. Impact gun is necessary to achieve this time. Now it’s quiet and handing improved. I adjust the camber a bit and now it tracks nicely. I resisted the temptation to cut the spring.
Never give up
